Old 11-21-2011, 02:16 PM   #661
Default RC10R5 diffballs
I see there are 6 diffballs in the kit.
The spur has more holes.
Is 6 diffballs usually the way to go?
Or can more diffballs be used?
Or might more diffballs be necessary in some cases?
What does define the number of diffbals to use?
For instance the power of the motor, or other criteria?
Kensei is offline   Reply With Quote
Old 11-21-2011, 07:51 PM   #662
LonnyJ1950's Avatar
OK. Reiterate: Go to your track and learn from the guys there. A few answers; fill the holes in the outside ring of your gear with balls, all the holes. Make sure that the front suspension moves absolutely freely, then apply a light coat of your 60K to the bottom of your kingpin where it passes through the lower suspension ball. Yes it acts as a damper, it's more effective on a bumpy track, if your track is smooth you may not need it. A lighter fluid (30K or 20K) will give a softer effect. If you're serious, you renew it for every run, if you're more relaxed once a day can work. Paragon can work on any surface, though the surface must be clean as Paragon will cause the tires to pick up. It's usually best to use what the other racers are using. The Jaco tires are less well liked because the yellow stripe they use to ID the tires seems to affect the grip they produce. Good luck and don't get discouraged, it takes a while to get up to speed.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 11-24-2011, 12:47 AM   #663
Default RC10R5
No answers on this side of the Atlantic as to what product exactly is 60K, 30K, 20K.
So back to this thread, as I knew upfront!
What is the exact (commercial) article description, as to 60K, 30K and/or 20K?
Old 11-24-2011, 12:54 AM   #664
Pro10noob's Avatar
Perhaps i am understanding it wrong but i hear we go.
They are meaning with 60K 60.000 oil as normally used in nitro gear diffs
It is the value that indicates the thickness of the oil.
So 30K is 30.000 and so on
It is used on the kingpins to smoothen it's action and give a bit of dampening.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-24-2011, 04:35 AM   #665
Default 60K
Thanks Roy,
So that is cst value?
Any sillicone oil will do?
Old 11-24-2011, 04:55 AM   #666
Pro10noob's Avatar
You got different ratings about the oil.
You got WT like Losi and Associated and you got CTS and CPS.
It is indeed the value for the thickness of the oil
What do you have at home or what is your LHS selling??
Regards Roy
Thanks Roy,
l===/o\===l
Old 11-24-2011, 10:43 AM   #667
MarkBurgess's Avatar
I run two rows of 6 - the outside row can only go in one set of holes, and I'd put the inside holes that are between those. It will make sense when you have the spur gear in front of you.
It gives more contact patches, and uses two spots on the diff rings for this.
Whilst I run 10.5 with advance which is pretty quick, I've always run 12 diff balls for 12th and GT
MarkBurgess is offline   Reply With Quote
Old 11-24-2011, 10:47 AM   #668
It's the thickness of the oil or grease used. If you've every run Nitro cars or had a Touring fonr gear diff then you'll know more about those. I haven't so like you have had to ask.
The idea is the grease add a further level of damping to the front springs. Smear it on over the spring to get that. Check it from time to time, and if it looks like the grease has gone or too much fluff on the spring then clean and re-fit. (not unlike side damper tubes).
Personally I run the longer 10R5 springs, and run them dry without any oil. Make sure the suspension pin moves smoothly up and down and you'll be fine. A 1/8th reamer can help with the hub, and spinning the pin in a Dremel and polishing with a very fine glass paper (or wet and dry) can also help.
Old 11-24-2011, 10:53 AM   #669
Default Difballs
I think I understand:
you mean six balls in the outside row, as seen on the pic in the manual and six balls in the ring of holes, the inner circle. one ball everytime in between two the outer balls.
The diffring is wide enough for that so it seems.
So two circles of six difballs is better than one of twelve.
Because as you say it gives more contact patches, and uses two spots on the diff rings for this.
Anyway, extra difballs have to be bought. Any preferences?
Old 11-24-2011, 10:59 AM   #670
Pro10noob's Avatar
Always use ceramic balls.
They last longer and are smoother.
regards Roy
l===/o\===l
Old 11-24-2011, 11:02 AM   #671
Default Front shock
Interesting. But I thought the grease or oil was to be put on the kingpin. The pivot ball in the suspension arm moves over the kingpin. Because the kingping is greased there is some sort of dampening. I think that is the way I am going
to do it, at least if and when the track isn't that smooth.
Or am I barking up the wrong tree here? (hope not......)
Old 11-24-2011, 11:28 AM   #672
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Here is a pic of the 10R5 I've been racing in 1s 13.5 blinky WGT form.
As you can see the lipo is mounted well forward, giving the car good weight distribution, which has resulted in a very consistent car during the entire 6min run, usually only .2 to .4s drop from start to finish.
To move the lipo as far forward as possible in the standard configuration 2mm shims were added under the front shock mount.
Inline axles provide the most steering possible from my experience with this car thus far.
The rest of the setup is essentially kit
40wt center, red spring
80wt side, gold spring
Pod flat, 1mm droop
.020" front springs, no droop
Short Wheelbase
52mm BSR Spec tires Fr & Rr
4mm RH
Powered by MurfDogg 13.5 Synergy: 10deg timing, 92roll
MurfDogg SuperCharger 60C 1s lipo
In "Club Race" format the car weighs in at 890gr
Haven't seen many pics of 10R5's here lately
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-24-2011, 11:37 AM   #673
Pro10noob's Avatar
Nice car.
Got mine this week.
Need to get me some electronics in it so i can drive it
Also thinking on converting it to 235MM
This because we drive WGT just in the winter time indoor and 235MM summertime.
Hmmmmmmmmm........
l===/o\===l
Old 11-24-2011, 11:43 AM   #674
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Man. That is a sexy machine right there. If you ever wanna get rid of it lemme know.
Looking for a 10r5 for next summer. Or buying parts to convert a 12r5.1. Seems easier to convert. No
One seems to carry this car =(
valk is offline   Reply With Quote
Old 11-24-2011, 11:46 AM   #675
Thanks.
If you live in the US, AE sell the car through their online store.
http://order.aeteam.net/product_deta...?Itemcode=8020
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
