Old 07-02-2008, 06:41 PM   #1
Send a message via AIM to playboy Send a message via Skype™ to playboy
Questions?? pinion gear option????
i am going to get a tc5r rubber tyer touring car kit and i want to know what pinion gear would be a good choice for a 3.5r novak BL system
playboy is offline   Reply With Quote
Old 07-02-2008, 08:56 PM   #2
Nik
Nik's Avatar
What arent you gonna get? Sheesh dude!
I can ride my bike with no handlebars.
Nik is offline   Reply With Quote
Old 07-03-2008, 12:23 AM   #3
what do you mean?????
a team associated TC5R with a team novak 3.5r BL system
Old 07-03-2008, 01:57 PM   #4
Catalyst's Avatar
I would recommend not using the kit 48P spur and getting a 64P spur and pinion set. I don't run mod so you will have to determine your FDR requirements for your track based the Novak gear chart found here will point you in the right direction for a starting point which looks like 10.5. With a 100/19 you will have a good starting point.
I recommend 64P because you will find that fitting large 48P pinion and spurs is limited space wise on this platform.
Catalyst is offline   Reply With Quote
Help super gear and pinion gear jojo RRR Electric On-Road 0 06-18-2007 07:37 PM
Would switching from a 19t pinion gear to a 21t pinion make a big difference ? thahookup Rookie Zone 5 05-19-2006 01:09 PM
what pinion gear should I run? duckbutter Electric On-Road 4 02-22-2006 11:33 PM
Mtx-2 pinion gear Johnnytc3 R/C Items: Wanted to Buy 0 06-29-2004 05:32 PM
Pinion & Gear tkhoo Malaysian R/C Racers 4 08-30-2003 09:18 PM
