Old 12-01-2011, 09:56 AM   #721
I.T.Guy's Avatar
Originally Posted by Josh-n-ya View Post
Running middle worked a lot better!
Thanks for the follow-up, I'll move it to mid and test it in the next few days.
Ever since I started saucing the entire fronts, the car has felt great (no more pushing). I'm wondering if repositioning the WB would've helped with the pushing i had. In any event, I'll give it a go and see.
I.T.Guy is offline   Reply With Quote
Old 12-01-2011, 11:03 AM   #722
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Did you make any other adjustments Josh.
or did the WB alone have an effect on the handling ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-01-2011, 08:36 PM   #723
AMZ
AMZ's Avatar
RedBull,
Do you prefer the inline or trailing steering block/axle for carpet roadcourse ?
And if you don't mind,can you tell me why?
AMZ is offline   Reply With Quote
Old 12-01-2011, 11:03 PM   #724
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Sorry, whats WB? My first run rear was slidding around. Side to side movment was way to loose on pod. I tightened up pivot and a half turn in on side springs. It got a little better, stearing was good but think I needed maybe 50wt in rear dampner shock instead of 40wt. I didnt make the main cause wife called and said power was out and wanted me home. I am going to try to run dampner tubes like I installed on my 12r5 and it works great. I am still learning about ramping and am trying set ups. This hobby is like a full time job! You will be here this weekend right?
Josh-n-ya is offline   Reply With Quote
Old 12-02-2011, 07:29 AM   #725
Sorry, whats WB? WheelBase My first run rear was slidding around. Side to side movment was way to loose on pod. I tightened up pivot and a half turn in on side springs. It got a little better, stearing was good but think I needed maybe 50wt in rear dampner shock instead of 40wt. I didnt make the main cause wife called and said power was out and wanted me home. I am going to try to run dampner tubes like I installed on my 12r5 and it works great. I am still learning about ramping and am trying set ups. This hobby is like a full time job! You will be here this weekend right?
Change of plans won't be up there next weekend as I had hoped.
AMZ.
I have always preferred inline axles for 10th scale indoors, the feel is more direct.
Old 12-02-2011, 08:09 AM   #726
Sorry, whats WB?
WB = Wheelbase
AreCee is offline   Reply With Quote
Old 12-02-2011, 09:51 PM   #727
Josh-n-ya's Avatar
AMZ.
Same as for me. I wont be there either. New job!
Old 12-08-2011, 11:14 AM   #728
Default RC0R5 height adjusters
I see here is one set in the kit.
Do I have to get me some extra?
If so, which ones?
For instance:
http://www.amainhobbies.com/product_...t-Spacer-Set-8
Kensei is offline   Reply With Quote
Old 12-08-2011, 11:41 AM   #729
LonnyJ1950's Avatar
That's one of 3 trees you would need to have a complete CRC set. Look at the bottom of the page fro the other 2. They adjust in .25mm increments. You can also use these which go in .5mm increments:
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-09-2011, 01:15 AM   #730
If so, which ones?
For instance:
Why not just get these ones. http://www.amainhobbies.com/product_...ight-Adjusters
I use them in my AE pan cars with no problems. They're great.
Bumpy is offline   Reply With Quote
Old 12-09-2011, 01:24 AM   #731
Pro10noob's Avatar
They look the same as the IRS1167
Those are the one i am using.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-09-2011, 03:11 AM   #732
Skiddins's Avatar
Just dug my RC10R5 out of the cupboard with a view to running it for the first time in 18 months.
How are you guys securing your lipo's to prevent them moving during the race.
I used to use cell tape coming through the two outer '4-cell' holes but this never seemed to stop all the movement.
It's almost like we need different battery position pieces for the chassis.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-09-2011, 03:26 AM   #733
MarkBurgess's Avatar
Morning
I try to get as much contact patch between the tape and the underside of the LiPo. So I'd been running the tape under the two outside cell slots, then bringing it to the top across the middle three "bars".
So...around the top of the cell, stuck to the outside "bar" and up through the outside cell slot. Across the rest of the slots to the outside cell slot the other side.
For flat bottomed cells I've found strateic placement of speedo and a weight will stop the cell moving forward in a shunt. Tape alone hasn't been enough.
Hope that helps,
Mark
MarkBurgess is offline   Reply With Quote
Old 12-09-2011, 03:37 AM   #734
Skiddins's Avatar
Thanks Mark.
Am I reading previous posts correctly, that people have managed to use the 'side bars' instead of the side shock for the pod?
I find mine leaks quite often and removing it is a pain. The idea of the bars with grease on them is very appealing
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 12-09-2011, 03:48 AM   #735
Pro10noob's Avatar
If your shocks are leaking that often, isn't it time to replace the O-rings?
Perhaps with another brand?
Sometimes the original arn't that good.
I have had this problem with some shock parts from other brand cars and mixed and matched other parts on a original shock and the problems where gone.
Most of the time it is the pistonguide that causes the problem because of to much play.
regards Roy
l===/o\===l
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
