Old 02-06-2009, 09:33 PM   #1411
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by silverhkswrx View Post
i recently swapped all my alum screws for titanium hex screws, the funny thing is, the front end alum screws are the same exact weight (down to .01 oz) as the square rc titanium front end titanium screws.
may i ask the benefit of havin the shock mounted to the lower chassis instead of the upper?
its a f103gt that i have converted the front end to accept the f103lm wheels from tamiya and other similar brands.
More angle, better funtionality.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-06-2009, 10:53 PM   #1412
Regional Moderator
Darkseid's Avatar
Originally Posted by Jamie Hanson View Post
Unless it is one of the LONG Aluminum screws that holds the front end on. They are soft. I already had to slot one with a dremel to get it out.
Oh yeah, those suck A$$!!!
I replaced mine after just one weekend of racing. What I did was go to the local Ace hardware and find a stainless steel screw the same size and replace both those long front screws.
The best part...the screws have a 2.5mm hex in them, so no stripping at all!
TLR 22...Tamiya F104...
Old 02-07-2009, 01:23 PM   #1413
idwurks's Avatar
Send a message via AIM to idwurks Send a message via Yahoo to idwurks
Hahahaha i just stripped one too!!! hahaha
www.Idwurks.com | www.od12.com | www.TopRacingUSA.com
idwurks is offline   Reply With Quote
Old 02-07-2009, 01:37 PM   #1414
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
you think i could use a heavier oil because of the angle? i am using 35 now but it is VERY smooth. too soft for my liking...
any reccomendation on the setup on the oil filled shock? BTW i am running a 4.7ratio on a 3300 brushless i need traction!!!
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-07-2009, 03:40 PM   #1415
I run the white spring and 30 wt oil. It suits me fine, but that's with a silver can. I've never run a lipo in an an F103. In my WGT car, I run a 25 lb spring and 30 wt oil also. I ran 50, but was getting massive torque steer the minute the motor recoiled. I lightened it up and it went away. I get a little slide if I get on the throttle too hard right off the bat, but its predictable now.
Old 02-07-2009, 10:46 PM   #1416
robk's Avatar
Trader Rating: 22 (100%+)
The more you reduce the angle, the more on power steering the car will have, vice versa.
Not sure how fast a 3300 motor is but I have seen a 19t motor make a 103GT on foams pretty hard to drive. What is the car doing, is it crashing over bumps? Is it porposing on and off power?
Old 02-07-2009, 10:53 PM   #1417
on generic rubber tires, it would over power and do a u turn. since then i have turned the exp down, and am in the process of converting the f103gt to a f103lm.(only need the 3 racing front end for lm/GT and the 3 racing rear end for a f103lm-both on thier way in the mail to me. )
i also think my issue was the 5.5DR that i bought the car with. i have since ordered a 20/21 and 94/103 kit and will keep a 4.7 DR.hopefully that solves my problem.
as soon as i get the parts, i will let you know the experience.
Old 02-08-2009, 12:10 AM   #1418
nice car mate
would love to have the 15 anniversery model
NITRO
TOURING CARS
Kyosho Super Ten FW-04
OFF-ROADERS
Colt 1/10 buggy, converting to rally style this weekend
ELECTRICS
TOURING CARS
Tamiya TA-04S
Tamiya TL-01
OFF-ROADERS
Tamiya Super Hornet
XxDestroyerxX is offline   Reply With Quote
Old 02-08-2009, 03:28 AM   #1419
Foxxrocket's Avatar
Anyone heard any news about the carbon fiber painted body TRG was suppose to release? It should have been out months ago.
http://www.rc-trg.com/cpf1body.html
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 02-08-2009, 05:27 AM   #1420
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
i am running 21/93 (4.42FDR) with an LRP x11 13.5 (bonded) on a large ex-1/8th nitro track (250m) with TRG rubber tyres...
one thing that i have found which reduced a lot of the twitchiness in the steering is to turn the EPA down on the servos.. mine are set at about 60 on the EPA for left/right and i have DR down around 70-80% (DR was tuned for the track)
</2cents>
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 02-08-2009, 08:33 PM   #1421
theDover's Avatar
Originally Posted by gramm View Post
48p? Always.
Go with 72/19 for that silver can. 72/20 for small foam tires.
Daniel
Hey Thanks. Sounds like a good starting point to me. Appreciate it.
TEAM ULTRALINE / RickyRacerLidz
www.ultralinehobbies.com
Ultraline Hobbies RC Raceway @ fb
theDover is offline   Reply With Quote
Old 02-08-2009, 08:59 PM   #1422
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I've asked several times with no answers. I have wanted that body since I've seen it. I want to put it on my 15th Anniversary.
SerpentCT4S is offline   Reply With Quote
Old 02-09-2009, 01:37 AM   #1423
Talking Tamiya F103GT
Hi all,
I just purchased an F103GT with a S2000 Bodyshell. I have no esc and batteries installed. As for motors, i have Mabuchi RS-540 and HPI R2 23T. I would like to enquire what are the items i need to buy best for the kit. I am in need of a good motor, esc and batteries. I have been playing nitro powered rc for awhile, so i am new to EP racing. Thanks all. You can PM me too. Thank you.
Steergod is offline   Reply With Quote
Old 02-09-2009, 05:00 AM   #1424
Foxxrocket's Avatar
Me too. It's one of the coolest F1 bodies I've seen, and no need to paint.
Cut, mount and race.
Old 02-09-2009, 06:58 AM   #1425
It shown on their website, but they don't sell direct from what I can translate.
http://rc-trg.com/
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
