Old 09-24-2003, 07:03 PM   #121
JoshR 85's Avatar
HeY!!!
well while you're geussing that could hurt you and mayb blow motor or something and then yeah you're just gonna waist more time wrenching on car then you should if you just get the correct gearing right away by calculating it unless you don't know how to do that exactly for your car, because all cars are different.
JoshR 85 is offline   Reply With Quote
Old 09-24-2003, 08:10 PM   #122
Well I have done both "If the motor is hot and how does it sound down the straight". I have also done the rollout thing. Depends on the race and the track. I know I have seen people blow motors because they over geared to what "sounds" or "feels" good down the straight. I have also seen people out of the race pace because they followed someone's roll out. Each motor has different characteristics; especially from one manufacturer to another. So you might say you have to do one or the other and sometimes both. Just my 2 cents.
Isaac is offline   Reply With Quote
Old 09-25-2003, 06:45 AM   #123
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I usually only refer to rollout when I am running foam tires. When the tire gets smaller I may have to adjust my gearing. However with rubber tires I could care less about rollout.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-25-2003, 04:15 PM   #124
That's what I do Kraig.
Old 10-21-2003, 07:54 PM   #125
Scrad's Avatar
Trader Rating: 15 (100%+)
I was thinking about getting into a 19t class, but I was wondering what motors would be the best to try. I see the Reedy quad and the Epic quad. What else would be good.
Scrad is offline   Reply With Quote
Old 10-21-2003, 08:06 PM   #126
Bobby Z's Avatar
Does anyone have any tuning recommendations for a Chameleon 2 for 1/12th scale? Interested in a good brush/spring combo along with rollout recommendations and what amp draw I should be going for when running the motor at 5Volts?
Bob
Bobby Z is offline   Reply With Quote
Old 10-21-2003, 08:09 PM   #127
fast-ho-cars's Avatar
you might want to ask SPEEDXL in the 12th forum, they run them in their Florida club racing
fast-ho-cars is offline   Reply With Quote
Old 10-21-2003, 08:16 PM   #128
popsracer's Avatar
Default Orion Element
Guys;
Just ran an Orion Element for the first time last Sunday.
Was quite different from the Monster Stock that I'm used to running.
Gear it like you would a P2K and maybe 1 tooth higher yet. Plenty of power and speed with the correct gearing.
popsracer is offline   Reply With Quote
Old 11-04-2003, 10:59 AM   #129
Scrad's Avatar
Is anyone here running the reedy quad mag? If so would you please share your brush and spring combos, so I can have a jumping off point for tuning. Thanks.
Old 11-04-2003, 11:29 AM   #130
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I was just going to post that same question. I have a race in two weeks and that's the handout motor. Haven't had a chance to run one yet.
Jon Kerr is offline   Reply With Quote
Old 11-04-2003, 09:14 PM   #131
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
also regarding the reedy quad. i just picked one up yesterday and will try it out at the track tomorrow. Does anyone have experience with this motor and how to gear it? Considering same track layout and conditions, should this motor be geared up or down from lets say a Chameleon 2? Just need a starting point. Thanks!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 11-04-2003, 09:25 PM   #132
Matt Howard's Avatar
From what I've heard from other people running them is that the Reedy Quad mag 19T needs to be geared up a tooth or two compared to a C1/C2 type motor. I tried a C2 and a Kisbey D5 based 19T and the Kisbey one was faster all over the track, more torque and more RPM. I would recommend one for anyone looking for a fast 19T motor.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-04-2003, 10:19 PM   #133
akrcracer's Avatar
I run a Quad 19 in my 12th 4 cell class. All I did is tweak + spring a little more tension with using stock brushes. My car was totally fast. period! I was pulling guys down the straight running 9s... They were all dumping at end of racing. Wear I still had same speed I started with.
akrcracer is offline   Reply With Quote
Old 11-05-2003, 08:57 AM   #134
hyperformance's Avatar
Default reedy quad
i've been running my reedy with 767's, and factory springs & timing with a 30mm roll-out, the motor will fly with higher roll-out but the comm overheats. i have heard using red trinity springs works well on smaller tracks. so far in our 19t class the reedys and chamelons are doing well.
hyperformance is offline   Reply With Quote
Old 11-08-2003, 08:38 AM   #135
Super Steve's Avatar
Send a message via AIM to Super Steve
So what final ratio should I run on a belt drive touring car with a Chameleon 1
I am running 8.7 and seems way to torquey (diff slips even thought it's tight under hard accel)
My balls could have worn out but i just changed them and switched the diff rings around last race.
Since it is a tight track, should I leave it or lower the final to around 7.5? (or even lower?)
Let me know!
I will leave for the track at 1pm so please post!!!
Super Steve is offline   Reply With Quote
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 02:20 PM
Brushless Motor & ESC Forum stonedgti Micro and Mini Scales 28 09-06-2006 10:07 PM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
MODIFIED motor forum Alvin Electric On-Road 104 12-06-2002 12:32 PM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
