Old 07-08-2008, 12:26 AM   #16
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
wow, so much discussion on this little module. I guess at the end of the day by using this module it'll tell you which motor is the best without using the ESC.
Good thing is it's the size and adaptability to any motor tester. Last thing you need is to haul another piece of equipment or buy another.
I got a glimpse of it working with the MM Motor Master. No additional wires or sensors required and that is sweet.
I don't see how this module would cost a lot of money. Who knows, as it's still in it's early stage as a prototype.
I got some better close up of the module which I'll post later.
CHRIS LIM
OVERGEARED RACING
chrisman is online now   Reply With Quote
Old 07-08-2008, 08:21 AM   #17
Send a message via Skype™ to revolution31
Originally Posted by RCSteve93 View Post
I hope thats a good hall sensor for $15. My robotics team at my high school was using $50 ones
It was $50 for 4 not $50 each. We had to use the robotics organizations sensors and they are way expensive.
4 for $50 = 1 for $12.50 ....you just contradicted your first post....again...
revolution31 is offline   Reply With Quote
Old 07-08-2008, 11:09 AM   #18
trailranger's Avatar
Just take your old Brushed dyno hook up the MOTOR ESC like everyone else.
You might beable to use the power off the dyno just by setting the ESC at FULL Throttle and using a RX pack to power the ESC. Turn off LiPO Cuttoff.
When dyno puts voltage into the ESC, the esc will rev the motor. If that works, play with the different modes to see which give the best power curve for your racing.
trailranger is offline   Reply With Quote
Old 07-08-2008, 11:20 AM   #19
JevUK's Avatar
You will need a reciever battery pack as per my post
http://www.rctech.net/forum/showthre...39#post4291139
MRT, Novak, Spektrum, Sanwa, Tamiya, Alleven RC, Maxamps, CheapBatteryPacks, Duratrax Ice, Pro Peak PSU, Nuova Faor, McLarney Racing, Futaba, KO Propo, Team Associated, Enerland.
JevUK is offline   Reply With Quote
Old 07-08-2008, 11:30 AM   #20
Send a message via AIM to HenBeav
Originally Posted by syndr0me View Post
Why wouldn't you use use Novak's Sentry with the brushless harness? It calculates RPM from the Hall sensors.
http://www.shopatron.com/product/part_number=5365/135.0
nevermind
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 07-08-2008, 01:30 PM   #21
ta_man's Avatar
Trader Rating: 151 (100%+)
From the pic, this is being used with a speed checker, not a dyno. So basically, you are free revving your brushless motor at full throttle. Novak (and probably other manufacturers) strongly recommends against that. The question is: will this think work with a real dyno, that puts a load on the motor?
ta_man is offline   Reply With Quote
Old 07-08-2008, 01:48 PM   #22
JevUK's Avatar
If you already had a dyno why would you need one of these?
Old 07-08-2008, 02:10 PM   #23
Because you still need some way to convert the DC that the Dyno outputs to the motor into AC that the brushless motor accepts.
Old 07-08-2008, 02:11 PM   #24
JevUK's Avatar
Yeah I know, it's called a speed controller
Old 07-08-2008, 02:41 PM   #25
Is that what a RX pack is? Check my post
Old 07-08-2008, 02:55 PM   #26
JevUK's Avatar
Yes just like I explain in January and posted the link to that yesterday
Old 12-28-2008, 02:41 AM   #27
This type of tool Help really?
higbo is offline   Reply With Quote
Old 12-28-2008, 08:49 AM   #28
Bigshades's Avatar
Trader Rating: 22 (96%+)
If you want to test your motors with a Brushed Dyno, Yes.
Bigshades is offline   Reply With Quote
Old 12-28-2008, 08:57 AM   #29
For brushless
Old 12-28-2008, 02:25 PM   #30
Impulse_racer's Avatar
Why do you need a motor dyno/checker for a BL motor? I maybe wrong but I thought all you can do to a BL motor is adjust the timing, the effects of which can be seen immediately on the track. When I was running brushed stock I would buy 2 or 3 motors, tune them, and throw them on a TurboDyno to see which one was best. Some guys bought more than that because there were big inconsistancies from motor to motor. But I thought BL was supposed to eliminate this madness as well as weekly maintenance, comm lathes, a box full of brushes/armatures, inconsistances between motors, and best of all, cheating. The "black art" of brushed motor tuning was supposed to be a thing of the past as well as "leveling" the playing field. But this thread maybe saying that things are headed back in the direction, buying several motors to find the "best" one. Except the motors are $80 instead of $40 and laptops are replacing comm lathes and brushes. I don't know about the rest of you but this is not what I bought into BL for.
Sorry for the rant.
Xray T3 EU
KO Propo Helios
Tekin RS Pro/LRP X-12/Venom LiPo
Hudy
Litemodz CVS
Impulse_racer is offline   Reply With Quote
Idea to Use brushed motor dyno for brushless JevUK Electric On-Road 45 04-06-2009 10:52 AM
Brushes, Fantom Dyno, Brush Maste racer34v R/C Items: For Sale/Trade 2 07-17-2007 04:42 AM
Thunder Zapper Fantom Dyno Fantom Lathe Spring dyno Brush Butcher Fussy full monte HenBeav R/C Items: For Sale/Trade 8 12-06-2006 11:38 AM
Cobra Lathe, Break-in Stand, Indi Dyno, Brush Cutter RED-LINE M03 R/C Items: For Sale/Trade 14 10-26-2006 04:59 AM
!!! Everything For Sale !!! Dyno, Charger, Lathes, Truer, Air Brush, Compressor RCSale05 R/C Items: For Sale/Trade 19 07-22-2005 08:36 PM
