Old 12-09-2011, 06:43 AM   #736
MarkBurgess's Avatar
Originally Posted by Skiddins View Post
Thanks Mark.
Am I reading previous posts correctly, that people have managed to use the 'side bars' instead of the side shock for the pod?
I find mine leaks quite often and removing it is a pain. The idea of the bars with grease on them is very appealing
Skiddins
I've never had any problems with the side shock leaking Skiddins!
It is easy to cross thread the plastic shock top if you try to force it onto the metal shock body before it's straight. You also need to get the o-ring as low as possible before putting that shock top on...I run a small allen driver around and around the plastic spacer and get all the excess oil removed.
Best tip I heard to seat the shock top was to first rotate it slowly backwards. You'll feel a slight "click" as the two threads pass each other. And that's the time to start winding it in the correct way. If it doesn't screw in smoothly or isn't straight then on do it and start again.
There are side damper conversions...seen both one offs and some kits. Speak to Jason Butterfield about his DoRi5 chassis if you're interested
cheers
Mark
MarkBurgess is offline   Reply With Quote
Old 12-09-2011, 06:53 AM   #737
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thanks Mark.
Skiddins
cheers
Mark
12R5 shock build tips
http://www.rctech.net/forum/9531918-post2927.html
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-09-2011, 08:54 AM   #738
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Just dug my RC10R5 out of the cupboard with a view to running it for the first time in 18 months.
How are you guys securing your lipo's to prevent them moving during the race.
I used to use cell tape coming through the two outer '4-cell' holes but this never seemed to stop all the movement.
It's almost like we need different battery position pieces for the chassis.
Skiddins
Take a looksy at the Rebel 12 battery brace that sits behind and slightly wraps around the battery. Then on the 10r5 where the back battery blocks are its the same width. You might have to countersink those holes just a bit. Its what I use along with tape and I never have problems with the battery comming loose and rubbing the links. Sometimes the braces do break from a hard hit or crash but for the most part for $2.00 there worh it.
Josh-n-ya is offline   Reply With Quote
Old 12-09-2011, 09:03 AM   #739
Skiddins
Servo tape lexan strips to the bottom of your lipo packs.
I cut the lexan a bit narrower than the width, and about half the length of the battery slots, that way you can move the lipo around for weight bias.
Lexan locks the cell from moving sideways, tape holds it for & aft.
Old 12-09-2011, 09:12 AM   #740
The Reedy packs I was using had bumps molded in the case to hold the battery in place.
My new packs do not have any so I stuck on small drawer bumpers. They fell off after a few heats and I never noticed any adverse effects from the battery moving 1 - 2mm from side to side. Now I just tape the battery in a go race. BTW, my lap times kept getting better as the bumpers fell of, maybe it helps that the battery shifts slightly.
AreCee is offline   Reply With Quote
Old 12-10-2011, 01:43 AM   #741
Default Ride height adjusters
Originally Posted by Bumpy View Post
Why not just get these ones. http://www.amainhobbies.com/product_...ight-Adjusters
I use them in my AE pan cars with no problems. They're great.
OKIDOKI ;-)
Kensei is offline   Reply With Quote
Old 12-11-2011, 06:48 PM   #742
Chaz955i's Avatar
Looking forward to running my 10R5 for the first time. Purchased it used and as an added bonus the clown who assembled it decided to take a SAE stainless screw kit and jam them up into metric holes. Now that I'm past that issue just rebuilding and waiting on electronics.
Quick question. Anybody running a JR3650 and does it center on the chassis with the Associated mounts? If not does anyone make mounts that will fit or is the solution just to shoe goo the servo down?
Thanks,
Chuck
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 12-11-2011, 10:27 PM   #743
LonnyJ1950's Avatar
The JR will not mount correctly using the stock mounts. I don't know of a servo mount that will fix this. I just found a Futaba 9650 and it fits perfectly.
Lonny
LonnyJ1950 is online now   Reply With Quote
Old 12-12-2011, 07:27 PM   #744
nrtv20's Avatar
Default Right side Hub
I have an old 10L2 car that I am thinking about making into a WGT car using some home made parts and some 1/12 scale stuff I have. I need some help with the right side diff hub, if you look in the pictures I am going to try and use a 1/12 scale rear pod with my 10L2 axle and diff. It is currently 1/4 in too wide and I would like to know what is the width of the right side hubs on the new 10R5 car?
My hub is 1.4" long or 36.5mm. Like I mentioned I am hoping you guys can help me out and see if anyone makes a hub that is between 1.1 - 1.15 or something close I can make work.
Thanks for the help!!!
Team Associated Factory Team RC10R5-wp_000293.jpg   Team Associated Factory Team RC10R5-wp_000294.jpg
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 12-12-2011, 08:06 PM   #745
Chaz955i's Avatar
Thanks Lonny.
At The Gate Bizzos
Old 12-22-2011, 10:52 PM   #746
Post
top
THEBIGBULL is offline   Reply With Quote
Old 12-23-2011, 05:07 AM   #747
rcgen's Avatar
I am have problems with my left side hub loosening up. Is anyone else having this occurring too? I race oval also and having the same problem with the left side hub also. Both cars are R5
rcgen is offline   Reply With Quote
Old 12-23-2011, 05:14 AM   #748
Pro10noob's Avatar
Try changing the left hub to a IRS item.
These have 2 clamping screws and hold better.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-23-2011, 05:57 AM   #749
I use a product that you can find in a bicycle shop it is a carbon fiber assembly compound. A little dab on the carbon axle will keep the hub in place without overtightening the screw or damaging anything.
Old 12-23-2011, 06:13 AM   #750
Now I never had a problem with mh LHS hub...but I know others that have.
+1 recommendation for the IRS LHS hub as a replacement. It uses two big screws to tighten the hub to the axle. Does need spacing out a fair bit, and I found the big diff cones were spot on to get the spacing right.
Hope that helps,
Mark
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
