Old 07-12-2008, 08:05 PM   #46
Bigshades's Avatar
Trader Rating: 22 (96%+)
here are tips for the really sneaky...
-Dump out your competitiors cans of traction compound, and replace with CA. Your competition will never make it off the line!!!
-Also try replacing with vaseline, It will make thier cars into drifters!
-Replace your competitors oil with CA, thier motor rpm's will fall drastically, and bearings cease!
-If a competitors' car does not break down during a race, YOU must break it down! Bricks work great, and range is directly increased by the height of the drivers stand! Litteraly CRUSH your competition!
-Sneakily replace all lipo's with 1200 nicads, and watch your competition comit suicide!
-Replace thier shock oil with JB weld. talk about ultra-stiff setup!
-if competitors run Nimh batteries, replace the pack with 6 giant firecrackers. This is the most realistic representation of Nimh!
-Replace thier tires with jelly donuts.
-Put all of your flatulant activities(farts) into jars. Build a rig to open all of them seconds before the start of the race. If all other compatitors do not turn green and fall of the stand, then resort to the backup resviors at once!
-Hire a few hot chicks to distract the competition. You can win the race if you dont stare too much.
Bigshades is offline   Reply With Quote
Old 07-13-2008, 01:32 PM   #47
trailranger's Avatar
That would be cheating, but adding a few drops a Plasticizer to their traction compound will do wonders taking away just enough traction.
Plasticizers do the opposite of what the solvents do. Instead of breaking apart the bonds of the rubber it combines the bonds of the rubber reducing the stickyness. Good for making hard rubber tires become drift tires
trailranger is offline   Reply With Quote
Old 07-13-2008, 08:59 PM   #48
Regional Moderator
CarbonJoe's Avatar
Shortening your motor wires 1/4 of an inch is good for .3 seconds per lap. You know, because of the huge voltage drop over 1/4 inch.
Using bearings with a different color rubber seal is good for .1
Paint your body with a faster kolor. That alone is worth .2
Anodizing your plain aluminum parts is good for .4
Switching to a dish wheel is good for .1. Unless you already run one. Then switching to a non-dish wheel is good for .1
There's your 1 second a lap.
Now, if you switch brands of diff grease or shock oil, add .1 back.
Cleaning the foam tire dust off your car also adds .1 back, since you are interfering with the boundary layer, causing air to stick to your chassis instead of flowing over it cleanly. This is the same effect as having dimples on a golf ball. Dirty = fast.
Having the turnbuckle indicator notches towards the inside of the car is faster than having them towards the outside on a road course. Of course, for oval, you have to run them on the right hand side to help with wedge.
That's all I got...
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 07-13-2008, 09:05 PM   #49
wingracer's Avatar
Trader Rating: 24 (100%+)
Apparently bad soldering is actually worth a tenth. I used to always give the local hotshoe a hard time about his incredibly bad soldering jobs. One day he finally had enough and yelled at the top of his lungs "So you're telling me if I could solder better I would break the track record by two laps instead of one?"
I wanted to say yes but I admit I was kind of speechless on that one.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-13-2008, 10:37 PM   #50
When the track gets sprayed with grape soda, add 2oz of Rit Black Dye and 2oz of Molasses for every 2 liter. OMG that will give so much traction that moddified will be looking for more motor. The Rit Dye just makes the track appear fast with a well worked blue groove.
Store your tires in Air Tite Containers! That makes them go faster. Lance Armstrong would not ride on new rubber tires, he would always ride on 2 year old tires that were kept in a Humidor
Old 07-14-2008, 03:33 AM   #51
tc3team's Avatar
Replacing all the steel screws for alloy ones on the gearbox housing is good for a .2 a lap until they break when you wrench them...
hey, they'll look good before they get damaged wont they!
On that note.... Why cant we get alloy circlips and grub screws? massive weight savings there....
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-14-2008, 07:07 AM   #52
adamge's Avatar
What's a gearbox housing? I'm pretty sure my Xrays don't have them.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 07-14-2008, 07:20 AM   #53
Default i think its sarcasm!
The best one is not maintaining your car, thats worth a second a lap,
just glue together old broken parts, "its just a little broken, its still good,......"
or "a dirty car is a fast car"
Use the brushes in your motor (without a comm tru) until the spring doesn't hold them in any more,
Tires are always good on their 11th to 13 run!! I SWEAR!
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 07-14-2008, 07:26 AM   #54
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
The speed differential between holding the radio's antenna pointing toward or at the car, straight up, or over your shoulder.
Discuss.
Bonus points for including the radio-neckstrap factor.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 07-14-2008, 07:31 AM   #55
redlion's Avatar
Run the tires until the cord shows. That is worth a secound a lap. Make sure you run them in your main. That will give you first.
redlion is offline   Reply With Quote
Old 07-14-2008, 07:35 AM   #56
Default antenna envy
Good point.
Lets discuss........
Antenna pointing away from you, Towards car, aka THE FISHERMAN
shorter distance to the car, = gotta be wirth a tenth or 2.
anenna pointing away from car (over drivers shoulder) aka THE GOLFER
further away from car, and more obsticals between radio and car, (ie your friggen big head!) slow as, mate dont even try it! not worth it
neck strap = wank factor! only good to show people how bad you CHOKED in that last qualifyer!!
and remember, anyone using crystals with those big antennas is just over compensating for something somewhere else in their lives............
Old 07-14-2008, 08:31 AM   #57
kavadni's Avatar
Cool shades.
Kevin
kavadni is offline   Reply With Quote
Old 07-14-2008, 06:41 PM   #58
bmr
Trader Rating: 27 (100%+)
I always pick up a couple tenths when Jackyl is playing on the sound system.
Hello everybody, welcome to the show
We're headed for destruction, don't you want to go
It's time to romp and stomp
It's time to jam
It's time for you to kick some dirt up off the ground
Are you out, are you in, if you're in are you for sure
And get your a** on out the door
'Cause if you're in you're in, and if you're out you're out
bmr is offline   Reply With Quote
Old 07-14-2008, 07:27 PM   #59
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Reviving those old ass tires with some heavy solvent is worth at least 1 second off a lap.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 07-14-2008, 09:52 PM   #60
If it is foam tires,
some spray adhesive on the tires and do some slow laps on the fringe to pick up the black dust and you just made your self the perfect tire. Compounds, who cares...it will be what ever the other guys are running.
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Huge "Clearing Out Maxx Parts" Sale (Worth a Look) stil2hi95 R/C Items: For Sale/Trade 14 06-02-2005 10:10 AM
