Old 08-19-2003, 08:34 AM   #1
Default New Yokomo/Rayspeed charger and discharger
These new battery products look interesting. The charger seems like a good deal. Has anyone tried them or know more about their capabilities and quality?
coolrcdad is offline   Reply With Quote
Old 08-19-2003, 11:14 AM   #2
Matt Howard's Avatar
I've been using the yokomo BCS single charger for a couple of months now and like it alot. The only thing I could nit-pick about is that is doesn't have a backlit display but it does have a swivel display so it makes it pretty easy to see anyway. I haven't tried the rayspeed discharge tray yet but from looking at it, it should be good as well.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 08-19-2003, 03:13 PM   #3
Matt,
Thanks for replying. It looks like it is comparable to the LRP Pulsar but at a better price. I'm looking for a second charger and this might be the one.
Old 08-19-2003, 03:19 PM   #4
Accord's Avatar
Send a message via AIM to Accord
Originally posted by coolrcdad
Matt,
I've got a Reedy Quasar Pro for sale for $110 shipped if you're interested, it's barely been used since i've got a GFX.
Accord is offline   Reply With Quote
Old 08-19-2003, 07:01 PM   #5
peter_robinson's Avatar
Trader Rating: 21 (100%+)
the yokomo BCS single charger is definatley a great charger. the only thing that it seems to lack is the dicharge feature and motor run feature that the pulsar gives you. how ever the charge mode is a little "smarter" if you will, and software is compairable to the GM vis commander.
the rayspeed discharge tray will have 5amp ans 2amp discharge modes and will accept 6 and 4 cell packs. it also has external leads to power a built in fan off of a 12v power supply.
peter
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 08-19-2003, 08:17 PM   #6
Does anyone know what the adjustibility of the delta peak cut-off is on the Yokomo charger. For example, the Pulsar can go down to 5 mV per pack (I think). This is an important feature for sensitive cells, like the GP3300s.
Old 08-19-2003, 08:18 PM   #7
I'll check for you tonight, I "believe" it goes down to 10mv per pack.
RCTech #361
Old 08-20-2003, 02:13 PM   #8
Here's some details from Steve at Speedtech RC:
Yokomo BCSS Battery Charger:
Charging capabilities: HiMH and NiCd
Number of cells: 1-12 cells
Battery capacity: 270mah-6000mah
Charge Amperage: 0.3-9.9Amps
LCD Display Modes: Voltage, Aperage, Cpacity, Temp
Charge Modes: Yokomo Charge, Peak Charge, Temp Charge
Built in cooling Fan.
The size of the BCSS is the same exact size as the Yokomo MMS (Motor
Management system) It's really small. I would say it's about 6 inch x 4 inch x 1 1/2 inch in size
Rayspeed EXCEED Discharger:
Battery type: Sub-C NiMh, NiCD
Cells: 1,3,4, o4 6 cell
Mode: Equalizing (5 Amp discharge), Conditioning (1 Amp discharge)
Cut off voltage: Ni-MH (0.9V) NiCd: (0.1v)
Built in singl fan
Led lights: Red = Power, Auto cut: yellow
Case size 161 x98 x47mm (which is about 6 1/2 inch x 4 inch x 2 inch)
Old 08-20-2003, 02:30 PM   #9
utieh's Avatar
the specs of the charger are very good, especially at that price ($140)!
since I already own a Pulsar Comp, I won't change now
does it have bad points, like false peak....
I will probably order the RS discharger
utieh is offline   Reply With Quote
Old 08-20-2003, 06:18 PM   #10
I've used the charger for a couple of months now and I haven't false peaked once, my quasar pro does every now and then but not the BCS
RCTech #361
Old 08-20-2003, 08:47 PM   #11
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I just bought the BCS from Speedtech... hope it works out nice..How does the Temp part work on the charger?
mike_Webb is offline   Reply With Quote
Old 08-20-2003, 09:22 PM   #12
you adjust the temp cutoff on the charger and attach the probe to the battery, when the cutoff temp is reached it shuts off. I haven't really played with that because I'm racing outdoors and the ambient temperature varies as the night goes on.
RCTech #361
Old 08-20-2003, 09:23 PM   #13
mike_Webb's Avatar
Cool... so ideal for indoors Winter season..Nice... Thanks Matt
Old 08-20-2003, 09:59 PM   #14
that's when I plan on using it, when I'm indoors and the temp isn't going from 105 to 70 degrees.
RCTech #361
Old 08-21-2003, 05:59 AM   #15
lonestar1127's Avatar
the Yokomo/Rs discharger has similar spec as the new Eagle discharger??
lonestar1127 is offline   Reply With Quote
F/S Rayspeed/Yokomo discharger Dasupacat1 R/C Items: For Sale/Trade 6 03-05-2006 01:59 AM
Yokomo Rayspeed discharger R/C Anonymous R/C Items: For Sale/Trade 5 05-19-2005 03:48 PM
Reedy Quasar Pro's, Yokomo Motor Mate, Rayspeed Discharger Randy Caster R/C Items: For Sale/Trade 10 03-15-2004 12:57 PM
Wanted: Yokomo/Rayspeed discharger JusBox R/C Items: Wanted to Buy 0 11-22-2003 06:39 PM
Yokomo Rayspeed Discharger... kaizen Electric On-Road 11 11-12-2003 12:44 PM
