Old 02-24-2009, 09:15 AM   #1591
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by [RC10TC] View Post
What does this option part do for performance?
Tamiya 53259 3.5mm offset upright.
Thank you.
Makes the car less twitchy in long straights but takes away steering response.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-24-2009, 03:32 PM   #1592
Wonder what Tamiya's thinking when they put a 0 offset knuckle in the original kit?
I think they should do it the other way round.
Ben.C is offline   Reply With Quote
Old 02-25-2009, 08:54 AM   #1593
padailey's Avatar
I hope this isn't something that has been discussed over and over again and I just missed it... but here goes.
I know people have mentioned the uneven wear on the fronts due to the positive camber... it is kinda driving me nuts thinking something is wrong, but I've heard its normal. My car works pretty well but I can see on the tires that I'm really only running on the outer 1/4 of the tires most of the time. Eventually this will wear and I'll have those coned tires people have mentioned. Doesn't this cause some handling/performance issues? How do you deal with it?
Car is new to me so I have no prior experience to draw on.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 02-25-2009, 09:11 AM   #1594
Some posts back, someone did mention the 3Racing front arms do allow camber adjustments. I'm not sure how it affects handling because I've never tried it. Of course they wouldn't be TAC legal.
stocker is offline   Reply With Quote
Old 02-25-2009, 09:32 AM   #1595
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
You can either just true them periodically or get this which will help some and is TCS legal..
http://cgi.ebay.com.my/Tamiya-Formul...mZ350163411723
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 02-25-2009, 11:48 AM   #1596
NOT TCS LEGAL: You can shave down the formed in spacers in the middle on the upper A arm assembly and by tightening the center down, with different shims in their place, change the camber angle. As the center pulls down further, the king pin holes move in ever so slightly. I've been able to get the -0.5 degree camber I really like for handling to work.
Old 02-25-2009, 11:54 AM   #1597
idwurks's Avatar
Send a message via AIM to idwurks Send a message via Yahoo to idwurks
Does anyone have a US source for the Chevron onboard camera? I really don't want to order across seas for such a small part. Thx!
Also - we are starting up a racing program in Huntington Beach in the parking lot at OCRC raceway. If anyone is in the area, it will begin next Saturday, March 7th 2009. Get there at 8am.
For more info check out: http://www.rctech.net/forum/racing-f...ad-racing.html
www.Idwurks.com | www.od12.com | www.TopRacingUSA.com
idwurks is offline   Reply With Quote
Old 02-25-2009, 12:01 PM   #1598
inconceivable's Avatar
Have you tried running an F103 on the test track yet ? Just curious if they hook up at all ....
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 02-25-2009, 02:29 PM   #1599
240Z's Avatar
The part you speak of (#53258) is NLA from Tamiya. I wonder what the difference is between it and the A arm kit from the F103GT #51244? Anybody know?
240Z is offline   Reply With Quote
Old 02-25-2009, 02:32 PM   #1600
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
i was the one who said 3 racing makes the adjustable arms... why wouldnt they be legal?
the shim idea would not give a constant camber angle. the lower the suspension droops, the more camber. i dont think that would be wise. while turning, the outside wheel would be lower, increasing camber, losing contact patch.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-25-2009, 02:34 PM   #1601
You can still find them...but not really easy. The GT parts are the same, except not everything you need is in that pack.
Old 02-25-2009, 02:42 PM   #1602
3 Racing are made by 3 Racing. To be TCS legal, the part must come from Tamiya uncut, unmodified and out of the box assembled.
The "shim idea" is a proven theory for the stock out of the box fixed A arms. If you remove the 3 mm of plastic on the underside of the A arm and put the screws back in and tighten them all the way down, you'll get negative camber. The top and bottom arms should be touching now as the underside of the top A arm would be flat with the 2 nubs cut flush. About -2 degrees I think. By adding shims back in 1 or .5 mm increments you add positive camber back to the car. I stop adding shims when I reach .5 Degree of negative camber. An untreated A arm setup from Tamiya already has positive camber, so no, I would not shim one as out of the box they already roll on the outside of the tires.
Old 02-25-2009, 03:16 PM   #1603
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
that upright design was a carryover from earlier F1 chassis, so they were thinking cheap
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 02-25-2009, 04:29 PM   #1604
Typical capitalistic thinking...!! Way a go Tamiya!! Cheaper parts for us!
My local TCS is starting in another 2 weeks time!! We finally have the F1 class back this year!! Can't wait.
Old 02-25-2009, 06:56 PM   #1605
Default Hi from NZ
Hello fellow F103RM addicts
Just wanted to say hi and how enjoyable it was reading the posts.
I race a F103RM in New Zealand where we have just had our National Champs.... geographically its a little bit of a challenge getting around NZ we didnt get too many drivers from down south but 12 cars were entered and a great time had by all.
Have especially enjoyed the photos of everyones rides WOW have I got some work to do !
Seems there are different rules down here Li Pos arent legal down here yet looks like from most of the posts we are a little stuck for motors too as we run 27turns. Apart from that it all looks pretty familiar.
Cheers Si
sijorg is offline   Reply With Quote
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
