Old 11-24-2010, 03:24 AM   #556
Foxxrocket's Avatar
I would hold off from making any major changes to the car. Run is as you would normaly, and see how it handles. Just take out as much steering as you're comfortable with then set camber and toe to "0".
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 11-24-2010, 05:52 AM   #557
Trader Rating: 28 (97%+)
I have one 10R5 that I will be running with the starndard layout. I should be recieving a 2nd 10R5 on Friday. This is the one I was thinking about experimenting with. Our local track changes back and forth from a road course to oval course which is why I was considering an oval setup for the 2nd car.
I really prefer running the road course, but unfortunately it is only setup once a week and the oval course is setup the remainder of the week. I am not really interested in oval, but figured I should give it a shot since I have never tried it.... I was just looking for a cheap way to try it without replacing/buying another chassis.
Funky is offline   Reply With Quote
Old 11-24-2010, 09:03 AM   #558
Foxxrocket's Avatar
Right now I'm running a 20 spring on the left front and 22 on the right front. Double golds on the rear sides and a blue center spring. 5.4mm preload on right and 2.7mm preload on left. Center spring is set to 2.7mm as well.
Old 11-24-2010, 10:10 AM   #559
Foxxrocket's Avatar
Hey, I found something that might catch your eye. 10R5 not oval
Old 11-24-2010, 10:23 AM   #560
hey all.. i just raced my 10R5 this past weekend, and it was doing well, but then i started to learn more about it, and my ride height was well off... so now im running all 3 of the kit washers on each screw in the front to lower it as much as possible... and i still can go lower...
so my question is, would it hurt to get another package of those washers and just use alittle longer screw?
reason is, im using full tires (not trued) and i dont have a tire truer yet, and probably wont until spring (taxtime)
im probably sitting at 6 or 7mm ride height in the front, and of course for WGT min. is 4mm...
thanks for any and all info.
honhon is offline   Reply With Quote
Old 11-24-2010, 02:49 PM   #561
Foxxrocket's Avatar
That's what I do. I just run them the way they come, and adjust the ride height to the taller tiers.
Old 11-24-2010, 03:05 PM   #562
Thanks Foxxrocket!! I really appreciate the info
Old 11-24-2010, 08:41 PM   #563
jammincrtjames's Avatar
Anybody have a rollout spur/pinion set-up for a track with an 80 foot straight?
Also, anybody have any Tekin setups fo WGT running 1-cell? I run TC and we are going to start a class at my local track?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 12-11-2010, 04:42 PM   #564
I just noticed on the Team Assocoiated web site that have the FT 10R5 as discontinued.... Why has this been discontinued? Will it be replaced with a 10r5.1 version??
Big Marv
Ultramarv is offline   Reply With Quote
Old 12-16-2010, 01:21 AM   #565
stipres's Avatar
Trader Rating: 70 (100%+)
anybody....
Pres Ilog
AKA Products, Team Losi, Track Star Racing, Tekno RC, Hitec RCD, LRP, Schelle Racing, Imagine It Graphics, EKD, VP/PowerMaster fuels
stipres is offline   Reply With Quote
Old 12-16-2010, 04:06 AM   #566
+1
Old 12-16-2010, 12:56 PM   #567
Old 12-16-2010, 01:39 PM   #568
pakk's Avatar
Trader Rating: 79 (100%+)
It only seems like the natural move. It will probably just have the updated rear pod. Hopefully it has different battery mounting options to be more pro 10 friendly.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 12-19-2010, 09:12 AM   #569
CFR
CFR's Avatar
How to get the car to rotate in the corner.
Car turns in OK and drives out OK but just can't get it to rotate at the apex.
Front
Inline axle
0 degree blocks
Long wheelbase
0.20 front springs
1 camber
1 toe out overall
5.5mm rideheight
Rear
Pivot balls lowered 0.6mm including side links
Red centre spring
Gold side springs just touching
2mm droop (when you lift chassis from ride height)
5.1 rear pod
Front shock mount lowest hole
Centre shock 35wt
Side shock 40wt
Spec tyres 60mm rear 58mm front
Full additive rear
Full front additive apart from outer 6mm
Rideheight 6mm
Servo mounted flat
Sophia shell
racing the car here but it's not in the video
+ YouTube Video
CFR is offline   Reply With Quote
Old 12-20-2010, 11:11 AM   #570
AndiF's Avatar
Hi there, just got this reply from the AE customer service about the discontinuation of the RC10R5:
"There are no plans to replace the 10R5 with a new kit. I am not sure why it was discontinued either. I believe we will still make parts just not the complete kit anymore."
I'm really shocked about this...
...very bad news just before christmas...
Team Durango Switzerland - Corally - CRC - IRS - Team Associated
AndiF is offline   Reply With Quote
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
