Old 02-08-2006, 12:06 PM   #361
Ill Factor's Avatar
Originally Posted by dgullickson
The 3 I mentioned are the most reputable with locked timing. Also keep notice when people on here to tell you to buy a certain brand they are usually a sponsored driver doing thier job. I told you 3 can designs to go with, whether you buy from me or the next guy doesnt matter, it matters you get a can design that will work for you.. Good luck.
I purchased a Z-Zone. I was interested in feed back form you on how we should gear these,in general of course. I run sedan on med grip asphalt with CS27's
Ratio I believe 1:7
Ill Factor is offline   Reply With Quote
Old 02-10-2006, 10:15 AM   #362
TMHippo's Avatar
Default Element 19T Spec
I was wonder if the team Orion 19T Spec motor is any good?
Also have any of you out there run a 19T with V2 Endbell yet? How do the perform? Are they worth it or not? What brushes are reccommendend for the V2 versions?
Thanks Rodney
TMHippo is offline   Reply With Quote
Old 02-10-2006, 11:06 AM   #363
jw92656's Avatar
Smile
I tried the V2 conversion awhile back and did not like it. Installing the brushes, and the springs in the brush hoods was kind of a pain. If you want a fast 19T. Checkpoints new one is due out in a week, or two.
jw92656 is offline   Reply With Quote
Old 02-10-2006, 11:10 AM   #364
tom235's Avatar
i run the elemant v2 and it is pretty good took me a little bit to get it fast
i run sprint brushes with hard springs both +and - and in my car i gear it to the moon fdr 5.8 to 5.50 depending on track and batterys
Thanks Rodney
tom235 is offline   Reply With Quote
Old 02-10-2006, 01:59 PM   #365
TMHippo's Avatar
tom235
With that set up how long does the comm and brushes last?
Rodney
Old 02-10-2006, 02:00 PM   #366
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
tom235
Rodney
Comm will last longer with his setup vs. a softer setup with brush bounce.
dgullickson is offline   Reply With Quote
Old 02-10-2006, 04:23 PM   #367
Trader Rating: 47 (100%+)
ran the new integy in my B4 on tuesday was impressed fast as a C2 same gearing
josh short is offline   Reply With Quote
Old 02-10-2006, 04:27 PM   #368
Laydown version or angled?
Old 02-10-2006, 04:52 PM   #369
Korey Harbke's Avatar
I've run the laydown version and was able to gear up a tooth or two 64P from a C2.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-10-2006, 05:49 PM   #370
tom235's Avatar
tom235
Rodney
it last pretty long depending on your gearing i cut mine about every other race week just to keep it fresh and rebreak in the brushes.
i got about 20-25 runs out of it before i replaced the brushes
(great comm wear)
Old 02-10-2006, 06:33 PM   #371
Glowster21's Avatar
Trader Rating: 116 (100%+)
-Korey
Korey,
Did you run it on foam? What was your rollout? Love the Atlas and Quad Mag but am dying to try the new Integy..
Glowster21 is offline   Reply With Quote
Old 02-10-2006, 06:36 PM   #372
sorry laydown version did no tunning to it right out of the package
Old 02-10-2006, 07:38 PM   #373
raptor 700's Avatar
On the element 19t spec how small does the comm have to be before replacing the armture
raptor 700 is offline   Reply With Quote
Old 02-10-2006, 07:50 PM   #374
raptor 700's Avatar
which blueprinted verse from team br00d better the atlas 19t or the atlas evo super stock 19t spec? thanks
Old 02-10-2006, 10:12 PM   #375
Both ones from Team BrOOd are just as fast but they do require different gearing. I would say get the Atlas based blue can for tight carpet tracks, torque crazy and run cool. Basically nothing else is even close or worth trying out there.
RickyIS300 is offline   Reply With Quote
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 02:20 PM
Brushless Motor & ESC Forum stonedgti Micro and Mini Scales 28 09-06-2006 10:07 PM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
MODIFIED motor forum Alvin Electric On-Road 104 12-06-2002 12:32 PM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
