Old 01-29-2009, 05:51 PM   #1321
How much does a RM or R go for at Champ?
stocker is offline   Reply With Quote
Old 01-29-2009, 07:16 PM   #1322
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
they are about 9300 yen from champ. Thats about $105 USD
mild seven is offline   Reply With Quote
Old 01-29-2009, 08:23 PM   #1323
Trader Rating: 15 (100%+)
Default f103
i have a brand new in box f103gt courage with blue motor mount and shock for 100$ [email protected]
AARON YOUNG is offline   Reply With Quote
Old 01-30-2009, 02:37 AM   #1324
mac853's Avatar
Excuse me, could somebody tell me:
Which aftermarket body has best aerodynamic performance for any Formula 1 chassis?
Which aftermarket of front and rear wings has best impact proof and best aerodynamic?
Which make and set of compounds of rubber tyres are using commongly?
Best regards
mac853 is offline   Reply With Quote
Old 01-30-2009, 04:16 AM   #1325
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Best regards
aerodynamics - no idea
front/rear wings - i like tech racing wings, the plastic is kinda flexible and not brittle and prone to cracking, also the front wing end plates pop off in a collision by design so they dont break
rubber tyres - out my way those using rubber tyres are running TRG, rears appear to be soft, front has a choice of hard or medium (i'm getting good results with soft front springs and hard front tyres)
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-30-2009, 05:32 AM   #1326
mac853's Avatar
Thanks for your advise about tyres and wings, about my question of bodies is about the choosing the 1 with nice handling, how about the bodies from Cross, TRG and Zen. I don't like so much those from Chevron and those body of year 200X replica version of TRG, to be so much heavy carry of aerodynamics which i don't like so well.
Would somebody make a comment about my opinions, please?
Then I forgot also about the question of the diffuser, which brands are nice, please?
About the shaft, what material was better, carbon or aluminium?
Then i want report something, i saw in redrc.net, somebody in Japan was running Kyosho F1 so finished 2nd position in Amain of 30T class, could somebody tell me if this car is any good then run or not with 1 of those before?
Best regards
Old 01-30-2009, 07:39 AM   #1327
mok
mok's Avatar
i am using the 91M body from TRG...
the reason for this is that this body shape fits lipos without any issue (due to the shape of the side pods)
i like the TRG Carbon Diffuser..
http://www.rcmart.com/catalog/rc-f10...th=595_744_888
i have seen the carbon shaft wear quite easily at the grub screw that bites into it.. would also presume that the aluminium shaft doesnt do this, but is heavier and prob would be slower to reach max rpm (guess)
i would say that its as good as the F103... never ran one before though
they all seem to be fairly close in performance, unless you're talking about the seriously expensive high-end F1s like the MLPs, Corally etc...
Old 01-30-2009, 08:53 AM   #1328
240Z's Avatar
Best regards
As noted, the grub screw does not seat well with the carbon shaft. I was thinking of machining a piece to fit in the slot for the grub screw to seat against to fix the problem. I have heard rumors of the carbon cracking.
Aluminum bends. Not a major bend, but just enough to tweak it and make the wheel wobble. Be prepared and buy several if you plan to run it.
240Z is offline   Reply With Quote
Old 01-30-2009, 10:35 AM   #1329
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Originally Posted by Turbonium View Post
hey all... i am in the process of putting back together an old 103RS, and was curious. i have the kit o-ring setup, along with the ball pivot type. which would be better on carpet with foam tires? and any ideas on how to set that particular one up?
any ideas?
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-30-2009, 10:54 AM   #1330
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
any ideas?
I am running on carpet and run o-ring setup. I am running the R kit tires and basically stock setup. I did shim the front ride height 2mm lower (shim the king pins)30wt oil yellow spring on the shock. And Tamiya ceramic grease on the friction plates.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-30-2009, 11:26 AM   #1331
mtveten's Avatar
How exactly do you lower the front ride height? When I built my car I wanted to do so but I didn't see a way to do so without shaving the steering block in violation of TCS rules.
Mark
mtveten is offline   Reply With Quote
Old 01-30-2009, 11:43 AM   #1332
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I sent an email to Champ.
I will be getting parts bags A, B and C (x2)
THEY CAME THROUGH!
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-30-2009, 12:09 PM   #1333
THEY CAME THROUGH!
It is so easy.....it should not be that easy. Watch how fast it comes, I bet you have it by mid week next week.
cherokee is offline   Reply With Quote
Old 01-30-2009, 12:29 PM   #1334
They said they did not have them in stock, but they could get them straight from the factory. The hitch being I could not return them or cancel the order once started. As I need most all of the parts to complete my 2 cars from cast offs, I don't think they'll go back. The owners of these 2 cars will be very happy with them when they are complete.
Old 01-30-2009, 12:41 PM   #1335
Mark
Just add shims below the front springs before putting on the e-clip... Give it some trail & error.
Ben.C is offline   Reply With Quote
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
