Old 02-20-2009, 09:04 AM   #1561
RossoTorro's Avatar
After a full run with Team Orion SHO 4200 pack, the motor is a cool 50 degree celcius. So it's not overheating, the ESC is also just slightly warm, not hot.
Will rebuild diff as instructions, then test tonight.
Will post back how it goes.
RossoTorro is offline   Reply With Quote
Old 02-20-2009, 10:59 AM   #1562
rccardr's Avatar
I think it's the new tires- sounds like that was the only thing that you actually changed when performance declined. Foam tires are cut out of big sheets and suppliers don't always use exactly the same material with each successive batch- even if THEIR bulk supplier claims that the material has not changed. So the new tires might have more (or less) rubber content or smaller (or larger) cells. Even if the shore number tests out to the same range, the tires can be very different.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 02-20-2009, 09:13 PM   #1563
RossoTorro's Avatar
Just home from track.
The car was amazing tonight again!
TQ and won all races, best laptime, best average and new lap record! Had lots of fun and some hard but fair fights on track.
My set up ended up with...
Black springs upfront, standard front suspension but with the 53119 king pins.
Lower damper mount, red spring, no preload, #200 Tamiya oil in it.
Diff got rebuilt as instructions says, new balls again, sanded rings.
Friction damper got hard grease tighted about halfway down, white low friction pads.
Rear pod on it's lowest. New spur gear. (104T) New pinion (21T).
T-bar was firm.
Tires was Zen 38 shore front(old ones, very small) and Zen 35 shore rear(new ones), using Red Dot Trinity tire sauce.
Body i used was Ferrari F310B with M. Shoemaker as driver.
Overall a great evenings racing. Only damage was a 850 bearing on right front got busted after a little incident.
Old 02-20-2009, 09:59 PM   #1564
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
am i correct by assuming it is 20wt? what do you find your results being with heavier oil?
when sanding what grit of paper do you use? i have 1k here as we speak and i am in dire need of a diff rebuild.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-21-2009, 12:26 AM   #1565
edhchoe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Turbonium View Post
Actually, there is another newer RM kit, its this one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXWCP2&P=7
it shows on order, but who knows if it will come in. in HK, they tell me its already been discontinued, but there might be some left somewhere...
It looks like the 310B body..
edhchoe is offline   Reply With Quote
Old 02-21-2009, 09:37 AM   #1566
Does the 103rm come with all the parts necessary to convert to the o-ring setup? I see that it has the plastic parts, but how about the o-ring itself?
thanks!
stocker is offline   Reply With Quote
Old 02-21-2009, 10:25 AM   #1567
RossoTorro's Avatar
The RM comes with all parts except the washer on the front of t-bar. Just use 2 normal gold thin washers. the o-ring is a normal black one that Tamiya puts in all kits!
I don't remember what oil i had in damper first time i built it, it's a old Low friction Formula damper and not the new one with adjustment. I rebuilt it first with 60wt oil, then after all my problems i used Tamiya's kit oil. They send with oil that is 20wt.
The F310B body is extremly strong, mine has taken quite a beating! Ordered new front wing now, can't find rear wing so i use Tech type B wing at the moment.
I used 1000 paper on diff rings and plain crap Tamiya diff tube.
Old 02-21-2009, 07:13 PM   #1568
i just got my 3 racing diff set in, and it fits, but there is a HUGE gap between the nut and where it secures the wheel. i am almost 100% positive it need the thrust bearing there but i am having HUGE problems finding one locally...
anyone have one lying around they are willing to sell?
this si what i need:
i need all washers, and bearings.
a few people in japan have some, but i dont want to wait 2 weeks to recieve...
thanks!
Old 02-22-2009, 01:18 AM   #1569
ali_g's Avatar
Anyone tried Tamiya foams on carpet and tarmac or which brands of foam tyres works best on carpet and foams??and any websites or tips for installing foam onto the rims ?
ali_g is offline   Reply With Quote
Old 02-22-2009, 05:10 PM   #1570
RossoTorro's Avatar
I have tested Hop-up Tamiya tires on carpet. All kinds, hard, medium and soft.
Only tires i have not tested from Tamiya yet is F103R tires. Got a set i will test later.
But the Zen tires we use now have massive grip.
I run 38 shore in front and 35 shore rear, that is my preferred combo.
Others on my track run 35 shore front and 25 shore rear with success. And the best part is, they are premounted! and pretty cheap and long lasting with right care! (Not crashing)
There are no other tire that preform that well if you ask me!
Old 02-22-2009, 05:42 PM   #1571
portyansky's Avatar
Trader Rating: 54 (100%+)
Hey guys, how do you lower the front ride hight? I tried putting in shims as I thought that would be the easiest way, but the tire can not go on. I guess cutting the tires is the only way?
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 02-22-2009, 07:04 PM   #1572
add washers to between the lower chassis and the suspension arm.
Old 02-23-2009, 03:25 AM   #1573
ali_g's Avatar
do u true the tyres to a smaller diameter?
Old 02-23-2009, 06:38 AM   #1574
portyansky's Avatar
Thanks, that was my next thought.
Team Hitec
Old 02-23-2009, 07:40 AM   #1575
Thumbs up
tamiya makes 1mm, 2mm and 3mm ones.
tamiya f103 gt madmiki Australia For Sale/Trade 1 02-04-2009 12:13 AM
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 GT heavy Australia For Sale/Trade 3 05-15-2006 02:49 AM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tags
rasta scbc
