Old 10-05-2012, 05:28 PM   #811
need some work
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-15-2012, 10:20 AM   #812
tlb987's Avatar
I was wondering if anybody else had problems with the steering servo and the mounts. I can't get anything to line up correctly. I don't want to drill into the chassis for a number of reasons, one of them is I don't have a drill press and I was hoping you guys or girls had an ideas i could use. All the help would be greatly appreciated.
tlb987 is offline   Reply With Quote
Old 10-15-2012, 10:37 AM   #813
Chaz955i's Avatar
The stock chassis is designed for Futaba servos. I ran JR servos and just shoe goo'd the servo directly to the chassis. Plenty strong and easily removable if needed. There is no reason to drill more holes in the chassis for different servos.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 10-15-2012, 10:46 AM   #814
AdrianM's Avatar
+1
Most of the fast guys shoe goo their servos even if the mounts line up. This reduces the chance of a trim change in a crash.
I really wish AE would update the 10R5 with the 12R5.2 pod and damper tubes. They would just need a new lower chassis plate,a Lipo bridge and some stand offs. Without all the holes the lower chassis would cost less to produce. All the rest of the parts would stock items from the 12R5.2.
Adrian Martinez
Old 10-15-2012, 10:46 AM   #815
Pro10noob's Avatar
Weird as i have a normall servo in there without problems.
I use TC5 servo posts and a DS1015 servo.
Mind you tho that my chassis(new) came with 2 mounting holes direct next to each other on one side.
If you don't have that then use a Savox SH1257MG servo.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-15-2012, 10:56 AM   #816
tlb987's Avatar
I tried putting in an AE servo and it didn't work I will try a savox I have them in some of my other vehicles. Thank You!
Old 10-15-2012, 10:57 AM   #817
AdrianM's Avatar
AE, I would buy this if you made it with the 12R5.2 damper tubes and a center Lipo option. I think this 12R5.2 Lipo setup would be better on asphalt/low grip carpet and the center/forward would be better on high grip carpet.
Adrian Martinez
Old 10-16-2012, 10:07 AM   #818
tlb987's Avatar
So I was thinking about going the shoe goo route. You guys that have tried it are positive it really works? My servo won't fall out mid race?
Old 10-16-2012, 10:30 AM   #819
AdrianM's Avatar
So I was thinking about going the shoe goo route. you guys that have tried it are positive it really works. My servo won't fall out mid race.
Clean your chassis and your servo with motor spray and a paper towel. Put a thin layer on the bottom of the servo so just a tiny amount of goo will squeeze out around the perimeter of the servo. Let it dry 2 hours and you are good to go. You could obliterate your car and the servo will stay put.
If you want it to come off just disconnect the links, twist the servo hard and it will pop off. Any remaining goo will pull off the servo and chassis cleanly. Shoo Goo is amazing stuff.
Adrian Martinez
Old 10-16-2012, 10:33 AM   #820
PutAwayWet's Avatar
Have no worries about the Shoe Goo thing. It is an ancient and respectable pan car servo mounting method. Just make sure both surfaces are clean, apply a single thin continuous layer, press into position, and let it dry overnight.
Any crash that jars it off the plate will simply make it easier to glue it to the new plate you'll be buying to replace the broken one. It's solid.
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 10-16-2012, 10:51 AM   #821
tlb987's Avatar
Thank you for all the help I really appreciate it!!!!!
Old 10-16-2012, 12:09 PM   #822
Chaz955i's Avatar
Another option which a lot of guys at my track do is use servo tape to lock the servo into position and them run a bead of shoe goo around the perimiter of the servo. Extremely secure and a little easier to remove the servo later on. Nothing wrong with just going the shoe goo route. Just wanted to present another option. Main thing is to make sure the surfaces are clean, as a few have already pointed out.
At The Gate Bizzos
Old 10-17-2012, 08:49 AM   #823
tlb987's Avatar
Thanks again for the help. i have been running RC cars for a long time but, this is my first time I am going to try and race one.
Tim Buchman
Old 10-17-2012, 11:05 AM   #824
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Still curious why the damPer tubes are so great. Its super easy to maintain the mono shock.
valk is offline   Reply With Quote
Old 10-17-2012, 11:38 AM   #825
I.T.Guy's Avatar
I honestly found the mono shock system to be a big PITA! so nice to slide the tube out, clean and change the fluid. (less than 2 mins). also, I seem to get much finer results with tubes.
www.5280Raceway.com | Racing. Elevated.
I brake for Drake's Coffee Cakes...
I.T.Guy is offline   Reply With Quote
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
