Old 11-29-2009, 06:45 PM   #2206
DRAG_ON's Avatar
Originally Posted by downtempo View Post
84095 (rear) are most like the premounts for softness, we use this in combo with 84096 (front) cuz they are medium and help scrub some of the twitchy steering on high grip surface.
84096 and 84097 are the mediums
84095 and 84094 are the softs
Premounts seem to be something like the combo I suggested above, but different.
hope it helps
van anyone help i need the parts number tires that included in F103RM -- yesterday i bought front tamiya tires it say soft (but it's harder than the original given in the box) -- same thing with the rear tires i bought rear tires it written soft but it feel like it's harder than the original tires from the box. Can you guys help me which parts tires number come with the box F103RM thanks mate.
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 11-29-2009, 08:44 PM   #2207
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Here you go
http://www.tamiyausa.com/product/ite...uct-id=9805476 rears
http://www.tamiyausa.com/product/ite...uct-id=9804385 fronts
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is online now   Reply With Quote
Old 11-30-2009, 10:32 AM   #2208
F N CUDA's Avatar
Trader Rating: 31 (100%+)
hope it helps
DRAG ON DUDE,
If you want the softest (rears only, run the medium up front!) tires I'd go with the numbers in the quote above by downtempo.
That is by far the best combination for asphalt with less than perfect traction.
This car has too much steering and needs the softest rear and the firmest fronts available when running on the tricky surfaces and these numbers are the best match we have found.
And if you "sauce" the tires (traction additive), try saucing only the rears.
Then if you need a little more steering, sauce the fronts a little, start with the inside of the front tires 1/4 to 1/2 of the width.
The alternative are the "premounts" which are pricey and are just about the same combination but DIALED.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-30-2009, 06:11 PM   #2209
DRAG_ON's Avatar
Originally Posted by F N CUDA View Post
DRAG ON DUDE,
Thanks FN CUDA -- Yes i do run in asphalt with medium grip.......... using the tires given out of the box is superb i achieve balance stability in handling. During the race my front tire and rear tire already worn therefore i have to replace. I forgot what tire parts number i used but i remember it say medium front (after i replace the old tire and i squeze the new tire it's seems the tires is twice harder than the original tire out of the box) same thing with the rear tires i also forgot the parts number but it say soft rear tires (after i install same thing it feel harder than the original tires out of the box)........... i will follow your advice to buy this combo:
anyway thanks for everyone fast response, advice and feedback, regards Drag_on
Old 12-01-2009, 12:59 AM   #2210
bsmooth's Avatar
Could any of you post some setups? I will have the car on-track for the first time this Wednesday. The surface is medium grip asphalt.
Thanks for any tips.
-Steve
bsmooth is offline   Reply With Quote
Old 12-01-2009, 03:34 AM   #2211
DRAG_ON's Avatar
-Steve
Here is my setup during the race in outdoor asphalt)
front tires: out of the box 103 RM
rear tires: out of the box 103 RM
front spring: Out of the Box (black)
toe in 0.5 deg
FRP chassis (out of the box)
F103 RM Carbon Upperdeck
double o-ring on t-plate (fully tighten, after release 1 1/2 turn both front and rear)
TRF shock - 2mm spacer
Spring: Red (soft)
Oil 250 much more
Piston: 3 hole
T-Plate: FRP out of the BOX
spring above friction pad: Silver (out of the box) screw in until 2.5mm
grease in friction pad: TAMIYA ball diff grease
spur gear: 63
pinion: 19
FDR: 3.315
motor: mabuchi 540 silver can
7 min final motor temp: 83 celcius (i used year racing motor pod full aluminum--black)
bateries: LIPO 3800 IP 25C
Trotle Expo: -28
drag brake:0
Old 12-01-2009, 08:08 AM   #2212
bsmooth's Avatar
toe in 0.5 deg
Spring: Red (soft)
Oil 250 much more
Piston: 3 hole
spur gear: 63
pinion: 19
FDR: 3.315
Trotle Expo: -28
drag brake:0
Thanks Drag On.
What about ride height? Also, do you run the tires full-size?
Thanks again,
Steve
Old 12-01-2009, 06:36 PM   #2213
DRAG_ON's Avatar
Thanks Drag On.
Thanks again,
Steve
yes i do run the tire full size ............ i never check my ride height, i do check 1 time when the front tire diameter is getting smaller, i check and it's around 3.0 mm. With the rear i used the bearing shaft holder in zero positions.
Old 12-01-2009, 08:32 PM   #2214
240Z's Avatar
Any body have a short upper deck they would be willing to part with for $10?
240Z is offline   Reply With Quote
Old 12-01-2009, 09:44 PM   #2215
Trader Rating: 8 (90%+)
are you guys getting 5 minutes with a 21.5 with a lipo that is around a 2400?
I am not even really sure who or where else is using brushless in the f1's, I am pretty new to this chassis and even have only been in about a year and a half in the hobby in general. I also run an Associated 10r5 in WGT and am starting to get the grasp of it more and more, like tonight in practice I ran 3-4 tenths faster than I normally do at my local. So I am wondering if there is anything I can implement from that car to the F1, and how they work differently?
Here is my setup I ams still waiting to get the shck upgrade this week and I plan on as of now running a three hole piston.
RC HP F103
Sp v2.0gt currently running the newest software 312 I think
Trinity P-SPEC 21.5
Looking for the lighttest lipo that will run five minutes or so..
Stock gearing
Stock Tires= does anyone know the box stock rollout?
Thanks for you help in advance
Chris
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 12-01-2009, 11:06 PM   #2216
robk's Avatar
Trader Rating: 22 (100%+)
The average trans am car (21.5, 4wd, 1450g min. weight) uses anywhere from 800-1200 mah per 5 minute race. I'm sure that 2400 will last 5 minutes with a 2wd car that weighs just about nothing.
Old 12-02-2009, 11:22 AM   #2217
240Z's Avatar
RC HP F103
Trinity P-SPEC 21.5
Stock gearing
Chris
We have several drivers running 21.5 in So Cal.
2400 will run a 21.5 in an F103 for 5 min no problem. Stock gearing is very short, so I would think you would take out about half of the 2400 in a 10 minute run. Your results may vary depending upon your track layout (big/small/tight/oval/carpet/asphalt etc.).
Don't know about your other questions.
Old 12-06-2009, 08:06 PM   #2218
GCT69's Avatar
need help, where can I buy a wing kit for the f103 here in the states aside from tamiya. Also will the f104 kit fit?
thanks
GCT69 is offline   Reply With Quote
Old 12-07-2009, 02:42 AM   #2219
DRAG_ON's Avatar
Thanks Drag On.
Thanks again,
Steve
how did you go with the race mate? did my set up help you in the race?
Old 12-07-2009, 08:52 AM   #2220
thanks
The F104 wing kit (front or rear) it's a direct fit.
I don't Know where you can find it, because I'm from Spain
prorace is offline   Reply With Quote
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
