Old 02-15-2007, 08:23 AM   #496
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
the diamond bit will get smoother, better cuts. the diamond bit will last a lot longer than a carbide bit. the carbide bit will give a few smooth cuts but wear out rather quickly compared to that of a diamnond bit.
-Zac
Z.Hallett is offline   Reply With Quote
Old 02-15-2007, 08:32 AM   #497
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
i bought one form integy for 65$ its there mod motor lathe. comes with carbide bit... works good though pretty compact.
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 02-15-2007, 09:10 AM   #498
pug 205 gti's Avatar
quality carbide steel will last ages if treated correctly.
remember amatures are butter soft copper!!!
although diamond edged cutter will give a better more shinny finish.it can chip much easier if mistreated.
my experience comes from cnc and not cutting little bits of copper on a poxy little laithe.
pingo where did you get the integy? thanks
pug 205 gti is offline   Reply With Quote
Old 02-15-2007, 09:20 AM   #499
pinggoy's Avatar
here is the link but
http://cgi.ebay.com/ws/eBayISAPI.dll...4192&rd=1&rd=1
they are integy ebay store..
TAMIYA TRF416X
Old 02-15-2007, 09:26 AM   #500
thankyou
Old 02-15-2007, 08:36 PM   #501
wallyedmonds's Avatar
Originally Posted by Dane
Could someone suggest a decently priced lathe? I run mostly mod motors.
Also, is a diamond but a necessary investment? Why?
Thanks,
Dane
a diamond bit is very necessary
iv had mine since cobra came out with there lathe.
i tried the carbide bit and it realy sucked.
wallyedmonds is offline   Reply With Quote
Old 02-15-2007, 11:04 PM   #502
Tek Nickal's Avatar
Default CP19T Money Motor
I was running my CP19T, and I ran it for 2 heats and a main. The motor felt strong through all 3 races, and I didn't cut the comm, although when I took the motor apart, the comm was in bad shape, purple and discolored. And during the main, the motor got really hot. My rollout is 31.58 on foam tires and 5.77 FDR with rubber. Using silver springs both terminals with infinity brushes.
Tek Nickal is offline   Reply With Quote
Old 03-07-2007, 11:22 AM   #503
I have two chemelon 2's with no springs or brushes installed. What spring combo is recommended for asphalt rubber?
Thanks for your help.
CheeerZ
Obsidian is offline   Reply With Quote
Old 03-07-2007, 06:08 PM   #504
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
had a similar problem but during practice (running rubber on asphalt). purple coms, but the brushes were fine and the can was at about 152-159*F.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-17-2007, 05:48 AM   #505
Default Advancing timing
I have heard that some people are advancing their fixed timing motors by twisting the stack.
Rumours are that this advances the timing by another 10 deg and is being hidden under the guise of "manufacturer tolerances"
I would assume that this is illegal but am interested in what this actually means as i thought that the stack (apart from the wire winding) was a complete unit so how would this be possible?
Sponsored by Team Wave Online
www.teamwaveonline.com
stuartb is offline   Reply With Quote
Old 03-17-2007, 06:05 AM   #506
part-time racer's Avatar
CheeerZ
I'd try purple / purple or purple / red to, + / -, and you can't go wrong with putnam green / blue. If you run it hard you will need to skim and re-brush everyother run.
Richard Clarke
EWS Event Organizer
CPD Racing ___MuchMore-UK___Awesomatix UK___OTM Racing
part-time racer is offline   Reply With Quote
Old 03-17-2007, 10:00 AM   #507
DIALED's Avatar
Trader Rating: 92 (100%+)
Has anyone ever found the performance of a Komomo
to just drop off---severely?
Like say, when new, it pulls 12 amps @ 2v
Then, without abuse, just normal racing, the most it pulls (w/a fresh cut and brushes) is 9v???
Can zapping have a negative effect on a good motor---if done correctly w/ a high quality zapper?
Thanks for any ideas, I'm really scratching my head on this one.
Team Schumacher - Team Powers - EDS Specialized RC Tools - RCSpeedshop.net
DIALED is offline   Reply With Quote
Old 03-17-2007, 10:12 AM   #508
Korey Harbke's Avatar
Typically I haven't seen anything like that happen unless the zapper did something weird. Magent zappers that are working properly should just resaturate the magnet to it's full capacity as far as I know.
Now... what could have happened is brush hood alignment might have shifted/changed. Also different batches of brushes draw more or less amps depending on how good the raw materials in the batch are. Also if the wire look of the windings look any darker than they were when new....
Try just re aligning the brush hoods... and maybe throw in a known good set of f brushes or 767's in there. The latest batch of 4499's is really good too.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-17-2007, 10:55 AM   #509
DIALED's Avatar
Thanks.
I'll re-check the allignment. But as far as the brush batches go...
Is color/performance the only way to distinguish good from bad?
Old 03-18-2007, 12:33 AM   #510
Not really... you're kinda screwed there. EA has given me different batches of brushes and they all look the same... but are totally night and day on the track.
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 02:20 PM
Brushless Motor & ESC Forum stonedgti Micro and Mini Scales 28 09-06-2006 10:07 PM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
MODIFIED motor forum Alvin Electric On-Road 104 12-06-2002 12:32 PM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
