Old 06-26-2008, 12:42 PM   #1
Send a message via AIM to Deznuts05
Default Lipo Balance hook up
Hey,
Out of curiosity why do some manufactures use one method over the other?
what I mean is I currently own a pack that uses type A bracket that has three wires. whereas others use a single wire to do the balancing?
Are there any advantages of balancing with a multi wire vs a single wire?
Also, if I were to compair information from one to the other would I get different results due to one having multi wires vs a single wire?
thanks,
Rudy
"Power is nothing without control" Ryuken
Deznuts05 is offline   Reply With Quote
Old 06-26-2008, 04:10 PM   #2
Nexus Racing's Avatar
Actually, they both achieve the same thing. The two outside wires on the 3-wire balancing plug are just the main + and -. The single plug setup gets these readings from the power wires so it does not need 3 wires on the balancing plug.
You can actually use the single plug type on a pack that has three wires. The single plug just needs to be adapted to fit the middle wire on the balancing plug.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 06-26-2008, 04:28 PM   #3
thanks for the info!
lipo balance rjs_13203 Electric Off-Road 6 06-11-2008 10:10 AM
s it fine to hook up a 3s lipo to my lrp sphere esc? bosley Electric On-Road 3 04-25-2008 01:50 PM
To Balance or Not to Balance Lipo Packs while charging RED-LINE M03 Electric On-Road 14 10-24-2007 05:00 PM
LiPo Charge Balance / Non-balance bugnet Electric On-Road 2 09-12-2007 07:39 AM
To Balance or Not to Balance Lipo Packs while charging RED-LINE M03 Electric Off-Road 25 09-04-2007 02:22 PM
