Old 01-30-2005, 08:02 PM   #211
ChadCapece's Avatar
Originally posted by Bluey_74
Guys what do you think about buying a 19t (say a rchamelion) or buying something like the Paradigm version?
If price is not option, is it worth the trouble?
looking for suggestions as im starting to race 19t this season cheers.
The Paradigm or Putnam Chameleons should be really fast. The fastest will be a Kisbey or KC Racing adjustable timing motor. My KC motor is way better than my C2, but new they can cost up to $95. If money is "really" no option, then buy a dyno and get several adjustable timing motors.
ChadCapece is offline   Reply With Quote
Old 01-30-2005, 08:04 PM   #212
i want to try to push my team orion element for i little higher mph so i want to go from my 24/72 combo to a 25t pinnion this is pretty safe right? my motor doesent get to hot now so just as long as a keep my eye on the temps i should be good right?
kh15 is offline   Reply With Quote
Old 01-30-2005, 08:04 PM   #213
ChadCapece's Avatar
KC made me a 19 turn motor and it has a D6 can and endbell. Stand-up brush hoods. And a handwound armature.
Old 01-30-2005, 08:21 PM   #214
kh15
I put a 19T in my TC4 for the first time tonight (a used C2 I picked up, fresh cut, new 767 brushes) and with a 28/72 combo it was coming off the track warm.
I don't know exactly what I should be running with that motor, but the 28 was recommended by the guys at the track as a starting point. I might go down a tooth or 2 and see how it works, but its not the car or the gearing slowing me down.. its my driving +)
MartynD is offline   Reply With Quote
Old 01-30-2005, 09:16 PM   #215
Default KC
Nit familiar with the KC motors, can you give me a web site or any thing else? ( im in australia)
Cheers
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 01-30-2005, 10:42 PM   #216
Regional Moderator
kumpol's Avatar
Originally posted by D_Ames
Anybody tried the Peak dynasty 19T with the V2 endbell?? What do you think of this motor?
I've used it for 2 weeks now. I have endbell set 36degree timing.
It's a little less punch than my EA C2 (Chameleon2)....but no need to cut the comm. It's good for club races. But I think if you want to use it in a big race....C2 with F-Brushes.
kumpol is offline   Reply With Quote
Old 01-30-2005, 11:58 PM   #217
Default Dynasty.
Using the Dynasty with out the Vs
2 end bell.
Its pretty good, but i havent tried it with. From what i know, Its only available un Europe with the V2.
Or you could just add it your self!!
have really found the perfect brush, but for now im using the peak 2221.
Old 01-31-2005, 07:19 AM   #218
Thumbs up
I personally have had great success with the C1 / C2 motors ... much more then the Quad. Running 767 brushes pos(+) and neg(-), purple on both with a slight tweak on the neg spring (less tension). Tried a bunch of combinations and found that the above was the most efficient .... running on a Turbo35 the amps weren't too high 9.5(+/-), but on the track the motor's fly (the best dyno). I do a couple other things to the motor but that's my secret -
As for the Dynasty, a few guys at the track are running this motor since it's pretty cheap at our track compared to the cost of the other 19T motors. The non V-bell seems to be a little better with regards to speed, while the V2 is more efficient with regards to brush wear. A couple of the fast-guys run the stock springs (tweaked to their liking), so other then 767 brushes - no idea what springs to start with. I'm gonna try green(+) red(-) as a base-line and see where to go from their.
duckman996 is offline   Reply With Quote
Old 01-31-2005, 07:30 AM   #219
howard hudson's Avatar
R/C Tech Charter Subscriber
I just ran the new dynasty with the v2 . It was ok but did lag a little. had to run a 5.4 final to get some skoot out of it.
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 01-31-2005, 02:50 PM   #220
Some a couple of pages ago was talking about Kisby and KC motors. Im familiar with the Kisby's (cos they have just become localy available her in Australia)
but im not at all familiar with KC.
can anuone shed any light on who/what they are?
Old 01-31-2005, 04:42 PM   #221
http://www.kc-racing.com/
Hyper1 is offline   Reply With Quote
Old 01-31-2005, 05:18 PM   #222
Default .
Thanks HYPER1
Old 03-19-2005, 06:11 PM   #223
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Hey guys,
I've encountered some problems with my Reedy 19t Quad Mag's lately. The performance has taken a downhill and I'm not happy with them. I'm currently using Copper springs and 767's all around. I've done a hole in the both brushes with a #42 drill bit 3/32 deep. I even tried slotting them. My numbers according to a Pulsar Competition 2 include 2.0 V @ 6ish A. I'm aware that the no load amp draw almost means nothing but I wanted to see some figures. On the track, the car isn't fast compared to others using either Chameleons or Reedy QM's. I'm using a TC4. Spur 72 Pinion 28 Internal Ratio 2.5. That gives me a gear ratio of 6.43 and a rollout of 27.37 (using 56mm foam tires). Now about the brush hoods, I have them aligned so that wear the wear mark is in the center of a flat brush. Hoods are not aligned directly across from eachother. Motors are about 2-4 months old. I'm unaware of the comm sizes but they been cut on the lathe about 10 times. (don't know if that helps). Motors were never abused or overheated.
I think I got all the information need. If I forgot something please tell me.
Thanks for the help.
Paul
Paul_TC4 is offline   Reply With Quote
Old 03-19-2005, 10:27 PM   #224
Aligning with flat brushes may not be the way to go, with the correct shaped brushes they may shift differently, next time you do check alignment try some non flat brushes. Not sure but I may have read somewhere that aligning straight across and permitting the brush shift to slightly retard the timing isn't a bad idea for the QM as well.
I believe the minimum size of the comm on the QM is .300, mebbe they are just getting too small.
Old 03-20-2005, 12:31 AM   #225
R40Victim's Avatar
I would suggest trying new armatures, 10 times sounds a bit excessive...
R40Victim is offline   Reply With Quote
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 02:20 PM
Brushless Motor & ESC Forum stonedgti Micro and Mini Scales 28 09-06-2006 10:07 PM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
MODIFIED motor forum Alvin Electric On-Road 104 12-06-2002 12:32 PM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
