19T Motor Forum
Old 05-18-2005, 10:15 AM
  #301
ts
ts's Avatar
Eli: YGPM
ts is offline
Old 05-18-2005, 03:07 PM
  #302
dgullickson's Avatar
Trader Rating: 45 (96%+)
Go with an Axiom C2 based 19t.
dgullickson is offline
Old 05-19-2005, 08:50 AM
  #303
Originally posted by loosenut
Site where it's available? Thx.
You order is shipping today.
Old 05-20-2005, 09:04 AM
  #304
Trader Rating: 17 (100%+)
have anyone tried cobalt 19t??? is this motor good?
cheers
EngTat is offline
Old 05-29-2005, 03:29 AM
  #305
NOZ69's Avatar
I`m after a ball park 19T gear ratio for my TC3.
I`m going from a Tamiya Sport Tuned (Black Can) to 19T so i would like a starting point to fine tune from.
Cheers
NOZ69 is offline
Old 05-29-2005, 12:55 PM
  #306
I`m going from a Tamiya Sport Turned (Black Can) to 19T so i would like a starting point to fine tune from.
Cheers
Well what motor will you be running? The reedy quad mag you can run at ratio's as low as 5.2 depending on the track, a chameleon 2 perhaps geared much closer to 6.0, a Peak Dynasty in between.
MartynD is offline
Old 05-30-2005, 02:39 AM
  #307
NOZ69's Avatar
it`s just a VERY cheap Venom "Fireball" 19T double..ATM , I was given it so i could have a run in 19T next meet to see if i like it.
I was thinking of around 6.0-6.5...??
Does anyone use/recommend "Nosram" motors..? My LHS is getting some in.
Cheers
NOZ69 is offline
Old 05-30-2005, 08:51 AM
  #308
Wich Nosram motors are they getting in?
As far as i know, the Nosram eXtreme modified is exactly the same as the Reedy Kr. Both LRP and Nosram use Reedy motors as a base for their motors.
I actually own two Nosram eXtreme motors, both 12x2, and from my experience i can't recomend them. They're just toast after 1 run if you are 1 tooth off perfect gearing.
Erlend is offline
Old 05-30-2005, 09:57 PM
  #309
NOZ69's Avatar
That i couldn`t tell you ATM...one of our local club members is just starting up a RC shop as his 2nd business, mainly to help out local ppl.
So i`l just have to wait & see.
From your experience they (Nosram) sound like the Venom Fireball range. If you don`t get your gearing spot-on they go up in smoke.
Cheers
NOZ69 is offline
Old 11-22-2005, 06:46 PM
  #310
can anyone give me a good setup for a C2 with f-brushes, like what cuts or holes and what springs to run, for a foam sedan?
SPC Racer is offline
Old 12-04-2005, 04:25 PM
  #311
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Of all my 19t motors. My Trinity Cham.2 is the fastest. Then my Integy Altas, my Trinity D5 19t , last but not least my Venom 19t (p.o.s.)
Strange my D5 is not the fastest even though it's handwound and all that. Out the box it was a pig, but then I put the P94 brushes and it made it a lil' betta. The Cham is a rocket with green-/red+ springs, trinity angled serr. brushes.
I love the dyno feature on my APS charger!
Dasupacat1 is offline
Old 12-04-2005, 04:58 PM
  #312
Brian McGreevy's Avatar
SPC,
Run Full-face F's with Either Purple (+), Red (-), or Red/Red with the positive spring bent to give a little more tension. This setup has worked great for me.
Brian McGreevy is offline
Old 12-05-2005, 12:28 PM
  #313
Dasupcat1- how many degrees of timing on the d519t?
Charles is offline
Old 12-05-2005, 12:33 PM
  #314
different 19t like different gearing. I would be surprised if the d5 19t at 36 degrees and proper gearing was a pig. Has this motor been overheated?
Brushhoods aligned? inspected for abnormalities?
Charles is offline
  #315
Default How much brake
Ran at IRP last night at the Hurricane cup only time ran 19t and learned a lot, one question I have is how much brake does everyone dial into the speed control? I have a 3PK radio and added brake quickly using it and it seemed to help. I have a GT-7 speedo and what program do others use?
I have it set up for Oval for running TC stock and 19t.
Thanks....
Mike T
bigdog xxx-s is offline
