Old 07-10-2008, 06:34 PM   #1
Default Gear Ratio Question.
I have a question about gear ratios, the question is what is the effect of going higher in number value verus going down. Meaning going from like a 6.57 to 6.80 or going in the other direction 6.57 to 6.36. (brushed motor)
I know one gives more torque less top speed the other gives less torque more top speed.
Also Im finally switching over to brushless motors is the gearing going to be the same or is there a big difference in the gearing?
Any help would be appreciated
Steve P.
srp67 is offline   Reply With Quote
Old 07-10-2008, 07:08 PM   #2
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
There will be a HUGE difference in gearing between brushless and brushed. As the FDR numbers go up, gearing will decrease, meaning that the motor will make more revolutions compared to one revolution of the entire drivetrain. The higher the FDR, the more the motor turns to turn the drivetrain once, this equates to more tourqe and less motor strain. Running a high gear ratio will be a low FRD, meaning that the motor will spin less compared to one revolution of the drivetrain. this means more top speed and more strain on the motor, batts, and speed control.
To find the FDR of a car, take the spur and divide it by the pinion, then multiply that number by transmission ratio.
In simple terms, a 6.36 will have more top speed than a 6.8.
Hope this helps.
-Kyle
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 07-10-2008, 08:15 PM   #3
Thumbs down I like your post.
A good post.thanks ofr out standing.acer
batterygogo is offline   Reply With Quote
Old 07-11-2008, 05:45 PM   #4
Thanks for the info, Kyle.
I have another question if anyone wouldnt mind answeringthe track that I run at everybody with a brushed motor gear at about 6.5, I will be running in the 17.5 class. Could someone suggest a starting point with the gearing.
-Steve P.
Old 07-11-2008, 07:41 PM   #5
cla5675's Avatar
Trader Rating: 49 (100%+)
I run on a 80x20 carpet track as well as a 120x60 outdoor asphalt track and I've been running the Novak SS17.5 at 4.2 and lower depending on the track layout. The 17.5 is a torque monster and you've gotta use some low ratios to get the speed out of that motor.....just my 2 cents.
cla5675 is offline   Reply With Quote
Old 07-12-2008, 11:39 AM   #6
Thanks. The asphalt track I run is pretty close to the same size, I will give it a try.
-Steve P.
general gear ratio question TRF-Powered Electric On-Road 10 06-09-2014 12:32 PM
Gear ratio question! Horth Racing Electric On-Road 2 02-10-2008 08:35 AM
Gear Ratio Autopsy1 Rookie Zone 7 01-10-2007 07:17 PM
540 gear ratio Tamiya No1 Australian Racing 7 06-17-2005 09:33 AM
gear ratio.. TRF_TG10R Nitro On-Road 0 08-06-2003 05:18 PM
