GM - Purple SX12 >
GM - Purple SX12
GM - Purple SX12
Old 08-14-2003, 08:56 AM
NMRCDude's Avatar
Default GM - Purple SX12
Was the GM SX9 not enough?
Check it out...
NMRCDude is offline
Old 08-14-2003, 12:46 PM
seaball's Avatar
i dunno that answer, but i was looking for an sx9 a few weeks back.
well i ended up going with the mtroniks m3 cubic. it is incredible. smallest esc i've seen. the drawback is that the schottky diode is external and the cap is large. i opted not to use the hidious factory supplied cap, instead using a standard version from novak. and now my schottky is fastened to the motor. a minor inconvenience.
when i got to the track with it, i saw someone with the sx9, and it's gaudy. small, but the switch is huge. with the m3, all the wires are external, so you set the length. i even shorted across the switch terminals so that i don't even use a switch. i like this alot.
just a strong recommendation for anyone in the market for an ultra small esc.
seaball is offline
Old 08-14-2003, 01:42 PM
rc-zombies's Avatar
Default Re: GM - Purple SX12
Check it out...
the SX9 has a motor limit...and the SX12 does not.
rc-zombies is offline
Old 08-15-2003, 11:56 AM
che
che's Avatar
The SX9 does not have a motor limit, but they they suggest nothing less than an 8 turn.
che is offline
Old 08-15-2003, 02:23 PM
anybody has specs for this esc? its not listed on their site..
and 8 turn limit is kinda enough, but unlimited is better
versa is offline
Old 08-16-2003, 12:08 AM
The M3 can only adjust the powerband by pressing the only switch on the top. And it is waterproof.
SX12 has a lot more adjustment than M3. It also has lower resistance and higher amp output than SX9. I just got one yesterday and it is amazing.
Kamen Rider is offline
Old 08-16-2003, 01:40 PM
Intelligentsia's Avatar
how much did you pay for the SX12?
Intelligentsia is offline
Old 08-16-2003, 10:00 PM
around HK$1400 around US$180.
I would also suggest Quantum 2 because it is also waterproof.
It will arive Hong kong very soon.
Old 08-16-2003, 10:20 PM
jfc_tech's Avatar
damn just bought the LRP Quantum competition and now they got the version 2 already...
anyway, anyone can suggest me the correct map(setting), default is no.2=off-road use. im into touring with my Tamiya EVO III??? thanks.
jfc_tech is offline
Old 08-16-2003, 10:22 PM
Stock or Modify???
For Stock, some people use mode 5 for maximum punch.
Old 08-16-2003, 10:32 PM
jfc_tech's Avatar
Stock or Modify???
Driving modified Team Echo S-Pro(Yokomo) 10X2 motor.
kamen, u in Hongkong? Im from Malaysia.
jfc_tech is offline
Old 08-16-2003, 10:45 PM
jfc_tech's Avatar
check this out...LRP quantum 2
jfc_tech is offline
Old 08-16-2003, 11:51 PM
That's the one. Waterproof and also some new functions in this ESC.
I am in Hong Kong.
Old 08-17-2003, 03:04 AM
jfc_tech's Avatar
the Quantum 2 is waterproof??? where i can this information???
Kamen, if i wanna order from you, in Hongkong, will it be cheaper to Malaysia?
jfc_tech is offline
Old 08-17-2003, 08:30 AM
TC3
TC3's Avatar
the quantum2 is waterproof, and the gm SX12W too !!
TC3 is offline
