Old 08-21-2008, 09:12 PM   #46
I am thinking of buying the 10r5 kit to replace my old HPI 10g pan car. With the 10r5, do I need to buy small servo that is normally required by 1/12? Can I use the standard servo for TC?
azmio is offline   Reply With Quote
Old 08-21-2008, 10:16 PM   #47
mkdut's Avatar
Trader Rating: 19 (100%+)
It appears to take a mini servo. Give me another couple of days and I will report back.
mkdut is offline   Reply With Quote
Old 08-26-2008, 10:31 AM   #48
Send a message via ICQ to CivicTuning
Hi guys !
I am planning to buy one as well.
But as said before, what lipo will we use if any ?
The price for the 10R5 is ok, a lot cheaper than the Corally 10X.
I would like to start a class over here as well.
I would love to hear back when someone has his 10R5 already
Just my 2 cents
Many RC greetings from Belgium.
CivicTuning is offline   Reply With Quote
Old 08-26-2008, 12:50 PM   #49
No LiPo possible in these cars. Voltage is all wrong, and the reduced weight means the cars won't have any traction, or any steering. You need to run 4 x NiMh cells to have a chance of being competitive - sorry!
EnerG and EP cells are now very good, and we find them to be lasting a long time with good performance. They don't go flat during storage for about eight weeks (put in 2000mAh to store) and they don't overheat during charging. Very good cells.
I ran my BMI DB10R last week with a 12 x 2 on 60mm/rev, with EnerG cells, and was as fast down the straight as drivers using 5.5BL. This is a cheap class, and great fun to drive. Don't worry about LiPo, use NiMh for more smiles per drive!! HTH
SlowerOne is offline   Reply With Quote
Old 08-26-2008, 02:05 PM   #50
Send a message via MSN to afonsospt
Im very interested in a car like this.
Does rc10R5 kit includes body and tires?
Which bl motor(nš of turns/kv) do you guys recommend for 4 cells on a 1/8 track(big for 1/10)?
I have a 5.5T GM-Racing motor waiting to be mounted on a car,but not sure if its ok for this car.
Thanks in advance
afonsospt is offline   Reply With Quote
Old 08-26-2008, 03:39 PM   #51
Thanks for the reply Slower One
I will put in 4 nimh cells then.
Is there a big difference in power and run time compared to lipo ?
How long do you run with your 12x2 motor ?
i have a 5.5 BL and an LRP TC Spec already waiting to put in the R5 as soon as i order one
Greetings,
Christoph
Old 08-26-2008, 11:41 PM   #52
Greetings,
Christoph
NiMh cells are usually more powerful than LiPo, but that isn't a problem in this class - there is much more power than grip!
Our races are five minutes long, or do you mean how long does the motor run between rebuilds? If it's the 'rebuild' question, I don't know, as this is the first time it was run. It looks OK, so I will run it again this weekend.
5.5BL is OK with four cells, and the Sphere is a good speedo. You should take off the fan - it is not needed and it will probably not fit under the bodyshell. HTH
Old 08-27-2008, 12:55 AM   #53
Hi SlowerOne,
Most of the lipo guys run like 10-15 minutes on their batteries until they have to recharge.
That was my question, when are your 4 cells dead, after 8-10 minutes ?
Anyone have their 10R5 already ?
Greetz,
Christoph
Old 08-27-2008, 02:10 AM   #54
ffactory666's Avatar
Hi guys !
Just my 2 cents
You can run lipos in the Bmi DB10R which SlowerOne drives , it was designed around them and you can get a weighted lipo tray for it to bring the cars weight to the same as 4 cell nimh
I was thinking about getting the RC10R5 and still might one day but have gone with the Bmi car since it lipo friendly and that's all i run .
ffactory666 is offline   Reply With Quote
Old 08-27-2008, 03:20 AM   #55
The RC10R5 has the same tray for batteries (4), so if there is a need for lipo, AE will make something, i think.
I the meantime i will run nimh
Greetings,
Christoph
Old 08-27-2008, 08:57 AM   #56
or should i buy a corally 10X with saddle pack lipo possibility ?
Thanks for your answers
Greetz,
Christoph
Old 09-09-2008, 12:16 PM   #57
74VWTECH's Avatar
Does anyone have a setup from vegas for the 10r5. I just picked one up and was looking for a good starting point on the Lilac tires.
Fantom Racing * CB's Custom Cut Gears * 92zero Designs * Stiky Liks Racing Concepts * Leisure Hours Raceway * Trackside * Race'em RC
SC5M, B6, T5M, RC10 Worlds
74VWTECH is offline   Reply With Quote
Old 09-09-2008, 05:02 PM   #58
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Hey ryan i am just curious ... were you going to run the 10r5 at the halloween classic ? Cause i dont think anyone has a car yet by us
wallstreet is offline   Reply With Quote
Old 09-09-2008, 06:47 PM   #59
AE-Reedy
Regarding the set up sheet for the IIC I think we have posted it.
If not I will check and make sure it gets on soon.
Myself I ran the first practice with the car as it came from the kit box and it was really good. As the grip rose and the competition heated up I made some minor tweeks to get just a bit more steering. The car is very good in kit form, nothing is required to upgrade the car, just bolt on the spec tires and the body of your choice and you should be competitive.
Sean Cochran is offline   Reply With Quote
Old 09-09-2008, 10:24 PM   #60
74VWTECH's Avatar
Thanks Sean, I appreciate the help. When installing the side springs, it tells you to bottom out the screw in the retainer. But doesn't say how to adjust them. My guess was to adjust the tweak in the car.
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
