Old 06-14-2008, 09:49 PM   #1
Default mongoose esc powering a novak SS17.5?
i have a rc12r5 1/12th scale pan car and will be running it in a 4 cell stock class on a small course. i wont need to go faster than about 22mph. so what if i used a novak SS17.5 and powered it through a Novak mongoose, will that be ok. hopefully that will be enough for a while until i get a better ESC.
benben10 is offline   Reply With Quote
Old 06-15-2008, 12:33 PM   #2
WTF!!!!!!
gasman is offline   Reply With Quote
Old 06-16-2008, 12:41 PM   #3
will the mongoose be able to handle the current? the mongoose is rated at 35 amps and the sensor plugs match. or will i be blowing up the esc?
Old 06-16-2008, 12:49 PM   #4
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
i'd say as long as the motors are pulling low amps on 4 cells, yes go right ahead,
its not my speed control...
Go with a cheap brushed route before you try this.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 06-16-2008, 01:11 PM   #5
The Bear's Avatar
and remember that once you hook up a full sized motor, you will void any warrantee....... so if/when it stops working,,,,, you are al done.
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Old 06-16-2008, 01:38 PM   #6
Charlie's Avatar
Hey Guys,
While we've not tested this yet, it sounds like it may be "okay". We'll have to do some pretty extensive running of this setup before we sign off on it. We'll try to have this done and keep everyone posted, but I'm guessing it will be a "while".
You can always email us directly via "[email protected]".
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 06-17-2008, 12:58 PM   #7
i was getting around to emailing novak just havent yet. this was just and idea for a stop gap measure for now. are there any capacitors i should look into adding?
Old 06-17-2008, 01:02 PM   #8
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
they will jsut tell you not to do it, and it would void warranty, i think
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 06-17-2008, 01:12 PM   #9
sportpak's Avatar
Trader Rating: 26 (100%+)
It sounds like they kind of want us to try it.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 06-17-2008, 01:13 PM   #10
i would love to see someone do it. it would be the lightest brushless out there, lol
Old 06-17-2008, 05:14 PM   #11
Charlie's Avatar
I'm sure it's doable and will "probably" work fine. I can't really give to many recomendations at this point as we simply have not had time to do anything but basic function tests.
I know there is a youtube video of a guy doing this all on his own.....
From what i've heard he simply wired up his motor to the ESC and away they went.
When we get more time to sit down and run it/test it the way we'd like to, we "may" release official 540 size motor limits, but then again, we may not.
Old 06-18-2008, 09:42 PM   #12
i sent an email to novak tech. i would really like to know if this is in the ballpark numbers wise, from what you have seen the SS17.5 do. maybe some dyno info or at least some numbers from a dyno, if you dont want or cant release an entire pretty graph.
also where is this youtube video you speak of. i couldnt find much under "novak mongoose"
Old 06-19-2008, 08:31 AM   #13
yeah, me neither, i searched.
Old 08-21-2008, 03:16 PM   #14
SWTour's Avatar
Has anyone ever done anything with this?
I'm looking at wanting to try it with the Novak 21.5 motor and LIPO too...
For OVAL racing the 21.5 motor only averages 15.5 amps over a 5 minute run...(With the bigger voltage)
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 08-21-2008, 03:37 PM   #15
Company Representative
Why don't you be the first one to give it a try?
NovakTwo is offline   Reply With Quote
Novak Mongoose frogger Micro and Mini Scales 601 08-05-2015 09:08 AM
Novak Havok=Mongoose? YmeBP Electric On-Road 10 09-10-2008 09:26 AM
Novak Mongoose JeromeB Micro and Mini Scales 132 03-21-2008 06:31 AM
Novak Mongoose syndr0me Electric On-Road 3 01-06-2008 02:43 PM
Novak Mongoose syndr0me Radio and Electronics 4 10-19-2007 06:40 PM
