Old 12-23-2009, 11:32 PM   #466
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
So after resaucing it still doesn't go back to the lap times you had when the charge was fresh? Or do you just get the faster lap times for another 6-8 laps and then it falls off again?
Old 12-23-2009, 11:52 PM   #467
Trader Rating: 5 (86%+)
Default losing power
the power is still off....it is just slower...maybe it is the battery or maybe it is to hooked up...maybe i have the gearing wrong..
obi wun is offline   Reply With Quote
Old 12-24-2009, 12:20 AM   #468
what could be wrong if the power goes back to normal for another 6 to 8 laps
Old 12-24-2009, 03:17 AM   #469
LOW ET's Avatar
Trader Rating: 97 (100%+)
Originally Posted by obi wun View Post
my setup is as follows...
3 timing boost
max turbo..
.5 delay..
0 motor timing
-1.5 camber
82 rollout
silver center shock 25 wt
side shock 30 blue springs...
handling is not a problem...i loose power..and i did exactly what you suggested...about pulling it off and going back..it runs as if it fell off again
what motor? what size track?
it seems to me that the roll out might be wrong, i'm under the impression that wgt like somewhere between 65-75mm roll out. you may be overgeared and overheating the motor???
LOW ET is offline   Reply With Quote
Old 12-24-2009, 03:28 AM   #470
2wdrive's Avatar
obi wun, if it is straight line speed that is slower after a few rounds then set your throttle epa on 90% recalibrate with the RS(pro) and then set your throttle epa to 100% again. ( i gues you made sure you didn't havee a hot motor?)
That will cure the problem of losing speed after a few minutes. If the laps are on the whole slower and not only straight line speed then it should be the tires. You still didn't mention what tires you are using. Some tires have only grip for a few minutes and then it goes away wich in turn means your laps are slower then before.
2wdrive is offline   Reply With Quote
Old 12-24-2009, 03:47 AM   #471
Foxxrocket's Avatar
If he was overgeared, and overheating the motor, wouldn't it thermel? In most cases when the motor thermels, it's dead on the track. It almost sounds like he's tapping out the battery, or a bad charger that's only charging the battery half way.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 12-24-2009, 03:52 AM   #472
LOW ET's Avatar
that may be but i thought i seen in another post of his that the track is 70' long or something and i would think he'd want to be on the lower end of rollout. 82mm seems like it would need a big track???
Old 12-24-2009, 08:49 AM   #473
Foxxrocket's Avatar
An 82mm rollout is normal for a 17.5 motor. And I'm only guessing here. I don't know what motor he's running.
Old 12-24-2009, 09:43 AM   #474
running a duo 2..on a 70 x30 track...o timing in motor...
Old 12-24-2009, 11:43 AM   #475
LOW ET's Avatar
duo 2 what, 17.5, 13.5, et...?
Old 12-24-2009, 11:44 AM   #476
Foxxrocket's Avatar
So, it is a 17.5?
Old 12-24-2009, 03:00 PM   #477
13.5 motor
Old 12-24-2009, 03:35 PM   #478
Foxxrocket's Avatar
Ok, then you are overgeared. Try a 73mm or 66mm rollout. The car will not be as fast, but at least you won't be straning the motor, or the battery.
Old 12-24-2009, 03:44 PM   #479
i went to a 71 rollout...and still had the same problem...should i go lower...if i do not have speed how can i win...
Old 12-24-2009, 03:48 PM   #480
LOW ET's Avatar
did you setup the radio like was mentioned in the other thread? setup on 90 and then adjust radio to 100. is there a reason your setting up at 135 and running at 150?
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
