Old 08-29-2009, 01:12 PM   #2101
evanwest94's Avatar
Send a message via AIM to evanwest94
High speed I used a 94758 Digital Servo worked perfectly fine, you dont need as much torque because it is so light
http://unclefrankensteinsrctools.yolasite.com/
--------LOOK AT MY TING-TING!!!----------
evanwest94 is offline   Reply With Quote
Old 09-08-2009, 12:01 AM   #2102
RonF's Avatar
Originally Posted by RC MARKET View Post
MP4-23
form HK customer was made 1 month
TRG type M body
Tech Rear Wing
http://rcmarket.com.hk/index.php?cPath=68_213
Rc Market
What tires are these in the pictures from page 96 of this thread?
http://www.rctech.net/forum/5417711-post1440.html
RonF is offline   Reply With Quote
Old 09-09-2009, 10:16 AM   #2103
Trader Rating: 16 (100%+)
For those who use F103GT front end (suspension) for their F103...do you know what is the PIN that will fit the F103 front tires..? The GT front pin is for TC tires and is too long for the F1 tires to fit...someone told me it is a TB03 parts or some other Tamiya car parts....any know the parts number..? Thanks...
Old 09-09-2009, 02:51 PM   #2104
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hey guys,
Im about to get a F103Rm and a F104
Now, on the F103, its possible to go for 48P pinion and spur ?, for me its very hard to get 64 pitch stuff ...
thanks,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 09-10-2009, 09:18 AM   #2105
Csaari77's Avatar
Trader Rating: 34 (100%+)
yes, you can use 48 pitch spurs. You will have to get an adapter for the gear.
http://d-drivesportsenglish.com/inde...roducts_id=229
That is the part that you will need.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 09-20-2009, 11:30 AM   #2106
Moole's Avatar
I got the F103RM and i want to use some body shells which are usually for the F103GT.
What parts do i need do use GT bodies for my RM? i think its just the front bumber and the front body holder...!?
thanks
Traxxas Slash - Mamba Max 5700
Tamiya F103 RM - Yeah Racing Brushless
Moole is offline   Reply With Quote
Old 09-20-2009, 06:52 PM   #2107
414MPH's Avatar
If you wish to use sedan type wheels and tires there are a few additional things you will need.
The front Bumper for the F-103 GT fit against the chassis plate which was different than the F-103. The F-103GT uses a TA05 front bumper and boddy posts. So you will need a bumper set and Chassis plate.
The front steering knuckles are different and carry different axles as the axle turns on the knuckle and not the wheel. This also required a special link type front end so the suspension actually would work.
There are special rear body posts and supports to hold the rear of the body.
You will also need new rear hubs and differential arrangement from the F-103
GT.
I know this because I converted an F-103GT to an F-103 and I have all the parts sitting here.
So if you want to use sedan wheels and hubs, let me know because I still have all the parts available from my car, some parts I have new in package that I purchased as spares.
OR....
You could just run F-1 style wheels and tires and only get the rear body mounts. You could use an F-103LM (LeMans) front bumber on an F-103 chassis, or run body posts in the extra holes on the F-103 front end, but if you hit something this could break the front suspension.
If you want details check the Tamiya America web site for the parts sheet for the F-103GT. You should be able to see all the parts I spoke of.
http://www.tamiyausa.com/pdf/pl/58376.pdf
Marty (TAMIYA 414M's, F-1's and Vintage Trans-Am! Is there anything else?)
** Red Dot Motors** , thanks doc....
and I guess the TA-05 IFS-R is pretty good too.....
414MPH is offline   Reply With Quote
Old 09-21-2009, 03:04 PM   #2108
RonF's Avatar
Default Speed passion F1 motor?
I saw a couple references here for the Speed passion f1 sport tuned motor. How does it run compared to brushed and other brushess? Im looking at it due to it might be roar legal, sensorless so i can use a CC sidewinder if F1 goes that way after mabuchi 540's.
Anyone?
Old 09-21-2009, 06:20 PM   #2109
Trader Rating: 19 (100%+)
Anyone see this yet?
http://www3.towerhobbies.com/cgi-bin...?&I=LXYEC1&P=7
zake540 is offline   Reply With Quote
Old 09-21-2009, 08:51 PM   #2110
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by zake540 View Post
Dale Epp did an interview on rcevilempire.com saying he wanted to do some F1 bodies since the class was taking off again. I guess he did
Old 09-21-2009, 09:12 PM   #2111
Trader Rating: 23 (100%+)
Send a message via Yahoo to JATOdriver
Just traded a fellow RCTech'er for one of the fine cars and CANT wait to get it in my hands, the closest thing iv had to F1 is the Duratrax Delphi Indy and i am ready to have a real F1, as soon as i get it i will post for everyone to see
Hi, my name is Daniel and i have a problem, I'm addicted to R/C cars.
***TEAM TERRIBLES***
JATOdriver is offline   Reply With Quote
Old 09-22-2009, 03:28 AM   #2112
cracka540's Avatar
hey guys i have a f103rm in the post and am excited !!!
do they need and mods or good set up tips or are they sweet out of the box set to the manual?
cheers
cracka540 is offline   Reply With Quote
Old 09-22-2009, 07:04 AM   #2113
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
cheers
I would get the aluminum motor mount and special damper, and the optional front spring set. You are looking at about $50-$60 in hopups and the car will be good to race.
Just make sure when you build it that everything is free and smooth, especially on the diff.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 09-22-2009, 09:39 AM   #2114
timmig's Avatar
Trader Rating: 25 (100%+)
What is the best setup for the F103 to race on the Tamiya track in OC? Should I get the soft rear t-bar-- and go with medium 35 fronts and 30 soft rears? Last I heard people were trying to get more rear bite with these babies--
firm front springs?? Are we allowed lipos for the upcoming F-1 race??
TIm
timmig is offline   Reply With Quote
Old 09-22-2009, 09:42 AM   #2115
THANK YOU DALE....hope he is doing WINGS as well.
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
