Old 06-02-2009, 10:10 PM   #2026
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by evanwest94 View Post
What about just the part i need?
Sorry, I have a complete chassis that I am willing to part with, but not part out. With the 104 coming out, I want to unload the chassis to make room for a 104, if I have an incomplete car hanging around, it will just be in the way
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 06-02-2009, 10:46 PM   #2027
robk's Avatar
Trader Rating: 22 (100%+)
Okay, I just got the Tamiya formula lightweight differential and now I am because it doesn't fit on my F103-GT is there some way to make it fit?
Dude, why don't you just buy this stuff from a retailer...
http://www.tamiyausa.com/pdf/pl/58376.pdf <<parts list for the gt car
Old 06-02-2009, 10:59 PM   #2028
BP SHADOW's Avatar
and tamiya america has the parts in stock
http://f1rclab.com
Old 06-02-2009, 11:44 PM   #2029
Hey all, this time I need a diff. joint spacer for my F103-GT like this:
Attachment 456082
Thanks kind of hoping to get it by next week.
Evan
You know you have about 6 hobby stores all within a 20 min drive from fremont.
DirtyRacer is offline   Reply With Quote
Old 06-03-2009, 09:36 AM   #2030
evanwest94's Avatar
Send a message via AIM to evanwest94
yeah but the hobby stores don't have any parts for the F103-GT it their system because it is a discontinued kit.
evanwest94 is offline   Reply With Quote
Old 06-03-2009, 09:46 AM   #2031
Suspended
Trader Rating: 28 (100%+)
Even if they did have the part number in their system,all major distributors are out of this part.The part number is TAM51233 btw.Try a google search of the number and you will find places overseas with it.Good luck.Your better off buying the other guys used car.
racenut123 is online now   Reply With Quote
Old 06-03-2009, 10:07 AM   #2032
evanwest94's Avatar
I did that but i needed the part asap and i didn't want to deal with the long processing and shipping time, but i did end up doing that I paid $18 for shipping just to get it here in time and its not even the right part
Old 06-03-2009, 01:46 PM   #2033
BP SHADOW's Avatar
Tamiya America has it in stock, and you can order it direct from them. Depending on when you order, you can have it in less than a week
http://www.tamiyausa.com/product/ite...oduct-id=51233
http://f1rclab.com
Old 06-04-2009, 10:03 PM   #2034
evanwest94's Avatar
Default Mod
Okay since I couldn't mount the F103 light-weight diff. joint on my F103-GT I did a little modification to make it work, I drilled a hole in the hub and it does work I took it out for a test run today and it is great!!
The only set back is that the part where you attach the lug nut isn't as big as I thought it would be, but it is enough to mount the lug nut on.
Old 06-05-2009, 12:58 AM   #2035
idwurks's Avatar
Send a message via AIM to idwurks Send a message via Yahoo to idwurks
Just thought I would post a couple of my new body. Chevron body with Tech rear wing and 3Racing front (which is badly beat up). And don't mind the orange wheel spats, they need to be replaced with gold ones =)
Ian
TAMIYA F103 RM-redbull_idwurks1.jpg   TAMIYA F103 RM-redbull_idwurks2.jpg   TAMIYA F103 RM-redbull_idwurks3.jpg
www.Idwurks.com | www.od12.com | www.TopRacingUSA.com
idwurks is offline   Reply With Quote
Old 06-09-2009, 10:19 PM   #2036
chicagokenji's Avatar
Here in Chicago F1 rc racing has taken off. A bunch of us who run at various venues are now racing the class. I bought a F103RM a month ago and have raced it every weekend and on Tuesday nights. We're racing on Asphalt and carpet. I just replaced the stock foam front tires because they got too small. It's amazing how much front tires make a difference with this car. So it looks like I'll be replacing fronts once a month. Not too bad spending 20 bucks a month.
Are any of you running rubber tires here in the US as a group of racers?
chicagokenji is offline   Reply With Quote
Old 06-10-2009, 09:22 AM   #2037
240Z's Avatar
Good to hear it is alive an well in other parts of the USA. Tamiya F1 is a great class. You can wrap it up with two words “challenging" and "simplicity”. You don’t have to spend a lot of money to be competitive if you have some root skills.
I have never run on carpet, but have run foam and rubber on asphalt. Unless the surfaced is well prepped, rubber will not hook up well. With good traction rubber is great and you can run a lot longer on a set of tires than with foams. You also never have to worry about ride height or conical front tires. At the local track (BCR in Orange CA) some of the drivers have a preference for a rubber tire from Ride that is out of production, I read somewhere that they were going to make them again, but have yet to find anyone who sells them. TRG makes a decent set of rubber tires. In a recent race series, we all ran rubber to keep the cost down and the race group on an even playing field. About the only other rule was to run 17.5 brushless, but that was found to be of no great advantage/disadvantage to those running a decent brushed silver can.
240Z is offline   Reply With Quote
Old 06-14-2009, 10:58 AM   #2038
SCD WldCrd's Avatar
Those who run 17.5 brushless on their f103, I would like to know the gearing to start. I may give the brushless a shot on mine.
Race with Pace no matter what you drive.
Durango DEX410R - Aluminum Upgrades included ; X-Factory X-60 ; Ofna Hyper 10 SC ;
Team Xtreme Predator X11 (for fun, no race) ; Hot Bodies Ve8 ; Tamiya F103R
SCD WldCrd is offline   Reply With Quote
Old 06-15-2009, 09:19 PM   #2039
Any issues with using E clips instead of the special C clip used at the bottom of the kingpin (#9805478 from the manual)?
stocker is offline   Reply With Quote
Old 06-17-2009, 09:59 AM   #2040
240Z's Avatar
You may want to ask that question on the BCR forum.
http://www.rctech.net/forum/racing-f...lt-we-got.html
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
