Old 06-26-2008, 09:43 PM   #1
Satish's Avatar
Default LIPO and 007
Does anyone know the max size lipo the 007 rubber car can fit without cutting or grinding anything away?
thanks in advance.
Satish is offline   Reply With Quote
Old 06-27-2008, 12:13 AM   #2
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
not sure for the US version, but for the Eu, you really can't fit any of the hardcase lipos unless you grind the spur gear bulk head or shim the topdeck. maybe the softpack lipos will fit without modifications tho.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 06-27-2008, 04:07 AM   #3
the smaller trakpower ones *might* fit, but the 4900 definitely will not without grinding the bulkheads
CPD Racing
chris_dono is offline   Reply With Quote
Old 06-27-2008, 03:12 PM   #4
Con
The SMC 4000 LiPo will fit with a very small amount of grinding to the spur gear bulkhead.
Con is offline   Reply With Quote
Old 06-28-2008, 07:13 AM   #5
Trader Rating: 16 (94%+)
If you want to be a little different, and do not want modifiy the bulkhead or battery in any way, then check out the MaxAmps 3000mah LiPo.
The MaxAmps 3000mah LiPo is only 12mm tall, or just less than 1/2" inch. The capacity may seem low, but 3000mah LiPo is more than enough capacity for 27T, 13.5, or 17.5 racing, but won't be the highest performing option.
kn7671 is offline   Reply With Quote
NIP Novak 5amp lipo regulator with volt monitor, NIP venom 1600mah lipo rx pack sharkman R/C Items: For Sale/Trade 1 06-10-2008 02:36 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
FS TrakPower 7.4V 4900MAH Hardshell Lipo,TrakPowerBalancer,TrinityReference 4500 Lipo ffpm46 R/C Items: For Sale/Trade 11 01-29-2008 06:11 PM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Lipo charger with power supply and 2 cell lipo pack fweemindan R/C Items: For Sale/Trade 3 01-03-2007 11:51 PM
