Old 11-04-2009, 03:53 PM   #2161
JayL's Avatar
Originally Posted by ouinon View Post
Ok I understand, I take back part of the rim Tamiya and I put the rim with Zen?
Just the thrust bearing, conical washers and the silver end piece, not the plastic rim piece
JayL is offline   Reply With Quote
Old 11-04-2009, 06:44 PM   #2162
MaxSp97's Avatar
Originally Posted by Barry White View Post
Can anyone help me to find the f103 15an. BLACK low friction pads?
Is that what you're looking for?
http://rcmarket.com.hk/product_info....oducts_id=4600
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 11-05-2009, 02:13 AM   #2163
Barry White's Avatar
They look different to the original parts.
Barry White is offline   Reply With Quote
Old 11-05-2009, 11:58 AM   #2164
ouinon's Avatar
Default zen wheel
hello! can anyone give me some photos of a rim Zen (screen inside) to the rear of the car to see what adapter do I save for my F103.
Thank you in advance.
ouinon is offline   Reply With Quote
Old 11-06-2009, 03:30 PM   #2165
240Z's Avatar
no adapter is required for the Zen f1 rim when used on an F103. On a tamiya rim, the thrust bearing and conical washers are put inside of the plastic mesh part of the two part rim. It is kind of nice that these parts don't fall out when you take the wheel off. The Zen wheel is one piece and nothing holds it in the rim so it just falls out when you take the wheel off.
240Z is offline   Reply With Quote
Old 11-16-2009, 07:41 PM   #2166
GCT69's Avatar
I have asked this in the f103 forum, even did some searches. Maybe you guys can help me. How or what do I need to do to convert my f103gt to an F1 car?
Or what do I need to purhase so i can used the f1 foam tires, I'll be racing it on gt class. BTW I have two of these that's why the 2 questions.
tnx.
GCT69 is offline   Reply With Quote
Old 11-16-2009, 08:06 PM   #2167
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
tnx.
you will need the following
RC F103 Thrust Bearing Set
Item #51346
RC F1 Spare Gear Set
Item #50506
RC RD Fnt Upright Set - SP1395
Item #50395
RC Diff Joint Bag: 58194/156
Item #9805524
And of course the wheels and tires of your choice
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 11-16-2009, 09:36 PM   #2168
GCT69's Avatar
Item #51346
Item #50506
Item #50395
Item #9805524
tnx man.
Old 11-16-2009, 09:48 PM   #2169
BP SHADOW's Avatar
tnx man.
no problem
you will also need to take the spacer blocks out of the front suspension and rear pod
http://f1rclab.com
Old 11-17-2009, 08:25 PM   #2170
414MPH's Avatar
tnx.
I responded on the other F103 forum with a longer list than Brads, but without p/n's. Go check it out.
I converted two GT's last winter and I feel I should have just bought a new chass kit.
Marty (TAMIYA 414M's, F-1's and Vintage Trans-Am! Is there anything else?)
** Red Dot Motors** , thanks doc....
and I guess the TA-05 IFS-R is pretty good too.....
414MPH is offline   Reply With Quote
Old 11-18-2009, 03:07 PM   #2171
GCT69's Avatar
so if I want to run it on f1 foam tires, just need to replace the knucles and rear tire holder on the rear, I supposed. help?
http://www.tamiyausa.com/product/ite...oduct-id=53248
http://cgi.ebay.com/Tamiya-54154-Opt...#ht_2535wt_802
Old 11-18-2009, 03:35 PM   #2172
GCT69's Avatar
or I know that the f201 wheels will fit, but does anyone know if any foam tires would fit in an F201 wheels?
Old 11-21-2009, 07:49 AM   #2173
pejota's Avatar
Just got my F103 on the road after a year or so of sitting. Scored it on ebay for $10 bucks.
What i'm looking for is a new front wing, rear wing, body and diffuser set. I've been to D-Drive and am having trouble deciphering all of the different wings and which bodies wil fit.
I found an adapter ring for the spur at my LHS, however the 104 tooth, 64 pitch gear seems WAY too large. I can go 100 and 88. Although i saw someone else used a 94. Any suggestions? I'm running some Type B rubber tires the LHS had on the shelf. I'm in Florida so that seems good enough for the hot concrete track.
It also looks as though i'll need a new axle soon, too much wear from the set screw on the spur side. Aluminum, Carbon Fiber?
Posted a pic since i'm totally new to F1. Maybe you guys can spot some issues i'd never notice.
Thanks!!!
PS-Please ignore the for sale notice in the pics, tried to sell it about 6 months ago. Glad i didn't!
pejota is offline   Reply With Quote
Old 11-21-2009, 03:44 PM   #2174
414MPH's Avatar
10 bucks? Nice score dude!! That is the exact set up I scored the Souther California win with. You are closer than you know to true F-1 greatness with that chassis. Just keep working it with some foreward thinking and you should be just fine.....
Let me know what body set you are looking for.
MPH
Old 11-21-2009, 09:27 PM   #2175
pejota's Avatar
That's my question... what body set should i get?
From what i can tell, i've got the high nose body and front wing. I like the look, since that's what most of the cars looked like this year in F1.
However, the rear wing was broken when i got it and it looked like the diffuser was installed by somone who had no idea what the dimples on the lexan were for.
The front wing is in one piece, it just has a bunch of decals on it and is white, which may or may not affect future paint schemes.
If i could score everything as one kit or from one vendor, i'd be very happy.
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
