Old 06-13-2011, 12:02 PM   #2326
gtfour93's Avatar
Trader Rating: 22 (100%+)
Originally Posted by BP SHADOW View Post
Type C is the Lotus.
The Castrol logo makes it a Type-C body.
The Jordan 191 Ford decals can also be used on the Type-C body. I have a new Tamiya Jordan 191 Ford decal set for sale if anybody is interested.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 07-07-2011, 01:07 PM   #2327
lightfoot's Avatar
Default UF1 Series
This Saturday July 9th will be the 5th race of the UF1 Series , The Grand Prix of Cam Marino an F1 ONLY event...
http://uf1series.com/schedule.html
Also the new UF1 shirts have arrived ... Again Mike Rydwell has helped out on design and printing... Thank you dude... 100% of sales will go towards the Season Review Book...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 07-16-2011, 03:24 AM   #2328
kneedeeppow's Avatar
can anyone tell me what is the size of the front wheel bearings for a 103?
thanks
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 07-16-2011, 03:39 PM   #2329
robk's Avatar
850 8x 5mm
Old 07-17-2011, 06:35 AM   #2330
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by robk View Post
850 8x 5mm
I think an 850 is actually a 5x8, id before od
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 07-18-2011, 01:45 AM   #2331
cheers guys wood they be 5 x 8 x 2.5?
Old 07-18-2011, 04:54 AM   #2332
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
sounds about right...i believe the last time i bought bearings for my F103, that was the thickness of the ones i bought
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-15-2011, 03:26 PM   #2333
kedal's Avatar
Hi guys, what would be the body type for a Senna's McLaren replica ?
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 11-15-2011, 03:49 PM   #2334
BP SHADOW's Avatar
Are you asking which body ro use for it?
http://f1rclab.com
Old 11-15-2011, 04:10 PM   #2335
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Either the MP4-5B bodyset
RC Body & Rear Wing: 84192
Or the MP4-6 bodyset
RC Body & Rear Wing: 84193
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-15-2011, 07:54 PM   #2336
Do all F104W bodies fit the F103RM?
stocker is offline   Reply With Quote
Old 11-15-2011, 08:11 PM   #2337
BP SHADOW's Avatar
Yes, but the dimples for the body post holes need to be relocated to run them on the 103
I have all 3 in stock at
http://f1paintlab.com/zencart
http://f1rclab.com
Old 11-16-2011, 02:15 AM   #2338
kedal's Avatar
Oh, i dont knew the F104W body fits the F103 8 Good news, thanks !
Old 01-02-2012, 12:53 AM   #2339
I'm having some problems with my 103rm on low grip asphalt or hard court, not getting enough off throttle steering. On throttle seems ok, and the car does spin out sometimes on corner exit but that could be because of my over eager throttling.
Running zen 35/25 shore f/r. 3racing shock with 30 oil. Silver spring on roll damper without grease. Silver (soft) spring on front. 3.5mm offset upright with toe rod on rear hole. The offset upright helped the coner exit to be more predictable but seemed to introduce off throttle push. Was on stock upright with black springs before. Any advice?
Thanks!
Old 01-02-2012, 05:54 AM   #2340
JamesHealey's Avatar
go to black hard springs on the front and on the T plate underneath rather than running two rubber o'rings, use a 0.5mm metal shim on the front hole and screw it down solid, then use a rubber o'ring on the rear one.
This will give much better steering characteristics, also make sure you're running where near 0-2 degrees of toe out on the front wheels.
Use a diff grease on the damper plate, i use associated diff grease, don't over tighten the damper discs they're just to slow down the rebound of the t-plate, not stiffen up the car.
Also make sure you're prepping your tires properly using suitable traction compound, start with rears only then introduce more to the front tires as needed to add steering.. (follow the compound instructions for how to apply)
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
