Old 07-14-2008, 10:05 PM   #61
wingracer's Avatar
Trader Rating: 24 (100%+)
Do the same thing but roll them around on the tire truing table. Free tires.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-15-2008, 04:23 AM   #62
tc3team's Avatar
Originally Posted by Bluey_74 View Post
Use the brushes in your motor (without a comm tru) until the spring doesn't hold them in any more
+1 Thats gotta work, as the brushes will weigh less. Once you are down to the wire you've done very well.... UNTIL you loose comm connection on the last lap of that A main....
Alloy spring seats on the suspension are a must have too, .3 or more if they are gold and .2 if they are red for the rarity factor alone. Otherwise its only .1 for blue
Running 1/12th foams down to the wheel so the spur gear self destructs when you literally "tear" down the main straight is probably going to win you the race, as all the cars behind you go under the carpet
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-15-2008, 09:14 AM   #63
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Use an oversized spur gear that pokes through the bottom chassis about 5mm. Then set a ride height of 5mm.
Not only does the bigger spur gear look cool and obviously be worth .1 a lap, but you get a bonus .3 a lap for having a 5th wheel. As the teeth break off your spur gear you get an additional .1 a lap for the weight savings
-Mark
mok is offline   Reply With Quote
Old 07-15-2008, 09:33 AM   #64
Suspended
Use left-handed tools only ~~ everyone knows it takes less time to get from the left-handed batters box than the right-handed one.
rocket-mtrsprts is offline   Reply With Quote
Old 07-15-2008, 09:54 AM   #65
Regional Moderator
CarbonJoe's Avatar
Talking
Wouldn't that only work for oval guys? Most road courses run clockwise, so you need right handed tools.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 07-15-2008, 10:05 AM   #66
Suspended
ssshhhhhhh, dang it, now you've let the cat out of the bag
Old 07-15-2008, 10:08 AM   #67
wingracer's Avatar
I have separate tools for oval and road course. Just have to be careful not to mix them up or bad things would happen.
Oval guys need to find the old Bolink LTO oil (Left Turn Only). It was specially designed for oval racing. I guess the oil would only stick to the side of the bearing that was loaded. hahaha
Team Shepherd USA
Old 07-15-2008, 10:13 AM   #68
Suspended
a liberal coating of Crisco on the throttle finger make for much smoother acceleration and response... you can also use it for sunscreen in a pinch on those especially hot days, always good to keep a tin in the pitbox
Old 07-15-2008, 10:28 AM   #69
Regional Moderator
CarbonJoe's Avatar
Let's see... Crisco as sunscreen, Coppertone as traction compound for foams on asphalt. Got it.
Old 07-15-2008, 10:39 AM   #70
Suspended
...and don't forget to give everything a little dash of Gold Bond Medicated Powder, your shorts, armpits, and under your cap (if you get tense during the race, the powder keeps your hat from sticking too tightly on the skull and constricting the brain) ~~ and the car too, makes it move nice and slippery through the air
Old 07-15-2008, 07:57 PM   #71
trailranger's Avatar
When seating the brushes, run the motor backwards. Prevents black arcs on the comm which is faster..
trailranger is offline   Reply With Quote
Old 07-15-2008, 08:37 PM   #72
I'm not sure what would help your rc car - but I know that this guy's probably "good for a second" in any real race car he drives.
Dale Epp - (rapidly becoming a Kyle Busch fan)
"It was worth a second a lap..."-kyle-busch.jpg   "It was worth a second a lap..."-kylebusch.jpg   "It was worth a second a lap..."-dollar-general.jpg
daleepp is offline   Reply With Quote
Old 07-16-2008, 07:21 AM   #73
Starteur's Avatar
Thumbs up
Go to your local Radio Shack store
Buy the anti-slip stuff for the video's and the cassete deck's belts
Put that on your rubber tires like you do with traction compound,
5 minutes before the race or qualifying.
HANG ON TO YOUR STEERING!!!
This trick was given to me by another racer and it was worth 1 turn for me!
Make sure you put the stuff in an old Traction compound can!
Clean your tires with brake cleaner, put on the stuff and GO FOR IT!
Starteur is offline   Reply With Quote
Old 07-16-2008, 07:51 AM   #74
kavadni's Avatar
Light weight in car peltier device
kavadni is offline   Reply With Quote
Old 07-16-2008, 08:21 AM   #75
mok
mok's Avatar
hehe, sorry for those who might appear in this pic :P
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Huge "Clearing Out Maxx Parts" Sale (Worth a Look) stil2hi95 R/C Items: For Sale/Trade 14 06-02-2005 10:10 AM
