Old 11-19-2008, 07:47 PM   #871
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
Originally Posted by hairy View Post
thanks but it won't let me browse without opening an account!
http://www.rcmart.com/catalog/default.php
http://rcmarket.com.hk/index.php?osC...gd7c3n4lpqg5q6
SerpentCT4S is offline   Reply With Quote
Old 11-20-2008, 12:39 AM   #872
hairy's Avatar
thanks for the info,it was the computer acting up that would not let me browse.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 11-20-2008, 03:09 AM   #873
bakaguyjean's Avatar
More bodies and decals here also
http://d-drivesportsenglish.com/inde...=index&cPath=2
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 11-20-2008, 06:56 PM   #874
kavadni's Avatar
I know very little about the F103 Chasis except that I love them, and have to have an open wheeler.
A class has started and I have been marshalling them for the last couple of meets.
A few days ago I purchased a second hand F103GT.
The car appears to be almost entirely 3-Racing parts, excepting the front suspension arms,
a few plastic parts. shafts. and pins. It has the Tamiya Shock.
Ive realised I need different hubs and have ordered:
3racing 3R-F103RM-01 Differential Housing
3racing 3R-F103RM-09 Front Knuckles
Tamiya 50388 Diff Ball and Plate Set
And a set of TRG Rubber.
I have been unable to determine, which bag or sprue from the
RM kit I need to buy to get the RM body posts.
Can anyone please advise me the PN#?
I have located manuals for the GT and the LM, and an exploded diagram of the RM.
Can anyone point me at a link to an RM manual?
Kevin
kavadni is offline   Reply With Quote
Old 11-20-2008, 07:54 PM   #875
Kevin
http://www.rctech.net/forum/4974508-post635.html
Mike
RCNewz.com
quick5pnt0 is offline   Reply With Quote
Old 11-20-2008, 08:24 PM   #876
Kevin
D-Drive Sports has the F103RM,F103GT,HPI Super F1,Corally F1 and Cross CF01-08 manuals linked at the bottom of thier home page.
http://www.d-drivesportsenglish.com/
The "D" parts tree is what you need for the body mounts for front and rear.
Old 11-21-2008, 12:39 AM   #877
kavadni's Avatar
Thanks for the manual links.
I have read about a long wheel base F103-L is the wheelbase the same between the other variants? RM GT ? Which variant was the indy car?
Kevin
Old 11-21-2008, 01:19 AM   #878
Kevin
I believe that F103-L was the indy car chassis.
Mike
RCNewz.com
Old 11-21-2008, 09:37 AM   #879
RaceBucks's Avatar
Default F103RM diff question:
Why does the RM put the diffís thrust bearing and cone washers into the right wheel? This makes no sense. So as the tire wears and I flip the tire from one side to another, or I switch out tires, I have to take apart the wheel hub and move the thrust bearing and cone washers into another wheel?
This canít be right; pan cars for years have figured out how to bolt the wheels straight on. The F103GT doesnít have this issue; why did Tamiya do this? Is there an upgrade option that fixes this?
Man, is this a strange design!
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 11-21-2008, 04:26 PM   #880
Vyger's Avatar
Kevin
If memory serves me right, the F103RS, RX, RM, GT, and R are all 260mm wheelbase.
The F103L is the "Indy" car chassis and it has a 280mm wheelbase.
Tamiya Road Wizard, F101ís, F102ís, F103ís, F103RSís, F103LM, F103RXís, F103RMís, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 11-21-2008, 04:43 PM   #881
414MPH's Avatar
Relax, this is no big deal. The diff is very easy to adjust and only needs attention when changing wheels/tires in the rear. Any other design would weigh more and cause handling annomalies like it did on the F-103GT.
Just try it, you will like it! I ran this for years with no hasle or issues in the past.
Marty
414MPH is offline   Reply With Quote
Old 11-21-2008, 06:27 PM   #882
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
yes the 103L is the Indycar. I am currently finishing up a Rahal Hogan Motorola car that will be for sale, probably by the end of the weekend
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 11-21-2008, 06:38 PM   #883
robk's Avatar
Trader Rating: 22 (100%+)
Marty
They could have just made it like a 1/12 car. It is what it is...
Old 11-21-2008, 07:29 PM   #884
Both Tech and Kawada make a diff where you can change the wheels with out adjusting the diff.
http://d-drivesportsenglish.com/inde...roducts_id=234
But it really inst that hard to swap tires with the stock system.
Old 11-21-2008, 09:11 PM   #885
kavadni's Avatar
I am wondering what the pros and cons of the two mechanism for joining the front and rear;
'pivot balls' or 'washer and o-ring'; my car has washer and o-ring.
Also I've read the suggestion - remove the plastic battery holders and use tape instead.
I am a little concerned about my lipos getting damaged .. opinions?
Kevin
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
