Old 01-16-2009, 01:19 PM   #1186
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Jamie Hanson View Post
What kind of servos are you guys running in these cars?
Also, is there any weight rule on the F1 class for a TCS race? I do not see anything posted.
Jamie,
I run a Hitec HS625-MG nice speed, not too heavy.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-16-2009, 02:04 PM   #1187
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I run a JR4750...just because that's what I had around. It' doesn't need much.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-16-2009, 02:29 PM   #1188
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Apex View Post
So I picked up an F103R today and was expecting the rear ball suspension to be included with the kit, but I guess the F103R kit doesn't come with it. What are the advantages of the rear ball suspension? I would think it would make more of a difference on asphalt than carpet?
I have yet to run the o ring suspension, mostly because there is no provision for tweak control. I run the ball suspension on carpet, and I have it set up like a 1/12 car, with tweak screws at the front. I don't know if going without some kind of tweak control would work, but I feel better knowing my car is square when I put it on the track.
Old 01-16-2009, 03:14 PM   #1189
I have only run the O-ring suspension so far and I can say it tracks dead straight with no pull on or off throttle. I was suprised as to how well the car worked right out of the box. This is with a F103R on carpet.
Old 01-16-2009, 04:13 PM   #1190
Trader Rating: 24 (100%+)
i have yet to open the box on my 15t anny kit yet.
2 questions.
1. is there a way to run 64pitch gears on the car?
2. what is the dampner lube i am hearing about? 15k, 30k. what is it for, what do you use?
vic0280 is offline   Reply With Quote
Old 01-16-2009, 04:44 PM   #1191
Trader Rating: 31 (100%+)
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 01-16-2009, 05:07 PM   #1192
Trader Rating: 45 (100%+)
Good to know the ball suspension accepts tweak screws. I'm gonna try the o-ring setup first and then try the ball suspension. One thing I like about the o-ring suspension is that you can tighten the o-ring to control roll. Anyhow, probably good to have both in the pit box to cover all conditions.
Apex is offline   Reply With Quote
Old 01-16-2009, 07:41 PM   #1193
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
2 questions.
64 pitch spur gear adapter..
http://www.muchhobby.com/shopping/pr...oducts_id=2316
this will more than likely be for the top friction plate
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-17-2009, 04:11 AM   #1194
I guess you figured it out? It's alright, if we were all perfect we'd be controlling rc cars with our minds by now.
Old 01-17-2009, 06:20 AM   #1195
Yup... I was just being an idiot and missed the thrust and cone washer part.
Old 01-18-2009, 08:29 PM   #1196
TitaniumR's Avatar
Hi,
Where do you put the tweak screws? Can you direct me to page on difference between ball and oring suspension? I'm having the 103R - ball setup I suppose? Thanks.
TitaniumR is offline   Reply With Quote
Old 01-18-2009, 08:41 PM   #1197
robk's Avatar
Each of the two carriers for the pivot balls has 4 screws to secure the pivot ball in place. You will notice there are 2 more holes, one on each side of the ball, which you can put a screw into for tweak control. The screws I use are small machine screws, I think the size is 1.5mm or 2mm, I haven't measured them. The tweak screws go into the pivot ball carrier towards the front of the car.
Old 01-18-2009, 09:17 PM   #1198
gto0209's Avatar
Whoa! switched to the o-ring suspension today and holy crap it drives better, but has more of a push where as the pivot ball has a tendency to load up and transfer all of the weight at once, which ca lead to to the dreaded hook or on power pull. In my opinion the o ring rear susp. is more predictable. Rob how does your car drive with the new chassis from ebay?
long live f-1
gto0209 is offline   Reply With Quote
Old 01-19-2009, 03:00 AM   #1199
TitaniumR's Avatar
Hi robk,
I've looked thru the car(15th Anniversary version). I can't find any pivot balls or their carriers. Which part of the rear or front suspension are you referring? Thanks.
Old 01-19-2009, 03:26 AM   #1200
mok
mok's Avatar
Originally Posted by TitaniumR View Post
Hi robk,
the F103R (15th version) has the o-ring suspension so you wont find it on your chassis... but they'd be in the same place as the o-ring suspension is now
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
