Old 11-26-2009, 12:10 AM   #451
Jamesalex's Avatar
Hi, Low Et
Thanks for the pics, have you run the car with a reciever pack and the smart boost (not at the same time lol) to do back to back tests which route did you find the best??
Cheers
James
Jamesalex is offline   Reply With Quote
Old 11-26-2009, 03:21 AM   #452
Foxxrocket's Avatar
Do you guys bother rounding out the chassis? Or not worry about it?
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 11-26-2009, 04:54 AM   #453
LOW ET's Avatar
Trader Rating: 97 (100%+)
Originally Posted by Jamesalex View Post
Hi, Low Et
Cheers
James
i have not done testing but i know the fast guys are running a receiver pack. in my thinking the booster is connected to the main battery for power, whether it's draininig power from the motor or not, it's still draining power from the motors battery. so i switched to the receiver pack to power everything and the main battery throws all it's power to the motor. it gives me better piece of mind knowing i have all the power i could on tap.
LOW ET is online now   Reply With Quote
Old 11-26-2009, 04:57 AM   #454
LOW ET's Avatar
i used to do this to all my carbon fiber and seal the edges with ca but the last few cars i've done i haven't and i had no problems at all. you will still need to round the edges where the battery tape goes or the sharp edge will cut the tape. if you're using nimh batteries you'll have to do the battery slots also so it won't cut into the cell while in the slot.
Old 11-26-2009, 08:28 AM   #455
Foxxrocket's Avatar
I never thought about that. Good idea. Would applying ca glue effect chassis flex?
Old 11-26-2009, 08:32 AM   #456
LOW ET's Avatar
not sure if ca affects flex. it is intended to seal all the layers of carbon fiber together to help prevent them from delaminating.
Old 12-04-2009, 09:00 AM   #457
TimNJ's Avatar
Trader Rating: 50 (100%+)
I have my fully loaded 10R5 for sale if anyone is interested.
http://www.rctech.net/forum/r-c-item...mc-4900-a.html
Trinity - Caster Racing USA - Panther Racing
Race Videos: http://www.youtube.com/TrackMasterTim
TimNJ is offline   Reply With Quote
Old 12-04-2009, 09:52 AM   #458
Default Reciever pack
What should i use for a reciever pack?
Dale.0 is offline   Reply With Quote
Old 12-04-2009, 10:00 AM   #459
Trader Rating: 8 (90%+)
I just use a hobbyzone 300mah pack its good for alot of laps with out charge. I think it is around $11 but I do know there a some lighter and smaller ones out there.
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 12-20-2009, 10:58 AM   #460
Running 1 cell lipo 13.5. Set the car up so it is balanced side to side and the right rear is about 2 ounces heavy. Checked a couple of other cars and they are about the same. What is everyone doing about this? Would installing the 12R5.1 rear pod even things out?
Ed M.
bentgear is offline   Reply With Quote
Old 12-20-2009, 03:32 PM   #461
Trader Rating: 5 (86%+)
Default Front Springs
What are the effects or differences of running .018 front springs or .020 front springs. What does it make the car do?
obi wun is offline   Reply With Quote
Old 12-21-2009, 09:51 AM   #462
Answered my own question on the pod change. No noticable weight difference on the right rear, but a lower weight overall. Best idea, throw the scales away for this car and set it up on a tweak board. Works fine that way.
obi wun, the 18 springs will have a little more steering because it allows more weight to transfer to the outside front wheel. The 20 springs are use full when you just have too much steering, when the car is too darty, when the rear end is a little too lively wanting to step out and you canít get a handle on it some other way + plus a few more.
Ed M.
Old 12-23-2009, 10:33 PM   #463
Default Power draining...
hello world..another question for you...
my 10r5 is falling off something awful...the first 6 to 8 laps the car is a bullet everywhere..but soon after that it is slowing ..i mean like .4 .5 difference..i am running single cell lipo..timing is not high at all the car is super quick in and out of corners in the beginning...any advice...i have been told that the car is to hooked up and it is fast at the beginning because the tires have not come in but when they do it binds the car because of the crazy traction therefore draining power from the battery...any advice...i am listening..
Old 12-23-2009, 11:01 PM   #464
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I know at our track with lower traction, when the paragon is fresh I can rip off a few hot laps before the car levels out. Go out to the track with a fresh pack and freshly sauced tires. Run till you notice the large fall off you mentioned. Pull off and have a buddy resauce the tires and rescrubb in. If your lap times are back to your previous hotlaps you can eliminate the power combo (batt, esc, motor etc) as the culprit. Handling issues however will be difficult to identify without actually seeing the car. Can you post your set up?
Old 12-23-2009, 11:09 PM   #465
Default power draining
my setup is as follows...
3 timing boost
max turbo..
.5 delay..
0 motor timing
-1.5 camber
82 rollout
silver center shock 25 wt
side shock 30 blue springs...
handling is not a problem...i loose power..and i did exactly what you suggested...about pulling it off and going back..it runs as if it fell off again
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
