Old 04-30-2005, 02:09 PM   #271
tom235's Avatar
but when i change springs on my stock motors i can see the differance and in brush compound.
tom235 is offline   Reply With Quote
Old 04-30-2005, 03:23 PM   #272
ChadCapece's Avatar
The difference you are seeing might be reltated to the frictional forces created by the springs. Only when power is applied do the spring tension matter.
ChadCapece is offline   Reply With Quote
Old 04-30-2005, 05:07 PM   #273
You really need a true dyno (turbodyno) to tune motors with,motor checkers are only good for checking rpms and amp draw,after you've tuned it with a dyno.
Hyper1 is offline   Reply With Quote
Old 05-02-2005, 12:05 PM   #274
tom235's Avatar
thanks for all you help
Old 05-02-2005, 04:22 PM   #275
Qwiglee's Avatar
I dunno why people are so negative about motor dynos and call them "motor checkers" like they are some kind of inferior device. I use the Orion checker and I use the slip on fan blade from Racer's Edge to put load on the motor. It makes a huge difference in the readings I get.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 05-02-2005, 06:21 PM   #276
We're not negative about the checkers they do serve a purpose but it's just not the same as a true dyno.I use a MM motor master myself to keep track of my motors at the track it is small and convenient and serve's it's purpose,but I tune my motors on a turbo dyno,it's much more sensitive to small changes such as springs and brushes,as long as you have a base reading on your checker you should be alright.I have seen some fast guys use motor checkers to tune with,so it's all good as long as you know you're readings
Old 05-03-2005, 01:10 PM   #277
tom235's Avatar
i think there a great tuning tool.
Old 05-03-2005, 02:33 PM   #278
I just pulled my motor master checker out and went through all my motors just to see how accurate it was and the best I can tell it does in fact tell me which motors are duds and which motors are good,so it will allow me to sort good from bad,But as far as tuning goes I haven't tried that yet.The Much More motor master is probably the best checker out there,it has a good assortment of features that allow you to do some minor tuning.
Old 05-03-2005, 08:34 PM   #279
ChadCapece's Avatar
I have to agree with Hyper on this one. I motor checker can weed out the bad motors and check for a motors "freeness" of rotation in the can, but they will not be enough to tune motors off of. It can be done, but the checker will not give you the precision that a TurboDyno or Fantom can.
BTW Hyper1, have we met before? Do you race at Augusta, CSS, TFB, GooseCreek, or somewhere even further away?
Old 05-05-2005, 05:13 PM   #280
edseb's Avatar
O kay, I have some Reedy Quad mag 19t and Fantom Blue label 19t. I always thought the Fantoms were much faster and they showed that on my dyno. I figured that Fantom must really know something, till I stopped and really took a look. I must have brain farted, cause it was not based on a Reedy Quad, but what? I went to Faantom's site to try to ge to the source of what this motor is based on. Does anyone know, one guess was a chameleon, but not sure. Help, I love the motors, but it looks like Fantom doesn't make those anymore and I'd like to look into other aftermarket companies tweaking on this base motor.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-05-2005, 09:26 PM   #281
edseb's Avatar
BTW, the blue label Fantom has a copper endbell.
Carl Hyndman
Old 05-05-2005, 09:59 PM   #282
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
They were offering a Chameleon 2 Based. We have them in stock if you arte looking for anymore and yes they rip!
dgullickson is offline   Reply With Quote
Old 05-05-2005, 11:37 PM   #283
Default ITS BITTER
what up carl? any chance on getting some DC gear? throw me a bone dude j/k just keeping it real
lickrim is offline   Reply With Quote
Old 05-07-2005, 01:33 PM   #284
Anybody running one of these ?
Andyg01 is offline   Reply With Quote
Old 05-08-2005, 04:04 AM   #285
syndr0me's Avatar
Trader Rating: 32 (100%+)
What's a reasonable starting rollout for a Reedy Quad-Mag? I'm going to be running outdoor on pretty open asphalt, using a spool up front.
syndr0me is offline   Reply With Quote
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 02:20 PM
Brushless Motor & ESC Forum stonedgti Micro and Mini Scales 28 09-06-2006 10:07 PM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
MODIFIED motor forum Alvin Electric On-Road 104 12-06-2002 12:32 PM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
