Old 10-20-2008, 09:52 AM   #571
hobbipro's Avatar
Trader Rating: 21 (100%+)
TenzoR, I've had several pan cars in the past, 1/12th, and even 1/10th. These Tamiya F1 cars drive very well in my opinion. But I do run mostly black can motors, I'm sure if you bolt in a 10T mod, it would be a handful. The key is to drive smooth and not grap big hand fulls of throttle. Excellerate nice and smooth, and let off before the turns. Don't run up to a turn and expect to jam on the brakes expecting it to turn in like a touring car, just stay smooth and set up your turns, and with practice your lap times will start to drop. These are by far the most exciting cars I have right now, and I'm very glad they are back.
hobbipro is offline   Reply With Quote
Old 10-20-2008, 10:22 AM   #572
i have a 10t motor in mine and programmable ESC and its not a handfull at all to be honest.
I think the foam tires help with the grip though and stop it spinning my other rwd rc car with rubber tires just spins and spins, but then again it is a grasshopper with a brushless system in it so what would you expect!
with my f103 i re programmed the acceleration curve on the ESC and it handles a bit better for it (or its just in my head, one or the other!)
the only problem is spur gears.
eats them
3 runs (as in 3 battery swaps) and the spur gear is unusable.
f103rm, couple o mods
Pimpzilla, all alloy/titanium 1/18th Minizilla
DucatiGary is offline   Reply With Quote
Old 10-20-2008, 11:39 AM   #573
Originally Posted by TenzoR View Post
How easy is to drive the F1? I've only had 2 RWD R/C before. The M04L and the Tamtech. The M04L was quite difficult to drive as it spun out quite a lot. The Tamtech was different, it was pretty hooked and easier to predict.
I'm thinking about getting the F1 15th anniversary if it's not too expensive. I enjoy driving RWD RC since it's a lot more fun than 4wd. The Tamtech was a lot of fun and cheap!
I think the reason you found the M04L to be harder to drive was because of the size of the motor. The Tamtech cars are running 380 size motors which don't have the same kind of torque as the M04L so you could be harder on the throttle/brake and it didn't have the torque to really upset the chassis. The M04L on the other hand runs a 540 motor which has much more torque that can easily upset the balance of the car during throttle/braking.
F1 cars definitely aren't like touring car where you can just stab the throttle and watch it squirrel away but if you're smooth on the throttle they're pretty easy to drive.
Mike
RCNewz.com
quick5pnt0 is offline   Reply With Quote
Old 10-20-2008, 11:41 AM   #574
Are pebbles or something getting caught in it or is it something else? Possibly something out of round in the drive line like a bent axle?
Mike
RCNewz.com
Old 10-20-2008, 12:03 PM   #575
RC MARKET's Avatar
again !
not finish
TAMIYA F103 RM-20081015_ea24faf800557291016amzp3wvoxrsab_jpg_thumb.jpg   TAMIYA F103 RM-20081020_5f7df0368c6552595169p9koam2qbewu_jpg_thumb.jpg
RC MARKET is offline   Reply With Quote
Old 10-20-2008, 01:36 PM   #576
Rogier's Avatar
noticed on ebay a guy is selling painted TRG bodies and trying to pass them off as originals.
item number 170271402709 then check his other items for the other one.
nice paint job but VERY expensive and not what they seem!
I contacted the guy to ask if it are Tamiya bodies and he keeps telling me they are. Man, I hate this kind of people!!
Rogier is offline   Reply With Quote
Old 10-20-2008, 02:20 PM   #577
Vyger's Avatar
Is it possible they're F201 bodies?
Vyger is offline   Reply With Quote
Old 10-20-2008, 02:30 PM   #578
take a look at them, its the TRG body.
he says both are different models but if you look they are both the same just with different paint jobs.
to be fair to him his paint skills are really good, he says he has used ltd or never released tamiya decals, im betting he's got a vinyl cutter!
Old 10-20-2008, 02:34 PM   #579
mabe a bit of dirt, not sure, gone through 2 spurs now.
Old 10-20-2008, 05:08 PM   #580
TitaniumR's Avatar
Hi,
Could it be the 10T motor is too aggressive?
I've been trying to understand if I can fit a Novak GTB with fan and a brushless motor while cutting the body for a 103? Plan to get the 103R. Appreciate your advise. Thanks.
TitaniumR is offline   Reply With Quote
Old 10-20-2008, 05:49 PM   #581
Vyger's Avatar
The brushless systems I've seen are just to big to fit into the rear pod of the F103 chassis. You don't want anything interfering/binding the movement of the T-plate. This will make the car handle too sporadic. Using two wires (16 gauge) on a normal ESC is bad enough but three sucks, plus the tabs on the motor stick up to far. In my opinion the brushless system is the less desirable way to go for this car. But that's probably just me...what do the rest of you guys think?
Old 10-20-2008, 06:28 PM   #582
Originally Posted by RC MARKET View Post
again !
not finish
That's a Beauty!!
stocker is offline   Reply With Quote
Old 10-20-2008, 06:36 PM   #583
Foxxrocket's Avatar
I agree, it looks horrid with the tabs and wires sticking out the back. This is a class where Brushless actually becomes a lliability. It can be done, but I can see a number of possible problems cropping up. It's best left for Brushed, NiMH.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 10-20-2008, 08:56 PM   #584
theDover's Avatar
Has anyone heard when the actual release date is for the 15th ann. kit in the U.S.?
TEAM ULTRALINE / RickyRacerLidz
www.ultralinehobbies.com
Ultraline Hobbies RC Raceway @ fb
theDover is offline   Reply With Quote
Old 10-20-2008, 09:03 PM   #585
hobbipro's Avatar
I agree the brushless in a F103 isnt very appealing. When I had mine in there I had to cut the rear of the body to clear the motor tabs. It looked totally hacked, and I was being very conservative on what I cut out. A F201 is a different story, I have a Tekin system in mine and all the wires can be hidden better in the 201's. But thats not to say a brushless cannot be used in the 103, just be prepared to mod the body you just spend hours on painting, cutting out, and decaling.
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
