Old 02-09-2009, 07:01 AM   #1426
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Steergod View Post
Hi all,
I just purchased an F103GT with a S2000 Bodyshell. I have no esc and batteries installed. As for motors, i have Mabuchi RS-540 and HPI R2 23T. I would like to enquire what are the items i need to buy best for the kit. I am in need of a good motor, esc and batteries. I have been playing nitro powered rc for awhile, so i am new to EP racing. Thanks all. You can PM me too. Thank you.
YGPM!
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 02-09-2009, 09:36 AM   #1427
padailey's Avatar
I just got my RM going a couple weeks ago and have gotten a couple practice runs in and the car is pretty good for the most part but I'm have trouble with a front end push off power and the car wandering at times. I think some turnbuckles and a different servo save will fix most of the wandering but I can't figure out the push.
So basically its a stock setup with the following changes.
F103GT TRF shock.. stock white spring... I think its a yellow dot.
Gold springs in the front
O-ring setup - I think its squished down pretty good but not sure how to measure that.
Stock silver springs on the damper pads.. fairly tight.
I've got the long top deck but not installed yet. Will that help?
It turns great on power but I just can't get it to turn off power. I normally have been gooping 1/3 to 1/2 on the front tires. I went to 3/4+ once and it traction rolled to start then wore off and I was back to the push. Any suggestions?
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 02-09-2009, 09:45 AM   #1428
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The top deck will help for sure. You could also try the carbon lower deck.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-09-2009, 03:49 PM   #1429
Hi all,
You could probably go for a cheap ESC to start with, that will take all the way to low mods.
If you want to go Brushless in the future, then go get Brushless ESC that can run brushed motors that you currently have.
The mabuchi would be a good motor to start with, then you can upgrade to the 23T if you can control the car and want more speed.
As for batts, get yourself 2 pack of Li-Pos... That would be sufficient.
Ben.C is offline   Reply With Quote
Old 02-09-2009, 07:08 PM   #1430
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
i hopped up mine, and i have spare parts galore. i have a whole 'nother chassis minus 3/4 of the motor mount, front steering arms plus misc parts.
if interested, pm me. otherwise it will be on ebay...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-10-2009, 12:28 AM   #1431
kavadni's Avatar
Has anybody seen a tuning guide for these things, or for pan cars (probably quite appropiate)
kevin
kavadni is offline   Reply With Quote
Old 02-10-2009, 05:28 AM   #1432
kevin
Check Vyger's posts. I know he's put together a starting point setup that he uses. He has set up a few of these things. Robk's car is extremely dialed in also and has many great suggestions.
Old 02-10-2009, 04:47 PM   #1433
Hi guys, very helpful thread.
I have a second hand f103 with the Hakkinen shell and a bunch of hop ups that I have slowly figured out.
Trouble is, it has the height adjustable case and all, but no inserts/adjusters other than the ones in there.
Can someone help identify a part or spare part number I need to get a set of the adjusters, or even aftermarket ones?
Keyz is offline   Reply With Quote
Old 02-10-2009, 06:05 PM   #1434
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
This is the part you are after 0115211 (S Parts)
mild seven is offline   Reply With Quote
Old 02-10-2009, 07:31 PM   #1435
Thank you!
Old 02-10-2009, 08:27 PM   #1436
by adjusters, do you mean the adjuster for the motor mount casing or the adjusters for the rear shaft?
Old 02-11-2009, 05:22 AM   #1437
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Hi guys,
managed to finish my new bodyshell I plan to use for our local club races. It's a Tamiya F-103RM (L-Type body) chassis with a few additional hopups. Body is a TRG SW F-1 and the car rolls on Zen F-1 foam tires with the wheels I painted chrome.
I painted the body in a sort of fictional scheme i call "Semi-Brabham". Decals are a combination of protoform Alfa Romeo script decals and the sponsor labels and stripes from an unused Tamiya Martini Alfa Romeo DTM bodyset. I plan to stick possibly Tamiya or more Alfa Romeo script decals on the big white area on the airbox.
i decided not to paint the driver area as i know this body will get bashed up a bit in the club races and i wanted to save weight by omitting some driver details
hope you guys like it. enjoy!
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 02-11-2009, 08:22 AM   #1438
rtypec's Avatar
Originally Posted by Vyger View Post
I noticed that too. I was trying to figure out what it could be, what the C stands for.
Sauber C-12
Lotus Castrol 107b
Williams Camel/Cannon FW-14b
Does anyone else have any ideas?
Oh happy days!
rtypec is offline   Reply With Quote
Old 02-11-2009, 08:25 AM   #1439
Trader Rating: 45 (100%+)
Originally Posted by Tommi Makkinen View Post
Hi guys,
That is sweet...Nice job!!
Apex is offline   Reply With Quote
Old 02-11-2009, 08:53 AM   #1440
RC MARKET's Avatar
MP4-23
form HK customer was made 1 month
TRG type M body
Tech Rear Wing
http://rcmarket.com.hk/index.php?cPath=68_213
TAMIYA F103 RM-20090209_8d623cc0b423ca3c361fybbjayxx6jml_jpg_thumb.jpg   TAMIYA F103 RM-20090209_63db57218bf9518fbf61b9ynkwwb3seg_jpg_thumb.jpg   TAMIYA F103 RM-20090209_acdf1bd67a750453bc85vlaf66nil6yt_jpg_thumb.jpg   TAMIYA F103 RM-20090209_c16ecc75dcbc580f708cfjmwypflxby0_jpg_thumb.jpg   TAMIYA F103 RM-20090209_d3b3c09cfd1e05219e313ljnrxpkquje.jpg
RC MARKET is offline   Reply With Quote
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
