Old 06-20-2008, 09:21 PM   #1
shadow102's Avatar
Trader Rating: 21 (96%+)
Default Problem with CC sidewinder and LRP 13.5
i recently picked up a used Castle sidewinder and LRP 13.5 motor to run in my 4cell VTA car. I am having some problems though when i pull the trigger on the remote fast the car will jerk and hesitate, it will also do this if i let off while i am rolling and pull back on the trigger hard like its trying to figure out how to keep the motor spinning. But if i roll on the throttle slowly it works fine. Anybody have any suggestions
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 06-20-2008, 09:56 PM   #2
rcdougie's Avatar
Make sure your Castle Link is the latest version available. The last update should of cured the sensored motor problem.
rcdougie is offline   Reply With Quote
Old 06-20-2008, 10:01 PM   #3
shadow102's Avatar
its up to date with version 1.7
www.nexusracing.com
www.go-rc.org
Old 06-21-2008, 01:09 PM   #4
shadow102's Avatar
did some motor and ESC switching...i tried running the LRP sensorless on my speedpassion ESC and it did the same thing but running it sensored it ran just fine so it looks like i cant run the motor sensorless
www.nexusracing.com
www.go-rc.org
Old 06-21-2008, 05:55 PM   #5
rcdougie's Avatar
You can shadow, I run a sensord novak 13.5 and a trinity 10.5 with my sidewinder. The 1.17 is the firmware, which is up to date but make sure you have the latest software which is 3.051. Restore back to all defaults too and see what happens.
Old 06-21-2008, 06:03 PM   #6
shadow102's Avatar
already tried that and it still didnt work...i think the issue is with the motor because it does the same thing when i hook it up to my speedpassion GT and run it uncensored
www.nexusracing.com
www.go-rc.org
Old 06-21-2008, 06:06 PM   #7
rcdougie's Avatar
Its also critical to have good batteries and connectioins. Give CC a call, thier support is top notch.
Old 06-21-2008, 07:03 PM   #8
Running a 17.5 sensorless using the high FDR and rollouts we use in the Trans Am class will likely not work all that well.
A 13.5 is the highest I've ever seen successfully driven sensorless.
BNiels707 is offline   Reply With Quote
Old 06-21-2008, 07:21 PM   #9
shadow102's Avatar
why would they not work that well running sensorless
BTW doing some more playing with the whole system but will a sidewinder even work on 4cells?
www.nexusracing.com
www.go-rc.org
Old 06-21-2008, 07:27 PM   #10
robk's Avatar
Trader Rating: 22 (100%+)
The Tekin R1 had problems driving 4 cell oval cars because of the gear ratios used there-similar to a T/A car. Sensorless is probably not ideal for high wind brushless motors
Old 06-22-2008, 11:41 AM   #11
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
The Sidewinder is not designed to run sensored motors. If you choose to run sensored motors it will hesitate on start up.
If you want to run sensored motors with the Castle system you will have to wait til the Mamba Max Pro comes out. It will have a sensor port for the sensored motors to plug into. Not sure how long til it comes out as I have not even seen a prototype yet but it is in the works.
ST Racing Concepts (STRC)
Old 06-22-2008, 02:48 PM   #12
hobbipro's Avatar
Trader Rating: 21 (100%+)
I was using a speed passion 13.5, and I believe I had to adjust the motor timeing to 12, or 15 and adjust it to start on high to help with the starts.
hobbipro is offline   Reply With Quote
Old 06-22-2008, 04:01 PM   #13
It has to do with how a sensorless speed control determines rotor position. It is harder for a sensoreless control to determine the position of higher wind motors then lower wind ones.
Since there is no rotor position sensor, the speed control has to 'guess' what position the rotor is in, and try to start the rotor spinning that way. If it guesses wrong, the motor may spin the wrong way. Making matters worse, since it is so hard to determine the position of the rotor of high wind motors (especially at low speeds), the speed control may not even be able to tell it has 'guessed' wrong for a second or more. Once the motor is up to speed it becomes easier for the speed control to determine rotor position so hesitation should go away.
My Tekin RS has some real difficulty with a 17.5 running in full sensorless mode. It gets even worse with a 21.5. I have to use sensors to get it to start acceptably.
As for your other question, the Sidewinder should have no problems with four cells, but I would still recommend picking up a sensored control.
WTB: Sidewinder ESC kavvika R/C Items: Wanted to Buy 3 07-30-2008 08:29 PM
WTB: sidewinder esc Yevins R/C Items: Wanted to Buy 0 07-26-2008 12:06 PM
Sidewinder 5700kv Setup Problem SDNitroGuy Radio and Electronics 3 06-27-2008 04:01 PM
m8 and sidewinder razataz Radio and Electronics 3 05-05-2008 05:17 PM
