Old 08-16-2003, 10:04 PM   #1
Default Need help on reducing the left and right turn differences in shaft drive
Any suggestion on how to make the car turn both side as equally as possible.
Thanks.
Kamen Rider is offline   Reply With Quote
Old 08-16-2003, 10:08 PM   #2
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I just did this on my tc3, first center your servo and have neutral radio settings. Then put the horn on as straight as possible and tighten it on. then set your link for steering throw to the rack. The wheels should be straight after this step. Then try it out and adjust for torque steer oin the trims. U should also tweak your car for even weight transfer from side to side and front to back. Make sure camber and toe settings are even on both sides.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 08-16-2003, 10:20 PM   #3
Thanks for the suggestion.
Another thing, some people in the track mention using different droop setting on left and right side of the car. I don't understand why they use that to dial out the difference radius.
Any suggestion on this.
Old 08-16-2003, 10:21 PM   #4
Moderator
I never do that, it upsets the way the car feels from corner to corner, its not the same when u have different settings.
SMC Racing
Old 08-16-2003, 10:23 PM   #5
Thank you very much for all your help.
Old 08-16-2003, 10:25 PM   #6
Moderator
no problem
SMC Racing
Old 08-16-2003, 10:25 PM   #7
Another thing, how can I balance the car for front and rear.
I can use the tweak station to balace out left and right. But I don't know how to balance the car front and rear.
Old 08-17-2003, 05:02 AM   #8
Moderator
Use a set of weight scales. grams is the setting i use to get it pretty close to dead on. the tweak station is fine. Just set your ride height at 5 mm or what ever u choose first, then tweak from there
SMC Racing
Old 08-17-2003, 07:10 PM   #9
Belt Drive versus Shaft Drive SUNA Nitro On-Road 20 03-28-2006 09:04 PM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 05:23 PM
Belt drive or Shaft Drive tc3wood Electric On-Road 4 12-03-2004 07:57 AM
Shaft Drive or Belt Drive? dino.tw Nitro On-Road 109 05-25-2004 11:04 PM
KR Mod Motors vs 19 Turn Quad Mag Motor, differences? Cain Electric On-Road 4 04-28-2004 10:20 AM
