Old 11-04-2012, 04:07 AM   #856
Joost K.'s Avatar
From the looks and the inbetween spacing I think you are correct. Only they look like 3mm holes and the battery holders are mounted with M2,5 so... '
Hopefully someone from Associated can shed some light on this???
The On-Point body mounts won't fit. The standoff position is different from the new 10R5.1
I think I will draw some new ones and CNC them for the car if needed.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 11-04-2012, 08:31 AM   #857
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Joost K. View Post
Can anyone tell me why there are two pair of extra holes on the side of the chassis next to the chassis braces? I thought it would be to place saddle-pack lipo's but there is nothing in the manual aboout that.
Maybe for the brass weights?
http://www.teamassociated.com/parts/details/31296/
Looks like a 2S would fit in there too..
Can't wait to see it next week!
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\MIP\JConcepts\Schelle\ProlevelRC
Logi Maker is offline   Reply With Quote
Old 11-04-2012, 08:37 AM   #858
Joost K.'s Avatar
Good one!!! Those were not in the parts list of the 10R5.1 but now that I see it I agree...
Old 11-04-2012, 08:39 AM   #859
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Attachment 988694
ahh
that makes sense
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-04-2012, 10:07 AM   #860
Logi Maker's Avatar
I finally contributed!!!!
Kyle Predmore
Old 11-04-2012, 10:18 AM   #861
Joost K.'s Avatar
Good boy!!! Now you can have some extra marsmellows in your hot coco...
Old 11-05-2012, 11:20 AM   #862
AdrianM's Avatar
I just pre-ordered my 10R5.1 from Stormer Hobbies. I called AE and they said kits are being packed now and should ship in 2-3 weeks.
I was on the fence between this kit and the SpeedMerchant World GT3. They cost the same but I wanted to run the R5 front end so that sealed the deal.
There are a lot of things to like on this kit.
The extend shock mount on the rear pod plate is an option on other kits.
The thru-shaft shock is nice to build and eliminates the cocking/friction of the piston and shaft under compression.
The split damper tube plate allows for very tidy wiring.
The stiffening rails are an interesting feature. I think you could use them as a tuning option. It looks like you could run the car with or without them.
Adrian Martinez
Old 11-10-2012, 12:37 PM   #863
samshirley00's Avatar
after setting up a large track today, i took my RC10R5 out for a spin, the only motor i had spare was a 13.5 one, so i tried that on 2s
HOLY F**K THIS THING IS SO FAST i thought down the back strait, but i was having a small issue with screws popping off, so threadlock it tonight.
got a 10.5 on the way so i can run 1s, can't wait to give it a proper go
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 11-10-2012, 01:53 PM   #864
Pro10noob's Avatar
I run my 10R5 always with 2S and a 10.5 motor on the larger outdoor tracks
It is a blast to drive
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-16-2013, 10:48 AM   #865
CFR
CFR's Avatar
Associated Rc10R5.1 Left Wheel Hub 8610
Will this fit the RC10R5 and still keep the rear width the same? Has two screw fixing rather than one.
CFR is offline   Reply With Quote
Old 08-30-2013, 03:06 AM   #866
Oryginal left hub should be modified for 2 screws then it works perfect.
99% that new one will fit 10R5.
I saw in manual that in .2 they use again 2 washers on axle and at old one 10R5 there is also two washers.
It should work without problems.
Two screws like IRS style works better, no moving hub on axle, I just
rebuild old left hubs for 2x inch screw, it need some work but it is worth
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-09-2013, 03:01 PM   #867
Trader Rating: 15 (100%+)
Is the 10R5 still competitive?
Website: http://michaelsasher.com
masher81 is offline   Reply With Quote
Old 09-11-2013, 03:07 AM   #868
Yes.
It is good car.
Maybe few things to change
Michal Abramowicz
Old 09-11-2013, 08:08 AM   #869
What changes?
Old 09-11-2013, 02:08 PM   #870
I coulda sworn i saw 10r5.1 oval kit somewhere
Bubonic-X is offline   Reply With Quote
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
