Old 10-01-2006, 08:44 AM   #436
Originally Posted by dgullickson
Komodo and Chameleon 2 are, Atlas's are not.
are the chameleon 2 motors any good are they gd compared to the dystany motors
jordan
jordys jrxs is offline   Reply With Quote
Old 10-01-2006, 08:52 AM   #437
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
jordan
Yes they are good...
I like them for larger tracks that are flowing...
They are to the KD as a Roar Stock is to a CO27...
KD has better torque but the C2 has better Revs...
If I race on a smaller more technical track I would bust out the KD or the Reedy QM...If the track is flowing and larger than the C2 is put in.
Hope that helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-01-2006, 08:53 AM   #438
Trader Rating: 36 (100%+)
Originally Posted by John Tag
Hey Tim.. Komotos are great 19T motors. We have found gearing around 28mm roll out to be best to start. Vegas was a med to large track with both tech and flowing sections and we too geared 28mm there too. We have also found either F brushes with red/red combo to work well or XXX brushes with Purple+ and red - to work well also.. Hope this helps..
Thanks John, you rock...as always!
EVILGRAFX is offline   Reply With Quote
Old 10-01-2006, 09:47 AM   #439
Hope that helps,
-Shookie <><
ok thanx errmmmm well i dont know if you know my track but it is the coastal model car club track in ipswich (UK) http://homepage.ntlworld.com/barry.h/homepage.htm
the link above will go to a picture of the track i mean
jordan
Old 10-01-2006, 09:49 AM   #440
ShermanSim's Avatar
Default Racing is not for u!
Originally Posted by COREX
Which money motor best suits the RDX racing on aspalt track?
Hey Kotex,
Stop asking stupid questions? Like I said, it's not the motor, it's your stupid driving style.
try racing Matchbox, you might win some races with your classmates!
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
ShermanSim is offline   Reply With Quote
Old 10-02-2006, 06:58 AM   #441
Glowster21's Avatar
Trader Rating: 116 (100%+)
Having a brain cramp....What are the rollouts for the Blue Can Atlas and the Reedy Quad Mag? Been so long since I've played with either of these and I can't find my notes.
Thanks!
Glowster21 is offline   Reply With Quote
Old 10-02-2006, 11:43 AM   #442
also ive just actually looked at my dystany and it looks shot so i shall get a knew motor
WHAT MOTOR IS THE BEST???????
i need speed lol
lots of it
jordan
ipswich track for a 19T gibbing( ithink its called) layout i used a V2 peak with a 5.27 fdr which was ok
then i changed to my TSUK Atlas with a 5.5 fdr and it was perfect.
also Paul B and i think Chris C was using ratios aout the same.
for motor jord, i would go for 1 that needs the least amount doing to it so V2 again, plenty of torque for the ipswich hills
also where was you yesterday then?
darren
sharpie is offline   Reply With Quote
Old 10-02-2006, 01:02 PM   #443
sorry darren didnt realize you posted bak lol
jordan
Old 10-05-2006, 09:41 AM   #444
Hi guys
I have a problem with my 19T motor. Its a Fantom, I just got it and hooked it up to my charger to brake in the brushes.
I hade the charger set at 2V and a run time of 1min. I conected the motor and push start, the motor would rev up for 3-10 sek and then shut down.
Motor short circuit or diss conected would show in the display.
I took the motor apart to check it out. The bearings are fine, the brushes(F) got a nice and even wear, the comm locked nice and the axel play was exact.
In short term... I couldent find anything wrong.
Anybody got a nice tip for me what to look for or what to do?
All help are deeply appreciated!
/Fredde
Heimdal is offline   Reply With Quote
Old 10-05-2006, 09:45 AM   #445
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Hiemdal,
What charger are you using?
If the motor pulls to many amps it will shut the charger down.
later
Dayton
1armed1 is offline   Reply With Quote
Old 10-05-2006, 10:45 AM   #446
Hi 1armed1
Im using the Orion avatage charger. The motor pulls around 9-10 amps, mabye thats why.... My power plant can only deliver 10amps.
The funny thing is that it shows motor short circuit in the display.
Thanks man. Will check that out.
Old 10-05-2006, 11:02 AM   #447
Just tryed all my outher motors(all mod) and they ran great in the charger, but they only pull 3-6 amps. So it must be because of the amp draw in the 19T motor.
Thanks for the tip 1armed1.
I may have a stupid question but im new to the 19T motors. Is it normal for a 19T motor to pull over 10amps at 2V?
Must say that the Fantom seems to be a good motor nevertheless. Super nice comm and brush wear. The brushes hoods didnt even need a reangling.
Cant wait to go racing this weekend.
Old 10-05-2006, 11:03 AM   #448
1armed1's Avatar
I have the orion also, anything much over 10 amps and it will shut down.
later
Dayton
Old 10-05-2006, 11:42 AM   #449
[QUOTE=Heimdal]Just tryed all my outher motors(all mod) and they ran great in the charger, but they only pull 3-6 amps. So it must be because of the amp draw in the 19T motor.
Heimdal
Most of my 19T motors pull 11 plus amps at 2 volts,I use a GFX to check them on, it can handle 20 amps in motor run mode,a really good 19T can pull as much as 13.5 amps of which I have ever had only one do.10 amps isn't that good of a motor.
Hyper1 is offline   Reply With Quote
Old 11-18-2006, 08:35 AM   #450
Do anyone know the maximum "safe" temperature the Dynasty Laydown can run at? I want to know this so I know how to gear it. Is 65C too hot?
trf_racer is offline   Reply With Quote
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 02:20 PM
Brushless Motor & ESC Forum stonedgti Micro and Mini Scales 28 09-06-2006 10:07 PM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
MODIFIED motor forum Alvin Electric On-Road 104 12-06-2002 12:32 PM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
