Old 03-18-2007, 12:57 AM   #511
EddieO's Avatar
R/C Tech Charter Subscriber
To answer the question regarding magnet zappers effecting a motor.....yes, that can happen.
Anyone that ran a Reedy MVP knew it was a horrid stock motor. The reason is really sucked bad, was because the magnets in it were the really good FB-9 series magnets, which is used in most of the modifieds. The problem with them though was they were SO powerful that the light weight arm Reedy had designed simply didn't spool up worth a crap......so, to reduce the magnetic field, we did things like using a torch the can past the magnet's temp range, thus reducing their power....which allowed the arm to spin up better. I used this trick on some motors at paved nats in 2004 in portland, though I hid it from everyone there by doing it up in my room.....
How this applies to your motor is a little smaller in scale. Sometimes, the magnet just has a sweet spot with the arm and the rest of the motor. So, everything is working together.....and then you zap the can, the magnets get stronger, which limits the spool.....and the motor feels like it lost something. This is not always the case, but it can happen......run the motor a couple more times and often you will see the magnets lose some power and the motor is suddenly fast again.
Now, it could be a bunch of other things that did it....but, it can happen.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 03-18-2007, 05:14 PM   #512
Default CP19 gearing
Voodooph,
we run CP19T here in the UK (a finals) also in a BD with Infinity brushes.
outdoors the ratio is 5.53 and indoors it is 6.15.
We always run a complete days racing (3 quals and 2 finals without touching the motor.
All with WC SMC 4200 cells.
rehards
Don
donwhit is offline   Reply With Quote
Old 03-18-2007, 06:54 PM   #513
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by donwhit
Voodooph,
rehards
Don
does the comm turn puple on you guys with those gear ratios?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-18-2007, 06:59 PM   #514
VooDooPH,
no, they are a little darker than yours.
Do you run a fan? We run a twin fan (endbell and case) from Coolcan.
In general we found that the motor seems to like to be geared up.
regards
Don
Old 03-19-2007, 04:04 AM   #515
VooDooPH's Avatar
run with 1 fan on the endbell. the pic posted was from a previous practice day. it was on the succeeding practice day, noticed the comm turning purple and red but the brushes were fine and the can came in at about 152deg.
Old 03-19-2007, 10:21 AM   #516
AE 14year-old's Avatar
Trader Rating: 15 (100%+)
I was wondering what is faster a brushless"equivalent"19turn or a brushed 19turn for off-raod.thanx for your time
Zack Rogers...
Kyosho / Team Orion / Airtronics / Jconcetps / Amainhobbies.com / Protek Rc / BlackBeard Rc / Rcinsider.com
AE 14year-old is offline   Reply With Quote
Old 03-19-2007, 11:06 AM   #517
also in the motors are their 19 turns around the arm? Or do they do it some other way because I know they are called like by weird numbers and pionts!
Zack Rogers...
Old 03-19-2007, 01:39 PM   #518
DIALED's Avatar
Trader Rating: 92 (100%+)
Thanks for the ideas Eddie O
Acutually that (from a tech pov) answers a lot of questions/suppositions from a track-based, gut instinct pov.
I wonder if there is anyway to pinpoint the sweet spot to which you refer with a given motor...and then duplicate, accentuate it....?
Team Schumacher - Team Powers - EDS Specialized RC Tools - RCSpeedshop.net
DIALED is offline   Reply With Quote
Old 03-19-2007, 08:54 PM   #519
Please help with the posts above!
Zack Rogers...
Old 03-20-2007, 08:06 PM   #520
247
247's Avatar
Whats the difference from kd to the hemi kd?
247 is offline   Reply With Quote
Old 03-20-2007, 08:53 PM   #521
RaceAce701's Avatar
Trader Rating: 86 (99%+)
19 turns of wire around every segment on the armature
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 03-20-2007, 10:05 PM   #522
Big B's Avatar
I dont know if there even is a "brushless 19t" your best bet would be to go to the local track where you plan to race and talk to the people who race there, and you will find out what people are running for the 19t class. Faster isnt alway better, on a tight technical track you will want more torque what good is a high rpm motor is you dont have enough room to open it up
Big B is offline   Reply With Quote
Old 03-20-2007, 10:13 PM   #523
Big B's Avatar
If I'm not mistaken it is has to do with the wire gauge, but I could be wrong
Old 03-20-2007, 10:27 PM   #524
Trader Rating: 44 (100%+)
If u go to the EA thread and do a search on Ďhemií, uíll find a brief explanation.
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 03-24-2007, 11:51 PM   #525
247
247's Avatar
tryed ea theaded nothing.
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 02:20 PM
Brushless Motor & ESC Forum stonedgti Micro and Mini Scales 28 09-06-2006 10:07 PM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
MODIFIED motor forum Alvin Electric On-Road 104 12-06-2002 12:32 PM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
