Old 02-25-2009, 09:33 PM   #1606
bakaguyjean's Avatar
Originally Posted by BP SHADOW View Post
that upright design was a carryover from earlier F1 chassis, so they were thinking cheap
The 3.5 are not the hot ticket for all cars. The way my chassis is set up and 95% of the guys i run with the 3.5 cause understeer. Our circuit is on the small side and a high grip circuit. Its nice to have a set of the 3.5s around to try but they are not a must have and can also hurt performance.
Dont fall into the trap of the option parts because they are more expensive. 3.5s,Link type supension,and pillow ball "T" bar mounts are all different items that really have to be tested where you race and are not for everybody. None of these items work on our circuit,but they might be good on yours.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 02-25-2009, 09:58 PM   #1607
414MPH's Avatar
Originally Posted by 240Z View Post
The part you speak of (#53258) is NLA from Tamiya. I wonder what the difference is between it and the A arm kit from the F103GT #51244? Anybody know?
The GT king pins are too long. I would have to measure the length of the F1 pins to see if Tamiya has another pin that is available. If anyone wants to know, just ask..... The GT front link suspension is still around and can be found easily.
Marty (TAMIYA 414M's, F-1's and Vintage Trans-Am! Is there anything else?)
** Red Dot Motors** , thanks doc....
and I guess the TA-05 IFS-R is pretty good too.....
414MPH is offline   Reply With Quote
Old 02-25-2009, 10:32 PM   #1608
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
if anything, just buy the 3 racign kit for the king pins... $13 cant be beat...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-26-2009, 12:34 PM   #1609
Can anyone tell me what firmness/shore tires come in the 15th Anny kit? I can't seem to find that info anywhere.
This car is a blast to drive!!! I built it to kit specs and put a 17.5 BL, 2 cell Lipo and M body kit on it and gets around our carpet track really well. It had a little understeer, but that was easy enough to fix. Now several other drivers are dusting off their F103s and bringing them out. Should be a fun class.
______________________________________________________
Team Tulsa - Team R/C Paints by Sonny - Durango DEX410
qwkpony is offline   Reply With Quote
Old 02-26-2009, 12:37 PM   #1610
RC MARKET's Avatar
Zen new 3D Rear Wing
TRG carbon F1 body
TAMIYA F103 RM-zen-z5003w.jpg   TAMIYA F103 RM-zen-z5003b.jpg   TAMIYA F103 RM-trg-3006.jpg
RC MARKET is offline   Reply With Quote
Old 02-26-2009, 12:48 PM   #1611
padailey's Avatar
Originally Posted by liljohn1064 View Post
NOT TCS LEGAL: You can shave down the formed in spacers in the middle on the upper A arm assembly and by tightening the center down, with different shims in their place, change the camber angle. As the center pulls down further, the king pin holes move in ever so slightly. I've been able to get the -0.5 degree camber I really like for handling to work.
Pretty cool... bought a new set of arms last night to try it. It definitely works... I just now have to give a little more grip back to the rear. We haven't started a class yet so I'm just playing around. Saved the other arm set in case our class rules won't allow it. I have a feeling once the class starts it will go by TCS rules.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 02-26-2009, 01:24 PM   #1612
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I have 2 spares for the same reason. I can put my car back to TCS at any time.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-26-2009, 01:47 PM   #1613
Matt Sunderlage's Avatar
3 Racing are made by 3 Racing. To be TCS legal, the part must come from Tamiya uncut, unmodified and out of the box assembled.
The "shim idea" is a proven theory for the stock out of the box fixed A arms. If you remove the 3 mm of plastic on the underside of the A arm and put the screws back in and tighten them all the way down, you'll get negative camber. The top and bottom arms should be touching now as the underside of the top A arm would be flat with the 2 nubs cut flush. About -2 degrees I think. By adding shims back in 1 or .5 mm increments you add positive camber back to the car. I stop adding shims when I reach .5 Degree of negative camber. An untreated A arm setup from Tamiya already has positive camber, so no, I would not shim one as out of the box they already roll on the outside of the tires.
If you could post some pictures of the modified parts that would be sweet. Like to exactly what to "shave" down to actually get negative front camber before I go at it.
Question: If you "modify a Tamiya part" wouldn't that be illegal????(For TCS) or would that be a grey area?
I do have a complete link front suspension I'll try anyway...just exporing tuning options on a fun simple car.
I keep my F1 cars TCS legal first, handling options second.
Matt Sunderlage is offline   Reply With Quote
Old 02-26-2009, 01:54 PM   #1614
Modifying parts is definitely not TCS legal, but after TCS is over they will still be considered spec here in Madison as the parts were intended for the F103 chassis. If you have only one set of A arms, let me know. There are still a couple at RCP from my last order. I'll take pics tonight and post them.
John
Old 02-26-2009, 01:59 PM   #1615
John
Sweet. I'll check back later tonite. Thanks John.
Old 02-26-2009, 02:02 PM   #1616
TRG carbon F1 body
prices?
Old 02-26-2009, 02:09 PM   #1617
RC MARKET's Avatar
Originally Posted by silverhkswrx View Post
prices?
rcmarket.com.hk
Old 02-26-2009, 02:51 PM   #1618
inconceivable's Avatar
rcmarket.com.hk
Ordered mine ! When should the 91M Carbon body ship ? I think the web site says 3/2, is that still accurate ? Can't wait !
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 02-26-2009, 05:25 PM   #1619
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
Im gunna order my carbon body tomorrow.
What is the difference between them? There is a 91 and a 94.
SerpentCT4S is offline   Reply With Quote
Old 02-26-2009, 06:08 PM   #1620
I couldn't tell with the pictures of the two carbon bodies. But if you look at the clear 91 and 94 it looks to me that the 94 has a wider nose section ? I'm guessing either is going to look great ! This will be my first TRG body so I don't have any reference point yet ....
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
