Old 03-15-2009, 10:26 AM   #1741
RC MARKET's Avatar
Originally Posted by silverhkswrx View Post
i also stumbled upon this...
new rc zen body:
http://rc-zen.com/z0004.html
around this weekend arrive !
RC MARKET is offline   Reply With Quote
Old 03-15-2009, 11:21 AM   #1742
idwurks's Avatar
Send a message via AIM to idwurks Send a message via Yahoo to idwurks
Zen makes nice wings, but i feel like their molds for bodys are really sloppy
www.Idwurks.com | www.od12.com | www.TopRacingUSA.com
idwurks is offline   Reply With Quote
Old 03-15-2009, 12:19 PM   #1743
rtypec's Avatar
This is sorta related but. here are a few recent photos of my F103-R 15th Anniversary chassis with an LMP body.
Chassis: F103R 15th Anniversary
Body: Protoform Mulsanne
Tires: Kit Rear / HBR Soft Front
Motor: Straight out of the box Johnson 540
And here's a noobtube video of the car doing some laps. Enjoy.
+ YouTube Video
TAMIYA F103 RM-f103lmp1.jpg   TAMIYA F103 RM-f103lmp2.jpg   TAMIYA F103 RM-f103lmp3.jpg
rtypec is offline   Reply With Quote
Old 03-15-2009, 12:55 PM   #1744
idwurks's Avatar
I LOVE that body. Where did you find the decals???
Old 03-15-2009, 01:38 PM   #1745
Trader Rating: 45 (100%+)
Was building the F103R today and the diff sucks. I put it together according to the instructions. What gives? Anyone got any tips?
Apex is offline   Reply With Quote
Old 03-15-2009, 01:40 PM   #1746
idwurks's Avatar
Did you attach the wheels? The wheel houses the thrust bearing assembly.
Old 03-15-2009, 01:41 PM   #1747
rtypec's Avatar
The decals are from the Tamiya ABT Audi TT-R kit number 58300. I am uncertain as to the exact part number for the sticker sheet but it is available for order from Tamiya America. I hope this helps.
Old 03-15-2009, 05:49 PM   #1748
Low_E's Avatar
Send a message via MSN to Low_E
I'm new on the Tamiya F103-chassis and I would like to drive a lemans-like car.
Could someone explain me the differences between the F103,
F103R, F103RM, F103GT ...?
And if possible, add some info on differences in driving-properties
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 03-15-2009, 06:08 PM   #1749
edhchoe's Avatar
Trader Rating: 41 (100%+)
Default WTB: 0.4 module spur gear 104 tooth.
I know all of you have bought the hopup spur gears. If you are not using the larger of the two that came in the bag, can you sell me the 104 tooth spur gear please? I will buy two if you have two.
edhchoe is offline   Reply With Quote
Old 03-15-2009, 06:35 PM   #1750
Yes, just like in the instructions. The diff feels fine until I really start locking it down. I set the diff so I can't spin the spur with my thumb when holding both wheels. When I have it at this setting the diff just feels like crap. Maybe I just need to pick up the aftermarket spur gear adapter?
Old 03-15-2009, 06:54 PM   #1751
edhchoe's Avatar
From the point where you can't turn it loosen the nut about 120 degrees. More if the surface is slippery.
Old 03-15-2009, 07:15 PM   #1752
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
all items i had listed and more are on ebay...
i will combine shipping!!! i need money for tires and a set of ceramic bearings.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 03-15-2009, 07:24 PM   #1753
idwurks's Avatar
Yeah its a bit grindy. I assume an aftermarket spur with MORE diff balls would be better. Also, try sanding the rings lightly with some 800grit wet dry sandpaper... and make sure you use a little lube on there.... It should be okay. I run my diff on the looser side, almost at the point where it slips. With pan cars on asphalt, afaik, a little slip in the diff is the trick.
Maybe the diff balls or rings are just not that great. I would try to address those two issues first as a new spur really wont help that much (unless it has more diff balls).
Old 03-15-2009, 08:57 PM   #1754
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
i use ceramic balls in my diff, with extra holes drilled between the default 6 holes giving it a total of 12 balls..
the plates are sanded with 600-800grit and plenty of AW grease in the thrust bearing etc..
that seems to keep them smooth for me
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 03-16-2009, 06:40 AM   #1755
The aw grease worked and smoothed the diff out. It's still not a 100% to my liking, but maybe it just needs to get broken in.
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
