Team Orion 3800 Lipo or Team Trinity 3800 Lipo?
#31
any one wana buy some NIMHs
Malc
Malc
#32
I'm looking to buy a new lipo for my TC and have been leaning towards the 5000mah SMC hard-cased packs rated at 28C (I think). Alot of local guys say there is a noticeable difference between the SMC packs rated at 28C vs. the older Orion 3600 packs rated at 25c.
I checked the specs on the new 3800 Orion pack and it has a 30c rating.
Has anyone done a comparison with the SMC 5000mah rated at 28C vs. the new Orion 3800mah rated at 30C? Is the power the same, noticeably different? I am not concerned with run-time since our heats and mains rarely ever go past 5 minutes.
I also plan on getting two packs. I am leaning towards the Orion packs because of the bullet-style connector ports. As far as the Trinity 3800, I don't know much about it but I can go in that direction also because of the bullet-style ports. However, I look at the "C" ratings (power) more than I do MAH (run time).
Thanks!
Thanks!
#33
many co. had use more mah or 2S-2P to get more amps for discharge ,
but can't same 30C feel ( punch & respond )
#34
Thanks!
Thanks!
#35
Time savings in Orion 34's,38's and 5000's
Thanks!
Thanks!
I wonder when the rest of the Mfg.'s are going to do the same?
#37
Thanks!
Thanks!
and you'll be glad you did. I just got 2 myself and it's got plenty of
power compared to my Orion 4800's. You can really feel the difference!
My friends were using the SMC 5000 28C and there's no difference in the
straights.
#39
I use the orion advantage flight charger or rc power both good and easy to use.
lipo sacks are as good as they are bad. just make sure of the settings on your charger.
i dont know the venom but the ones i use check the cell against what you tell it you are using so it is virtually impossible to make a mistake.
dont charge at a higher rating than reccomended if in doubt charge at 1c.
I really dont think it makes any difference to performance if you charge at 1c v 2c but it will definetly reduce the life of the cell.
the only thing i noticed is that the lipos perform best when warm, so try do do a few warm up laps before the race.
#40
If you're not concerned with run-time, just get the Orion 3800's 30C
straights.
straights.
Thanks.
#41
Glad to see there are a wide variety of lipos that everyone is happy with. I still need to buy one. Or two. Never used a lipo pack before. I've been doing a lot of reading though.
#42
I've been running the Orion 3800 for a few weeks now. I picked up a Trinity 3800 to try and the Trinity was faster for me. Felt faster and lap times proved it. Both are great batteries, but I prefer the "T".
#44
GT POWER A6 Charger
I'm very new to this rc stuff...recently just bought orion 3800 with GT POWER A6 Charger. Can somebody tell me what does the 1c means when charging the battery. Is it '1 cell'. Does anyone knows how to set and what i need to set on the charger to charge this lipo battery?
#45
1C means charge at the rate equal to the mAh capacity of the pack. So your pack with 3800mAH is charged at 3.8A or 3800mA.
