Old 07-04-2008, 04:45 PM   #1
academygaz's Avatar
Default Dead Orion 4800 LiPo
Came to race this evening, put my LiPo onto charge and it wouldn't register it.
Its an early Orion 4800 LiPo, I got it secondhand towards the end of 2006 and I think its passed the 700 cycle mark. Its not been balanced before, but its never been near the 6v threshold.
The pack isn't swelled at all, and it was perfect the last time I used it (it even won the A-main at my track), it was stored in the car (but not plugged in) until I came to charge it tonight, but for whatever reason its reading 0.0v across the pack - I haven't got a multimeter to check over each terminal and balance port.
Could it have an internal short or something? How safe is it to open it up and look for a broken connection? And does anyone have pics from inside the pack?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 07-04-2008, 04:48 PM   #2
Rcbasher06's Avatar
Send a message via AIM to Rcbasher06
i know it might sound stupid but check all your wires on the charger and your bullet connectors.
Losi XXXT-CR
GTB/Hacker 13.5
Orion 3600
Losi 8T
LIL JON
Rcbasher06 is offline   Reply With Quote
Old 07-04-2008, 04:51 PM   #3
academygaz's Avatar
Yep, first thing I tried. Also put the pack on a different charger and it didn't read it either, so its definitely the pack.
Old 07-04-2008, 04:54 PM   #4
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
I had a simular thing happen to a pack I have. A fellow racer told me to charge it in regular (NiMh) mode for 5 minutes to get voltage in it and then try it again in Lipo mode. Figuring I had noting to loose I tried it and it worked and the pack ran very strong for me that night.
follow me @RC3grafix on Instagram for pictures of my paint work.
PaintingRoly is offline   Reply With Quote
Old 07-04-2008, 05:11 PM   #5
Rcbasher06's Avatar
i would never reccomend that. i dont think there has been a single case of an orion combusting, but DO NOT CHARGE IT AS ANYTHING OTHER THAN LI-PO
the best thing for you to do is test the battery with a voltmeter, if it is below 6.0v dispose of the pack properly.
Losi XXXT-CR
GTB/Hacker 13.5
Orion 3600
Losi 8T
LIL JON
Old 07-04-2008, 07:54 PM   #6
Drifting101's Avatar
If you have nothing to lose why not?? i would put it in a lipo sack or two and a screen between it and the charger and charge to outside on nimh
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 07-04-2008, 09:12 PM   #7
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
I have seen many times the connectors in the pack come loose and need to be resoldered
pink_sleeve is offline   Reply With Quote
Old 07-04-2008, 09:13 PM   #8
Trader Rating: 38 (100%+)
Sounds like you shorted it out and blew the internal fuse.
or8ital is offline   Reply With Quote
Old 07-04-2008, 09:22 PM   #9
dbmartin's Avatar
I had a similar problem with my ice charger and a lipo pack, It kept stating short circuit, which i found out meant voltage was too low, I plugged it into my speedo and ran the car on the table for about 30 secs on and off the throttle, hooked it back up to the charger and away it charged.
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 07-04-2008, 09:40 PM   #10
chris moore's Avatar
Trader Rating: 88 (99%+)
I just had this happen to my 3200 pack, I called Orion and thay suggested I send it to them and thay will check the internal connections and deterimine if the pack can be fixed or not.
chris moore is offline   Reply With Quote
Old 07-06-2008, 05:25 AM   #11
jarkkom's Avatar
Send a message via MSN to jarkkom
Maybe it is just sometimes time to retire? Or do you want it to go 7000?
www.eurorc.com/?ad=jm
jarkkom is offline   Reply With Quote
Spektrum SR3000 RX, Orion 4800 Lipo, Orion 13.5 BL Jake S R/C Items: For Sale/Trade 40 07-06-2008 06:47 PM
orion 4800 lipo Valentin.H R/C Items: For Sale/Trade 0 03-30-2008 12:43 PM
WTB Orion 4800 Lipo ollie 45 R/C Items: Wanted to Buy 1 01-24-2008 07:17 PM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
4800 LiPo Peak Racing, 2 packs like new (Orion 4800) ALJR R/C Items: For Sale/Trade 14 01-09-2007 09:37 PM
