Old 07-09-2008, 09:50 PM   #1
Default does locking the front diff help?
Hi, I'm wondering if locking the front diff does in fact provide a good alternative to a one way diff.
I've read somewhere that by using the one way you lose the front brakes, and that by adding a higher weight oil to the front diff you can basically lock it, which helps by giving you a bit of the one way diff action without losing your braking power.
I'd like to try this but which oil weight should I begin with for 1/10 onroad? Probably locking it completely would give a bit of handling issues so I'd be looking for a medium or relatively high viscosity. have you guys tried anything like this?
Rufus2000 is offline   Reply With Quote
Old 07-09-2008, 10:44 PM   #2
Yeti35's Avatar
What car are you referring to that requires oil for the diffs? I am not aware of any electric TC that uses this. Spool is a good thing for asphalt and some claim for carpet as well. I run a spool in both my asphalt cars. Spool = locked diff.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 07-10-2008, 12:32 AM   #3
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
*serpent s400*
This car has gear diffs. thats enough being a smartass for me. And yes, the spool is the hot asphalt setup.
I know a lot of people that prefer a spool to a one way as well.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 07-10-2008, 02:39 AM   #4
tc3team's Avatar
A tighter front diff can also help when using foams on a smaller, technical track
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-10-2008, 04:26 PM   #5
Its an HPI sprint2
I still have to open it to see if the gearbox is sealed otherwise I'm worried that the oil could leak out. On the exploded view it does show the spider gears inside the diff, and what looks like a ring or seal for the case so it probably is.
I recall reading someone said to use a 500,000 wt oil on their diff to lock it, but this was for a 1/8 buggy. could this work on 1/10?
Old 07-10-2008, 05:38 PM   #6
shadow102's Avatar
Trader Rating: 21 (96%+)
if you truely want to lock it and have it not be permanent go get some silly putty and stuff it in there it works great for gear diffs
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 07-10-2008, 05:51 PM   #7
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
depends on application really. review xray's setup guide for reference
R
UltegraSTI is offline   Reply With Quote
Locking Centre Diff??? slyts6 Micro and Mini Scales 0 03-11-2008 06:20 AM
locking out the frt diff fstnv1 Oval, Larger Scales and More 1 07-26-2007 08:55 PM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 11:11 PM
front lock diff vs gear diff rhed Nitro On-Road 4 11-29-2005 02:20 PM
locking a 1way diff pink pac man Electric On-Road 7 06-08-2005 12:08 PM
