Old 11-22-2008, 12:48 PM   #886
subaru73's Avatar
Trader Rating: 41 (100%+)
Default f103
If you have a hard case lipo you will have no worries,the battery ends are a good idea but they tend to get in the way ie hang up on curbs and track barreirs.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 11-22-2008, 05:45 PM   #887
414MPH's Avatar
Originally Posted by kavadni View Post
I am wondering what the pros and cons of the two mechanism for joining the front and rear;
'pivot balls' or 'washer and o-ring'; my car has washer and o-ring.
Kevin
Kev,
It all boils down to preference and tuning choices.. Nothing more, nothing less......"
The midwest carpet guys like pivot balls even when running asphalt on the west coast. The west coast guys only lile to run O'rings. I have run both with sucsess at Aliso.
I don't know where you are, nor do I know what the prefernce is out east or south....
It is up to you and they both work well when tuned to your liking.
Marty
414MPH is offline   Reply With Quote
Old 11-23-2008, 02:47 AM   #888
kavadni's Avatar
Thanks Subaru73 and Marty.
I was at the track today, and had discussions with the F1 guys.
I was told to be careful that I got the correct kingpins during my conversion from GT to RM,
tp ensure wheel clearance
I assume that the pins that come in 50395 are correct.
Is the set 53119 suitable for the RM?
Kevin
kavadni is offline   Reply With Quote
Old 11-23-2008, 03:27 AM   #889
ffactory666's Avatar
Trader Rating: 19 (100%+)
Guys i just won a new Cross Fire Force on ebay and was wondering what wheels / tires will fit it in rubber and foams ? Also were can i get spares for it .As i understand it uses similar parts to the F103 , what hop ups for the F103 fit the fire force , was thinking the alloy motor mount and differential housing as i'm not sure what hop ups are included in the box.
Cheers
ffactory666 is offline   Reply With Quote
Old 11-23-2008, 04:27 AM   #890
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Cheers
i get my spares from:
http://www.the-border.com/
http://www.rcmarket.com.hk/ (special order)
http://shopping.rcmodel.hk/
http://www.d-drivesportsenglish.com/
i think tamiya wheels fit but you'd need to change the front wheel bearings.
for hop-ups that fit...
titanium or CF rear axle
aluminum diff housing
t-bar plate
alum motor mount/heatsink
basically everything at the rear pod except for the front pod part.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-23-2008, 09:09 AM   #891
mxrich's Avatar
Cheers
Not many are included but they are not that expensive. The main ones you need are the Aluminum motor plate and the aluminum front bulkhead kit. The front bulkhead is the only weak thing we have found on them and that cures that problem. (If you are driving the older Fire Force with the inboard shock setup on front). They are fast and seem to turn a little better that the old 103's. Tamiya wheels fit them but some wheel builders require a 1/4 spacer on the diff side. No biggie but some wheels like the TM's are that way.
mxrich is offline   Reply With Quote
Old 11-23-2008, 12:54 PM   #892
414MPH's Avatar
Kevin
Kev,
The 53119 is discontinued by Tamiya.
I prefer the 50395 uprights to the offset type and I also prefer the 50508 F-1 Super Kingpin Set for tuning ease at the track.
Marty
Old 11-23-2008, 01:00 PM   #893
Thanks VooDooPH and mxrich very helpfull , now to order some parts
It's the version with the inboard shocks , i'll post some pics when i get it
Old 11-24-2008, 03:17 AM   #894
kavadni's Avatar
Next I need to purchase a body, wings, and diffuser.
I would like some suggestions.
For my first body as I attempt to develop some skill.
I think I want something that will take a few impacts, end over end flips and rolls.
Which brand of wings are the most durable?
Can anybody recommend a wing set, body and diffuser that work well together, and are durable.
Kevin
Old 11-24-2008, 11:33 PM   #895
kavadni's Avatar
Thanks again Marty,
It looks like the kingpins are going to be the hard part for me to get.
Might be time to get to a lathe.
Kevin
Old 11-25-2008, 03:27 AM   #896
bakaguyjean's Avatar
Thanks again Marty,
Kevin
Here is the king pins along with the uprights/springs/and ball ends
http://d-drivesportsenglish.com/inde...roducts_id=110
Easy to find but you might want to get something else together to save on shipping.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 11-25-2008, 03:30 AM   #897
Kevin
The Cross/TRG wings are the most durable. Just about any body works well together. diffuser isnt needed but you can get one with a Nikko 5E body at D-Drive. The Nikko 5E bodies also work well with the Cross wings.
Old 11-25-2008, 08:20 AM   #898
liljohn1064's Avatar
Trader Rating: 17 (100%+)
My son stuffed his into the guard rail one too many times Sunday. Now he needs lower A-arms. I ordered from d-drive, but his car is out of action this week and maybe next. Anyone now of a supplier in the states? It seems everyone is out of part 50503.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 11-25-2008, 09:47 AM   #899
mxrich's Avatar
Thanks again Marty,
Kevin
Back in the '70's I bent a kingpin on my 103. As an emergency fix I cut and put in an allen wrench to run the main. It worked great! It's still there.
Old 11-25-2008, 12:55 PM   #900
reenmachine's Avatar
Trader Rating: 26 (100%+)
F103 time travel?
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
