Old 08-15-2003, 05:02 PM   #1
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Arrow Novak GT7 wont brake
My Novak GT7 won't brake even when I adjust the ESC to full brakes. When I come from a full speed run and let go of the throttle it coasts like 15-20 ft. Anyone know whats wrong? Thanks
DOMOisCOOL is offline   Reply With Quote
Old 08-15-2003, 05:57 PM   #2
Is your brake Expo in your radio set @ the maximum amount?
When you set the speed contol are you holding the trigger at full brake until the led blinks?
Try a different schotky diode(if it not the updated GT7 with the diode wired in already)
BrianJ is offline   Reply With Quote
Old 08-15-2003, 06:30 PM   #3
DOMOisCOOL's Avatar
Brake Expo or EPA?
The brakes worked before but now it doesn't
yah, the green LED blinks when I set the ESC.
Old 08-15-2003, 07:33 PM   #4
Herminator's Avatar
Send a message via ICQ to Herminator
I'm not electronics expert but it could be your brake FET's are blown, which depending on the manufacturer could be a cheap thing to get fixed or an expensive thing to fix. Never dealt with Novak myself. It may be something else all together, just an idea, as a club mate was getting interference problems when on full throttle and couldn't get rid of it, then someone had a go of his car and said were's the brakes? he said it had been like that a while, they were very weak, sent it back for repair and all was fine, it was an LRP I think.
Herminator is offline   Reply With Quote
Old 08-15-2003, 10:42 PM   #5
DOMOisCOOL's Avatar
I think I know the problem. Some guy told me that I had to turn off the ABS feature on my M8. Then re set up the ESC. Ill try it tomorrow.
Drag Brake on Novak GTB, LRP TC Spec rcjunkie3000 Rookie Zone 8 07-16-2008 09:28 AM
Novak Brushless binds up and wont turn RC Corral Radio and Electronics 4 07-03-2008 02:28 PM
Novak XXtra wont run electronics streetracer745 Radio and Electronics 5 12-18-2007 01:52 PM
ECS- Auto brake/Neutral Brake/Drag brake RC12L3a Electric On-Road 6 11-21-2004 10:10 PM
drag brake, brake and reverse imjonah Rookie Zone 3 07-24-2004 07:20 PM
