Old 06-16-2008, 11:34 AM   #1
Trader Rating: 23 (100%+)
Default Discharging
ok, so i have a ice charger and i want to know if i can discharge my batteries on it. i have some gp 3300's energ 4600's and gp 3700's and i know that they say like 35amp discharge on the packs but will the ice sharger work although it only has 10amp discharge? if it does work, what amp should i use?
thanks for the help!
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 06-16-2008, 11:44 AM   #2
Yeti35's Avatar
It will take awhile to dump them on that but yeah you can do it.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 06-16-2008, 11:46 AM   #3
JCarr's Avatar
I'm not battery expert by any means, but I do know that you can discharge with the Ice charger. When using the ice for discharging I always did it at 10 amps. Most stand alone dischargers do it at like 30 amps. I think the benafit of the higher dicharge rate is that you will get a higher voltage. I'm sure somebody with a better knowlege on this will chime in.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 06-16-2008, 12:42 PM   #4
well i did it on my 3700 and i guess it worked, is the dchg. volt .9 v/c thing right? thanks guys!
Mike Adamec
Trackside Hobbies
Old 06-16-2008, 12:50 PM   #5
JCarr's Avatar
Yes that is correct.
Gorilla Size Racing
Old 06-16-2008, 01:00 PM   #6
ok, thanks for help guys
Mike Adamec
Trackside Hobbies
discharging koolkidd Electric On-Road 25 06-08-2007 02:43 AM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 11:58 PM
Discharging and Discharging Question jeffbhhs Electric On-Road 5 12-14-2006 06:34 PM
discharging wallstreet Rookie Zone 3 04-01-2005 07:12 AM
discharging pro3racer Electric On-Road 4 10-04-2003 08:11 PM
